Samsung Galaxy S23 Battery Replacement
    1. Samsung Galaxy S23 Battery Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 Samsung Galaxy S23 Battery Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
      • Unplug any cables from your phone.
      • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
      Ask FixBot
    1. Samsung Galaxy S23 Battery Replacement, Heat the right edge: step 2, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes to soften the adhesive.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S23 Battery Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Insert an opening pick: step 3, image 3 of 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Samsung Galaxy S23 Battery Replacement, Separate the right adhesive: step 4, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Separate the right adhesive: step 4, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Separate the right adhesive: step 4, image 3 of 3
      • Slide the pick back and forth along the right edge to separate the adhesive.
      • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S23 Battery Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
      Ask FixBot
    5. Samsung Galaxy S23 Battery Replacement, Separate the corner adhesive: step 6, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Separate the corner adhesive: step 6, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Separate the corner adhesive: step 6, image 3 of 3
      • Insert a second opening pick at the bottom right corner.
      • Rotate it around the bottom right corner to separate the adhesive.
      Ask FixBot
    6. Samsung Galaxy S23 Battery Replacement, Separate the bottom adhesive: step 7, image 1 of 2 Samsung Galaxy S23 Battery Replacement, Separate the bottom adhesive: step 7, image 2 of 2
      • Slide your opening pick to the bottom left corner to separate the adhesive.
      • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Samsung Galaxy S23 Battery Replacement, Heat the left edge: step 8, image 1 of 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Ask FixBot
    8. Samsung Galaxy S23 Battery Replacement, Separate the corner adhesive: step 9, image 1 of 2 Samsung Galaxy S23 Battery Replacement, Separate the corner adhesive: step 9, image 2 of 2
      • Rotate the opening pick around the bottom left corner to separate the adhesive.
      Ask FixBot
    9. Samsung Galaxy S23 Battery Replacement, Separate the left adhesive: step 10, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Separate the left adhesive: step 10, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Separate the left adhesive: step 10, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • Slide your pick toward the top left corner to separate the adhesive.
      • Leave the pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    10. Samsung Galaxy S23 Battery Replacement, Heat the top edge: step 11, image 1 of 1
      • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
      Ask FixBot
    11. Samsung Galaxy S23 Battery Replacement, Separate the corner adhesive: step 12, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Separate the corner adhesive: step 12, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Separate the corner adhesive: step 12, image 3 of 3
      • Insert a fourth opening pick at the top left corner.
      • Rotate it around the top left corner to separate the adhesive.
      Ask FixBot
    12. Samsung Galaxy S23 Battery Replacement, Separate the top adhesive: step 13, image 1 of 2 Samsung Galaxy S23 Battery Replacement, Separate the top adhesive: step 13, image 2 of 2
      • Slide your opening pick to the top right corner to separate the adhesive.
      • Leave the pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    13. Samsung Galaxy S23 Battery Replacement, Separate the flash adhesive: step 14, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Separate the flash adhesive: step 14, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Separate the flash adhesive: step 14, image 3 of 3
      • There's a remaining patch of adhesive directly under the flash.
      • Line up the tip of an opening pick with the flash cutout.
      • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
      • You should see the opening pick through the flash cutout.
      • Keep sliding the pick toward the bottom of the phone until you feel the adhesive completely separate from the back cover.
      • Avoid touching the rear cameras with your pick. Pushing against the lenses risks damaging them.
      Ask FixBot
    14. Samsung Galaxy S23 Battery Replacement, Remove the back cover: step 15, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Remove the back cover: step 15, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Remove the back cover: step 15, image 3 of 3
      • Grab and remove the back cover.
      • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S23 Battery Replacement, Disconnect the wireless charging coil: step 16, image 1 of 2 Samsung Galaxy S23 Battery Replacement, Disconnect the wireless charging coil: step 16, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
      • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    2. Samsung Galaxy S23 Battery Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 3 of 3
      • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
      • Six screws securing the wireless charging coil
      • Seven screws securing the loudspeaker
      Ask FixBot
    3. Samsung Galaxy S23 Battery Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 3 of 3
      • Insert the point of your spudger in the notch at the top left corner of the loudspeaker.
      • Pry up to unclip the loudspeaker from the frame.
      Ask FixBot
    4. Samsung Galaxy S23 Battery Replacement: step 19, image 1 of 3 Samsung Galaxy S23 Battery Replacement: step 19, image 2 of 3 Samsung Galaxy S23 Battery Replacement: step 19, image 3 of 3
      • Use your fingers to lift the loudspeaker away from the frame to fully separate it.
      • Remove the wireless charging coil and loudspeaker from the frame.
      • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
      Ask FixBot
    1. Samsung Galaxy S23 Battery Replacement, Disconnect the battery: step 20, image 1 of 2 Samsung Galaxy S23 Battery Replacement, Disconnect the battery: step 20, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    1. Samsung Galaxy S23 Battery Replacement, Disconnect the interconnect cables: step 21, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Disconnect the interconnect cables: step 21, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Disconnect the interconnect cables: step 21, image 3 of 3
      • Use your spudger to pry up and disconnect the primary and secondary interconnect cable press connectors from the daughterboard.
