Samsung Galaxy S21 Plus Battery Replacement
    1. Samsung Galaxy S21 Plus Battery Replacement, Heat the back cover: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S21 Plus Battery Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
      • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Samsung Galaxy S21 Plus Battery Replacement, Slice the adhesive: step 3, image 1 of 2 Samsung Galaxy S21 Plus Battery Replacement, Slice the adhesive: step 3, image 2 of 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S21 Plus Battery Replacement, Slice the adhesive: step 4, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Slice the adhesive: step 4, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Slice the adhesive: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
      • Insert a third opening pick at the bottom right corner of your phone.
      • Slide the opening pick along the right edge of your phone to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Samsung Galaxy S21 Plus Battery Replacement: step 5, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement: step 5, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement: step 5, image 3 of 3
      • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
      • Insert a fourth opening pick underneath the top right corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Samsung Galaxy S21 Plus Battery Replacement: step 6, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement: step 6, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement: step 6, image 3 of 3
      • Insert a fifth opening pick underneath the bottom left corner.
      • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
      • When you slice near the power button, insert only the tip of the opening pick (~3-4 mm) to avoid damaging the power and volume button flex cable.
      Ask FixBot
    7. Samsung Galaxy S21 Plus Battery Replacement, Remove the back cover: step 7, image 1 of 2 Samsung Galaxy S21 Plus Battery Replacement, Remove the back cover: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the back cover.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
      • If you're using Samsung custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S21 Plus Battery Replacement, Slice the adhesive: step 8, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Slice the adhesive: step 8, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Slice the adhesive: step 8, image 3 of 3
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
      • Be careful of the cable that runs beneath the charging coil. Work slowly and stop sliding the pick if it catches on the cable.
      • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
      • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
      Ask FixBot
    2. Samsung Galaxy S21 Plus Battery Replacement: step 9, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement: step 9, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement: step 9, image 3 of 3
      • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
      • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
      Ask FixBot
    3. Samsung Galaxy S21 Plus Battery Replacement, Disconnect the charging coil: step 10, image 1 of 2 Samsung Galaxy S21 Plus Battery Replacement, Disconnect the charging coil: step 10, image 2 of 2
      • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
      Ask FixBot
    4. Samsung Galaxy S21 Plus Battery Replacement, Disconnect the NFC antenna: step 11, image 1 of 2 Samsung Galaxy S21 Plus Battery Replacement, Disconnect the NFC antenna: step 11, image 2 of 2
      • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
      Ask FixBot
    5. Samsung Galaxy S21 Plus Battery Replacement, Unfasten the NFC antenna & charging coil assembly screws: step 12, image 1 of 1
      • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
      Ask FixBot
    6. Samsung Galaxy S21 Plus Battery Replacement, Remove the NFC antenna & charging coil assembly: step 13, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Remove the NFC antenna & charging coil assembly: step 13, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Remove the NFC antenna & charging coil assembly: step 13, image 3 of 3
      Buy
      • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
      Ask FixBot
    1. Samsung Galaxy S21 Plus Battery Replacement, Disconnect the battery cable: step 14, image 1 of 2 Samsung Galaxy S21 Plus Battery Replacement, Disconnect the battery cable: step 14, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
    1. Samsung Galaxy S21 Plus Battery Replacement, Unfasten the loudspeaker assembly screws: step 15, image 1 of 1
      • Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the loudspeaker assembly.
      Ask FixBot
    2. Samsung Galaxy S21 Plus Battery Replacement, Pry up the loudspeaker assembly: step 16, image 1 of 2 Samsung Galaxy S21 Plus Battery Replacement, Pry up the loudspeaker assembly: step 16, image 2 of 2
      • Insert an opening pick into the gap between the top edge of the loudspeaker assembly and the midframe.
      • Use your opening pick to pry up the loudspeaker assembly by tilting it downwards.
      Ask FixBot
    3. Samsung Galaxy S21 Plus Battery Replacement, Remove the loudspeaker assembly: step 17, image 1 of 2 Samsung Galaxy S21 Plus Battery Replacement, Remove the loudspeaker assembly: step 17, image 2 of 2
      • Remove the loudspeaker assembly.
      • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      Ask FixBot
    1. Samsung Galaxy S21 Plus Battery Replacement, Disconnect the display flex cable: step 18, image 1 of 2 Samsung Galaxy S21 Plus Battery Replacement, Disconnect the display flex cable: step 18, image 2 of 2
      • Use a spudger to disconnect the display flex cable by prying its upper connector straight up from its socket.
      Ask FixBot
    1. Samsung Galaxy S21 Plus Battery Replacement, Disconnect the main & interconnect flex cables: step 19, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Disconnect the main & interconnect flex cables: step 19, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Disconnect the main & interconnect flex cables: step 19, image 3 of 3
      • Use a spudger to disconnect the main and interconnect flex cables from the motherboard by prying their upper connectors straight up from their sockets.
      Ask FixBot
    1. Samsung Galaxy S21 Plus Battery Replacement, Remove the display flex cable: step 20, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Remove the display flex cable: step 20, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Remove the display flex cable: step 20, image 3 of 3
      Buy
      • Use a spudger to disconnect the display flex cable by prying its bottom connector straight up from its socket.
