Samsung Galaxy S21 Battery Replacement
    1. Samsung Galaxy S21 Battery Replacement, Heat the bottom edge: step 1, image 1 of 1
      • Completely power off your phone before you begin.
      • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back cover are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S21 Battery Replacement, Separate the bottom adhesive: step 2, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Separate the bottom adhesive: step 2, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Separate the bottom adhesive: step 2, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      • Only insert the pick up to 5 mm, as you may damage internal components if you go further.
      Ask FixBot
    3. Samsung Galaxy S21 Battery Replacement, Slice the bottom adhesive: step 3, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Slice the bottom adhesive: step 3, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Slice the bottom adhesive: step 3, image 3 of 3
      • Slide the pick back and forth along the bottom edge to slice through the adhesive.
      • Leave the pick in to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S21 Battery Replacement, Heat the left edge: step 4, image 1 of 1
      • Apply a heated iOpener to the back cover's left edge for two minutes.
      Ask FixBot
    5. Samsung Galaxy S21 Battery Replacement, Separate the left adhesive: step 5, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Separate the left adhesive: step 5, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Separate the left adhesive: step 5, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
      Ask FixBot
    6. Samsung Galaxy S21 Battery Replacement: step 6, image 1 of 3 Samsung Galaxy S21 Battery Replacement: step 6, image 2 of 3 Samsung Galaxy S21 Battery Replacement: step 6, image 3 of 3
      • Slide an opening pick along the left edge towards the bottom left corner to cut the adhesive.
      • Don't cut past where the camera shell meets the back cover, as you risk cracking the plastic.
      Ask FixBot
    7. Samsung Galaxy S21 Battery Replacement, Heat the right edge: step 7, image 1 of 1
      • Apply a heated iOpener to the back cover's right edge for two minutes.
      Ask FixBot
    8. Samsung Galaxy S21 Battery Replacement, Separate the right adhesive: step 8, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Separate the right adhesive: step 8, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Separate the right adhesive: step 8, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
      • Only insert the pick up to 3 mm, as you may damage the secondary interconnect cable, which runs parallel to the right edge.
      Ask FixBot
    9. Samsung Galaxy S21 Battery Replacement: step 9, image 1 of 3 Samsung Galaxy S21 Battery Replacement: step 9, image 2 of 3 Samsung Galaxy S21 Battery Replacement: step 9, image 3 of 3
      • Slide an opening pick back and forth along the back cover's right edge to cut the adhesive.
      Ask FixBot
    10. Samsung Galaxy S21 Battery Replacement, Separate the corner adhesive: step 10, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Separate the corner adhesive: step 10, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Separate the corner adhesive: step 10, image 3 of 3
      • Rotate the right-edge opening pick around the top-right corner of the phone.
      • This procedure can be applied to each corner, except the top-left where the rear-facing camera is located.
      Ask FixBot
    11. Samsung Galaxy S21 Battery Replacement, Reposition the opening picks: step 11, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Reposition the opening picks: step 11, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Reposition the opening picks: step 11, image 3 of 3
      • Slide the top-most opening pick as close to the camera shell as possible.
      • Repeat for the left-edge pick.
      Ask FixBot
    12. Samsung Galaxy S21 Battery Replacement, Heat the camera shell: step 12, image 1 of 1
      • Heat an iOpener and apply it to the camera shell for two minutes.
      Ask FixBot
    13. Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive: step 13, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive: step 13, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive: step 13, image 3 of 3
      • Rotate the back cover counterclockwise to create a gap between the camera shell and the frame.
      • Only insert the pick up to 5 mm to avoid scratching the camera.
      • Insert an opening pick in the gap.
      • If this method doesn't work, move to the next step for an alternative method; otherwise, skip the next step.
      Ask FixBot
    14. Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive (alternate method): step 14, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive (alternate method): step 14, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive (alternate method): step 14, image 3 of 3
      • Gently slide the two picks toward the camera shell so they are under the corners of the back cover adjacent to the camera shell.
      • Move the picks back and forth along the bridge between the back cover and the camera shell until you create a gap between the camera shell and the frame.
      • Be careful with this method, as you risk cracking the plastic back cover.
      Ask FixBot
    15. Samsung Galaxy S21 Battery Replacement: step 15, image 1 of 3 Samsung Galaxy S21 Battery Replacement: step 15, image 2 of 3 Samsung Galaxy S21 Battery Replacement: step 15, image 3 of 3
      • Slide an opening pick between the camera shell and the frame to cut the adhesive.