      Ask FixBot
    2. Samsung Galaxy S23 Battery Replacement: step 22, image 1 of 3 Samsung Galaxy S23 Battery Replacement: step 22, image 2 of 3 Samsung Galaxy S23 Battery Replacement: step 22, image 3 of 3
      • Repeat the previous step for the primary and secondary interconnect cable connectors on the motherboard.
      Ask FixBot
    3. Samsung Galaxy S23 Battery Replacement, Remove the interconnect cables: step 23, image 1 of 2 Samsung Galaxy S23 Battery Replacement, Remove the interconnect cables: step 23, image 2 of 2
      • Remove both interconnect cables.
      Ask FixBot
    1. Samsung Galaxy S23 Battery Replacement, Disconnect the display and antenna cables: step 24, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Disconnect the display and antenna cables: step 24, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Disconnect the display and antenna cables: step 24, image 3 of 3
      • Use your spudger to pry up and disconnect the display and 5G mmWave cable press connectors from the motherboard.
      Ask FixBot
    2. Samsung Galaxy S23 Battery Replacement, Remove the display cable: step 25, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Remove the display cable: step 25, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Remove the display cable: step 25, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the display cable press connector from the bottom edge of the phone.
      • Remove the display cable.
      Ask FixBot
    3. Samsung Galaxy S23 Battery Replacement, Reposition the cables: step 26, image 1 of 2 Samsung Galaxy S23 Battery Replacement, Reposition the cables: step 26, image 2 of 2
      • Use your finger to push the battery and antenna cables away from the battery.
      Ask FixBot
    4. Samsung Galaxy S23 Battery Replacement, Separate the battery pull tab: step 27, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Separate the battery pull tab: step 27, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Separate the battery pull tab: step 27, image 3 of 3
      • Be very careful not to bend, crease, or puncture the battery during the next few steps. A damaged battery can leak dangerous chemicals and catch fire.
      • Use your fingers to carefully peel the battery pull tab from the left side of the battery.
      Ask FixBot
    5. Samsung Galaxy S23 Battery Replacement: step 28, image 1 of 1
      • Peel the two small tabs from the top and bottom corners of the battery's left edge.
      • If these tabs aren't fully separated, you won't be able to lift the battery in the next step.
      Ask FixBot
    6. Samsung Galaxy S23 Battery Replacement, Separate the battery adhesive: step 29, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Separate the battery adhesive: step 29, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Separate the battery adhesive: step 29, image 3 of 3
      • With one hand, fold the two upper and lower tabs out of the way of the battery and firmly hold down the frame.
      • If you're having trouble with the tabs, you can fold them under the phone and tape them to the screen.
      • With your free hand, grip the blue center pull tab and pull straight up with strong, steady force to separate the battery adhesive.
      • The adhesive might not separate immediately. Keep pulling with consistent force until the battery comes free from the frame.
      • If you're having trouble, apply 1-2 drops of high-concentration (more than 90%) isopropyl alcohol to the left edge of the battery. Elevate the left edge of your phone and wait one minute for the alcohol to soften the adhesive.
      • Lay the battery over the right edge of your phone.
      Ask FixBot
    7. Samsung Galaxy S23 Battery Replacement, Remove the battery: step 30, image 1 of 3 Samsung Galaxy S23 Battery Replacement, Remove the battery: step 30, image 2 of 3 Samsung Galaxy S23 Battery Replacement, Remove the battery: step 30, image 3 of 3
      • Peel the battery's plastic film from the frame.
      • Remove the battery and its film.
      • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after reassembling your phone.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy S23 Answers Community for troubleshooting help.
31 other people completed this guide.
Alex Diaz-Kokaisl
250,021 Reputation
1,203 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
4 Guide Comments
Thank you for this guide! Easy to follow. I couldn't get the phone open until I bought the iopener kit and anticlamp. Once I got it open, wasn't a big deal to replace. I did take photos that helped as I was opening it, as my battery was slightly different from these photos and I wanted to make sure I knew exactly what I was looking at. It works great now and turned right back on with no issue. Thank you!
Kate Hoelscher - Reply Share
Great step by step guide. Thanks!
Troy Schmanke - Reply Share
Thank you very much for this guide. My phone basically bricked after an update, and there was nothing I could do to make it respond. Holding the power and volume buttons, charging it, even plugging it into my computer gave zero feedback (totally black screen, no vibration or sound). I had to pop the phone open and completely disconnect the battery, and when I reconnected it everything was back to normal. It was my first time ever disassembling and attempting to repair electronics and this guide was essential in figuring out what I was doing.
Matthew Toro - Reply Share
Please ad a note to be extra careful on the right side. I angled my pic just right and broke the blue daughter board cable. The way it angles up if you are anything but flat when you go to pry it will snap it. Be sure to slide the pick only down towards the charge port when separating the right side of the back panel. Any upwards movements has the potential to snag.
30 VOID - Reply Share
Past 24 Hours: 164
Past 7 Days: 914
Past 30 Days: 3,974
All Time: 58,663