      • Use your fingers or a pair of tweezers to carefully remove the display flex cable.
      Ask FixBot
    1. Samsung Galaxy S21 Plus Battery Replacement, Remove the main flex cable: step 21, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Remove the main flex cable: step 21, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Remove the main flex cable: step 21, image 3 of 3
      Buy
      • Use a spudger to disconnect the main flex cable from the daughterboard by prying its bottom connector straight up from its socket.
      • Use your fingers or a pair of tweezers to carefully remove the main flex cable.
      Ask FixBot
    2. Samsung Galaxy S21 Plus Battery Replacement, Remove the interconnect flex cable: step 22, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Remove the interconnect flex cable: step 22, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Remove the interconnect flex cable: step 22, image 3 of 3
      • Use a spudger to disconnect the interconnect flex cable from the daughterboard by prying its bottom connector straight up from its socket.
      • Use your fingers or a pair of tweezers to carefully remove the interconnect flex cable.
      Ask FixBot
    1. Samsung Galaxy S21 Plus Battery Replacement, Disconnect the power button flex cable: step 23, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Disconnect the power button flex cable: step 23, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Disconnect the power button flex cable: step 23, image 3 of 3
      • Use a spudger to disconnect the power button flex cable by prying the connector straight up from its socket.
      • Use your spudger to carefully bend the flex cable to the side to avoid damaging it during the battery removal.
      Ask FixBot
    2. Samsung Galaxy S21 Plus Battery Replacement, Apply high concentration isopropyl alcohol: step 24, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Apply high concentration isopropyl alcohol: step 24, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Apply high concentration isopropyl alcohol: step 24, image 3 of 3
      • The battery adhesive of the Samsung Galaxy S21 Plus is very strong. If you can't manage to remove the battery by only using high concentration isopropyl alcohol (over 90%) you can try a combination with heat. In this case prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath the battery.
      • Apply 1-2 drops of high concentration (over 90%) isopropyl alcohol to the gaps in between the frame and the left and right edge of the battery.
      • Only apply a few drops and come back again if necessary. The are two cutouts in the midframe of the phone and too much isopropyl alcohol may run to the screen and loosen or damage it.
      • Let the isopropyl alcohol penetrate the battery adhesive for at least two to three minutes.
      Ask FixBot
    3. Samsung Galaxy S21 Plus Battery Replacement, Insert an opening pick: step 25, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Insert an opening pick: step 25, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Insert an opening pick: step 25, image 3 of 3
      • For this step, insert the opening pick into the edge with a wider gap between the midframe and the battery so that you have more space for the opening pick and get a better leverage.
      • Secure a suction handle to the battery, as close to the battery edge as possible.
      • Insert an opening pick into the gap between the edge of the battery and the frame.
      • Rotate the opening pick to insert its long edge into the gap.
      Ask FixBot
    4. Samsung Galaxy S21 Plus Battery Replacement, Pry up the battery: step 26, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Pry up the battery: step 26, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Pry up the battery: step 26, image 3 of 3
      Heavy-Duty Suction Cups (Pair)
      $16.95
      Buy
      • Take care not to puncture or bend the battery during the removal procedure—a punctured or bent battery may leak dangerous chemicals or cause a thermal event. In case you're struggling to pull up the battery apply more isopropyl alcohol and try again.
      • Pull up on the suction handle with firm, steady pressure and tilt the opening pick downwards at the same time to pry up the battery.
      • If you're struggling to pull up the battery with your suction handle you can try to use a heavy-duty suction cup instead.
      Ask FixBot
    5. Samsung Galaxy S21 Plus Battery Replacement, Remove the battery: step 27, image 1 of 3 Samsung Galaxy S21 Plus Battery Replacement, Remove the battery: step 27, image 2 of 3 Samsung Galaxy S21 Plus Battery Replacement, Remove the battery: step 27, image 3 of 3
      • Remove the battery, making sure to peel off any remaining adhesive.
      • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      • Temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Follow this guide to perform a battery cycle reset, and calibrate your newly-installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
13 other people completed this guide.
Dominik Schnabelrauch
263,756 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,581 Guides authored
7 Guide Comments
Super tuto ! Merci beaucoup
Charlie PRIEUR - Reply Share
Thank you very much!
I'm glad that step 26 emphasized how strong the battery is glued to the frame, that was much harder to remove than expected.
I also could not remove the NFC antenna and charging coil, because of a broken screw on this refurbished phone. But I managed to complete the battery swap anyway, since one only needs to reach the connectors under the edge of the NFC module
GEB - Reply Share
이건 21plus가 아니라 Ultra에요
Bro, this is galaxy 21 Ultra,
not 21 plus :(
euis Gen - Reply Share
The S21 Ultra has a larger camera bump. What makes you think this is the Ultra?
Spencer Pennington - Reply Share
The parts worked but where is the installation part of the installation guide. Either I'm missing something or this website is. everything I've looked at is not the same part or leave out steps. Also if you could include a nice rubber tool with a roundish textured head to work in the solvent and get the glue off that would have made me a lot happier..
sean S - Reply Share
Past 24 Hours: 15
Past 7 Days: 176
Past 30 Days: 849
All Time: 39,320