      • There's a significant amount of adhesive securing the frame to the camera shell, so multiple rounds of heating may be needed.
      Ask FixBot
    16. Samsung Galaxy S21 Battery Replacement: step 16, image 1 of 2 Samsung Galaxy S21 Battery Replacement: step 16, image 2 of 2
      • There's additional adhesive to the right of the camera that you need to cut through.
      • There's a plate on the back cover surrounding the phone's flash that the pick can get stuck on:
      • Angle the pick downward to avoid any damage.
      Ask FixBot
    17. Samsung Galaxy S21 Battery Replacement: step 17, image 1 of 3 Samsung Galaxy S21 Battery Replacement: step 17, image 2 of 3 Samsung Galaxy S21 Battery Replacement: step 17, image 3 of 3
      • Line up the opening pick's tip with your phone's flash
      • Insert the pick slowly, making sure to avoid the flash's plate.
      • The plate's resistance can feel similar to adhesive. Angle the pick downward to keep the pick from sliding into the plate.
      • Slice the adhesive to the right of the camera.
      Ask FixBot
    18. Samsung Galaxy S21 Battery Replacement, Remove the back cover: step 18, image 1 of 2 Samsung Galaxy S21 Battery Replacement, Remove the back cover: step 18, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the back cover.
      • If your back cover is still sticking to the frame, slide the pick around the edges of the phone until the back cover completely separates.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
      • If you're using Samsung custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S21 Battery Replacement, Unfasten the motherboard bracket: step 19, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
      • Throughout this repair, keep track of each screw, and make sure it goes back exactly where it came from.
      Ask FixBot
    2. Samsung Galaxy S21 Battery Replacement, Unclip the motherboard bracket: step 20, image 1 of 2 Samsung Galaxy S21 Battery Replacement, Unclip the motherboard bracket: step 20, image 2 of 2
      Buy
      • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
      • Do not completely remove the bracket yet, as it's still attached to the wireless charging coil.
      Ask FixBot
    3. Samsung Galaxy S21 Battery Replacement, Disconnect the battery: step 21, image 1 of 2 Samsung Galaxy S21 Battery Replacement, Disconnect the battery: step 21, image 2 of 2
      • While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
      • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    4. Samsung Galaxy S21 Battery Replacement, Disconnect the wireless charging coil: step 22, image 1 of 2 Samsung Galaxy S21 Battery Replacement, Disconnect the wireless charging coil: step 22, image 2 of 2
      • While still holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
      Ask FixBot
    5. Samsung Galaxy S21 Battery Replacement, Remove the wireless charging coil: step 23, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Remove the wireless charging coil: step 23, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Remove the wireless charging coil: step 23, image 3 of 3
      • The wireless charging coil is secured to the phone with light adhesive.
      • Use your fingers to gently peel the wireless charging coil away from the phone.
      • During reassembly, refasten the motherboard bracket screws first to properly align the charging coil into place, then firmly press the rest of the coil down to adhere it.
      Ask FixBot
    1. Samsung Galaxy S21 Battery Replacement, Unfasten the loudspeaker: step 24, image 1 of 1
      • Use a Phillips screwdriver to remove the six 4 mm screws securing the loudspeaker to the frame.
      Ask FixBot
    2. Samsung Galaxy S21 Battery Replacement, Remove the loudspeaker: step 25, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Remove the loudspeaker: step 25, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Remove the loudspeaker: step 25, image 3 of 3
      • Insert the point of a spudger into the notch in the top-left corner of the loudspeaker and pry up to release the clips holding it in place.
      • Remove the loudspeaker.
      Ask FixBot
    1. Samsung Galaxy S21 Battery Replacement, Disconnect the primary interconnect cable: step 26, image 1 of 2 Samsung Galaxy S21 Battery Replacement, Disconnect the primary interconnect cable: step 26, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the primary interconnect cable's press connector.
      Ask FixBot
    2. Samsung Galaxy S21 Battery Replacement, Disconnect the secondary interconnect cable: step 27, image 1 of 2 Samsung Galaxy S21 Battery Replacement, Disconnect the secondary interconnect cable: step 27, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the secondary interconnect cable's press connector.
      Ask FixBot
    3. Samsung Galaxy S21 Battery Replacement, Disconnect the secondary/primary interconnect cables: step 28, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Disconnect the secondary/primary interconnect cables: step 28, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Disconnect the secondary/primary interconnect cables: step 28, image 3 of 3
      • Use the flat end of a spudger to pry up on the secondary interconnect cable's press connector.
      • Repeat for the primary interconnect cable's press connector.
      Ask FixBot
    4. Samsung Galaxy S21 Battery Replacement, Remove the secondary/primary interconnect cables: step 29, image 1 of 2 Samsung Galaxy S21 Battery Replacement, Remove the secondary/primary interconnect cables: step 29, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the secondary and primary interconnect cables.
      Ask FixBot
    5. Samsung Galaxy S21 Battery Replacement, Disconnect the display cable: step 30, image 1 of 2 Samsung Galaxy S21 Battery Replacement, Disconnect the display cable: step 30, image 2 of 2
      • Use a spudger to pry up and disconnect the display cable's bottom press connector.
      Ask FixBot
    6. Samsung Galaxy S21 Battery Replacement: step 31, image 1 of 2 Samsung Galaxy S21 Battery Replacement: step 31, image 2 of 2
      • Use a spudger to pry up and disconnect the display cable's top press connector.
      Ask FixBot
    7. Samsung Galaxy S21 Battery Replacement, Remove the display cable: step 32, image 1 of 1
      • Use tweezers, or your fingers, to remove the display cable.
      Ask FixBot
    1. Samsung Galaxy S21 Battery Replacement, Apply isopropyl alcohol: step 33, image 1 of 2 Samsung Galaxy S21 Battery Replacement, Apply isopropyl alcohol: step 33, image 2 of 2
      • Take care not to puncture or bend the battery during the removal procedure—a punctured or bent battery may leak dangerous chemicals or cause a thermal event. In case you're struggling to pull up the battery, apply more isopropyl alcohol and try again.
      • Apply 1-2 drops of high concentration (over 90%) isopropyl alcohol to the gaps surrounding the battery's perimeter.
      • Only apply a few drops initially and apply more if necessary; too much isopropyl alcohol might overflow onto the motherboard and daughterboard or damage the display
      Ask FixBot
    2. Samsung Galaxy S21 Battery Replacement, Insert an opening pick: step 34, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Insert an opening pick: step 34, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Insert an opening pick: step 34, image 3 of 3
      • Apply a suction cup to the battery, as close to the center of the right edge as possible.
      • Insert an opening pick into the edge with the widest gap between the frame and the battery.
      • Rotate the opening pick to insert its long edge into the gap.
      Ask FixBot
    3. Samsung Galaxy S21 Battery Replacement, Separate the battery's adhesive: step 35, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Separate the battery's adhesive: step 35, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Separate the battery's adhesive: step 35, image 3 of 3
      • Pull up on the suction cup with strong, steady force and pry up with the opening pick to separate the battery from the frame.
      • If you're struggling to pull up the battery with your suction handle, apply 1-2 more drops of isopropyl alcohol.
      Ask FixBot
    4. Samsung Galaxy S21 Battery Replacement, Remove the battery: step 36, image 1 of 3 Samsung Galaxy S21 Battery Replacement, Remove the battery: step 36, image 2 of 3 Samsung Galaxy S21 Battery Replacement, Remove the battery: step 36, image 3 of 3
      • Remove the battery, making sure to peel off any remaining adhesive.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      • Temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it's seated.
      Ask FixBot
Follow this guide to perform a battery cycle reset, and calibrate your newly-installed battery.
66 other people completed this guide.
Alex Diaz-Kokaisl
247,608 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
84,052 Guides authored
13 Guide Comments
Will it void my warranty
BakaDolev - Reply Share
Yes, unfortunately the warranty will be voided if you "tamper" with any of the components.
Alex Diaz-Kokaisl - Reply Share
Just a note to the last step regarding iso. Be careful not applying too much iso - it will run down to the display via the hole in the back.
Adam Skou Ohana - Reply Share
The glue is a pain but I wasn't nearly as careful on the bottom part as the guide suggested and was able to get it off just fine. I also didn't bother to remove the old glue and it holds well enough
Josh Oxborrow - Reply Share
will my waterproofness go away
Rzgar67 - Reply Share
Past 24 Hours: 141
Past 7 Days: 921
Past 30 Days: 4,177
All Time: 204,955
