Samsung Galaxy S20 Ultra Screen Replacement
    1. Samsung Galaxy S20 Ultra Screen Replacement, Heat the bottom edge: step 1, image 1 of 1
      • Unplug and power off your phone before you begin.
      • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S20 Ultra Screen Replacement, Separate the bottom edge adhesive: step 2, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Separate the bottom edge adhesive: step 2, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Separate the bottom edge adhesive: step 2, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
      • If the back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
      • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
      • Insert the point of an opening pick into the gap.
      • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
      • If you are having trouble creating a gap, apply more heat to the edge and try again.
      • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
      Ask FixBot
    3. Samsung Galaxy S20 Ultra Screen Replacement, Slice the adhesive: step 3, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Slice the adhesive: step 3, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Slice the adhesive: step 3, image 3 of 3
      • Slide the pick back and forth along the bottom edge to slice through the adhesive.
      • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
      • Leave your opening pick in the seam to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S20 Ultra Screen Replacement, Heat the left edge: step 4, image 1 of 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Ask FixBot
    5. Samsung Galaxy S20 Ultra Screen Replacement, Separate the left edge adhesive: step 5, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Separate the left edge adhesive: step 5, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Separate the left edge adhesive: step 5, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
      • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
      • Due to tight tolerances, this may take multiple attempts.
      • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
      Ask FixBot
    6. Samsung Galaxy S20 Ultra Screen Replacement: step 6, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement: step 6, image 2 of 2
      • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
      Ask FixBot
    7. Samsung Galaxy S20 Ultra Screen Replacement: step 7, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement: step 7, image 2 of 2
      • Slide the pick towards the bottom edge of the phone to separate the back cover's adhesive.
      • Leave your pick under the left edge of the glass near the bottom of the device to prevent the adhesive from resealing.
      Ask FixBot
    8. Samsung Galaxy S20 Ultra Screen Replacement: step 8, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement: step 8, image 2 of 2
      • Insert another pick under the center of the left edge of the back cover.
      • Gradually slide the pick towards the top of the device to separate the back cover's adhesive.
      • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
      • Leave your pick under the left edge of the glass near the top of the device to prevent the adhesive from resealing.
      Ask FixBot
    9. Samsung Galaxy S20 Ultra Screen Replacement, Heat the right edge: step 9, image 1 of 1
      • Apply a heated iOpener to the right edge of the back cover for two minutes.
      Ask FixBot
    10. Samsung Galaxy S20 Ultra Screen Replacement, Separate the right edge adhesive: step 10, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Separate the right edge adhesive: step 10, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Separate the right edge adhesive: step 10, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
      • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
      Ask FixBot
    11. Samsung Galaxy S20 Ultra Screen Replacement: step 11, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement: step 11, image 2 of 2
      • Leave your pick under the right edge of the glass near the bottom of the device to prevent the adhesive from resealing.
      Ask FixBot
    12. Samsung Galaxy S20 Ultra Screen Replacement: step 12, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement: step 12, image 2 of 2
      • Insert another pick underneath the center of the right edge of the back cover.
      • As you do this, the bottom edge of the back cover may release the three picks located there. If this occurs, set these picks aside as the bottom edge shouldn't reseal from this point onward.
      Ask FixBot
    13. Samsung Galaxy S20 Ultra Screen Replacement, Heat the top edge: step 13, image 1 of 1
      • Apply a heated iOpener to the top edge of the back cover for two minutes.
      Ask FixBot
    14. Samsung Galaxy S20 Ultra Screen Replacement, Separate the top edge adhesive: step 14, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Separate the top edge adhesive: step 14, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Separate the top edge adhesive: step 14, image 3 of 3
      • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
      • Gradually slide the pick from the right edge of the device around the top right corner.
      • Continue slicing along the top edge to fully separate the back cover adhesive.
      • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
      Ask FixBot
    15. Samsung Galaxy S20 Ultra Screen Replacement, Remove the back cover: step 15, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement, Remove the back cover: step 15, image 2 of 2
      Tool used on this step:
      Buy
      • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
      • Remove the back cover.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using Samsung custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S20 Ultra Screen Replacement, Disconnect the wireless charging coil: step 16, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement, Disconnect the wireless charging coil: step 16, image 2 of 2
      • Use a spudger to pry up and disconnect the wireless charging coil connector.
      • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
      Ask FixBot
    2. Samsung Galaxy S20 Ultra Screen Replacement, Remove the wireless charging coil: step 17, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Remove the wireless charging coil: step 17, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Remove the wireless charging coil: step 17, image 3 of 3
      Buy
      • Use a pair of tweezers to gently peel the wireless charging coil away from the device.
      • Remove the wireless charging coil.
      • During reassembly, reconnect the wireless charging coil connector first to properly align it into place, then firmly press the rest of the coil down to adhere it.
      Ask FixBot
    1. Samsung Galaxy S20 Ultra Screen Replacement, Unfasten the motherboard bracket: step 18, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips #00 screwdriver to remove the five 3.9 mm-long screws securing the motherboard bracket.
      Ask FixBot
    2. Samsung Galaxy S20 Ultra Screen Replacement, Remove the motherboard bracket: step 19, image 1 of 1
      Buy
      • Use a pair of tweezers to unclip and remove the motherboard bracket.
      Ask FixBot
    3. Samsung Galaxy S20 Ultra Screen Replacement, Disconnect the battery: step 20, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement, Disconnect the battery: step 20, image 2 of 2
      • Use a spudger to pry up and disconnect the battery connector.
      Ask FixBot
    1. Samsung Galaxy S20 Ultra Screen Replacement, Unfasten the lower midframe: step 21, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the five 3.9 mm-long screws securing the loudspeaker and lower midframe.
      Ask FixBot
    2. Samsung Galaxy S20 Ultra Screen Replacement, Remove the loudspeaker: step 22, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Remove the loudspeaker: step 22, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Remove the loudspeaker: step 22, image 3 of 3
      Buy
      • Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
      • Remove the loudspeaker and lower midframe.
      Ask FixBot
    1. Samsung Galaxy S20 Ultra Screen Replacement, Disconnect the display cable: step 23, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement, Disconnect the display cable: step 23, image 2 of 2
      • Use a spudger to pry up and disconnect the display cable.
      Ask FixBot
    2. Samsung Galaxy S20 Ultra Screen Replacement, Adhesive tip: step 24, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement, Adhesive tip: step 24, image 2 of 2
      • In the next several steps, you will heat and separate the black adhesive around the perimeter of the device.
      • The adhesive surrounding the long edges of the device is thin and will only require you to insert the pick 5 mm to separate.
      • Note that along the top edge of the phone, the adhesive runs significantly farther from the device's edge. You will need to insert your pick deeper here to fully seperate the adhesive.
      Ask FixBot
    3. Samsung Galaxy S20 Ultra Screen Replacement, Separate the perimeter adhesive: step 25, image 1 of 1
      • Heat an iOpener and apply it to the top edge of the display for two minutes.
      Ask FixBot
    4. Samsung Galaxy S20 Ultra Screen Replacement: step 26, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement: step 26, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement: step 26, image 3 of 3
      • Apply a suction cup to the display glass, as close to the center of the top edge as possible.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Pull on the suction cup with strong, steady force to create a gap between the display glass and the frame.
      • Insert the point of an opening pick into the gap in the center of the earpiece speaker notch, working it downwards underneath the display.
      • Ensure the pick slides over the front-facing camera and is not pushing against it.
      • Due to the stubborn adhesive, this may take multiple attempts of reheating with the iOpener and lifting with the suction cup before you get it right.
      • Leave your pick in the seam to prevent the adhesive from reasealing.
      Ask FixBot
    5. Samsung Galaxy S20 Ultra Screen Replacement: step 27, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement: step 27, image 2 of 2
      • Insert a second pick into the same gap and slide it to the top left corner of the display to slice the adhesive.
      Ask FixBot
    6. Samsung Galaxy S20 Ultra Screen Replacement: step 28, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement: step 28, image 2 of 2
      • Insert a third pick into the center gap and slide it to the top right corner of the display to slice the adhesive.
      • Leave your pick in the seam to prevent the adhesive from resealing.
      Ask FixBot
    7. Samsung Galaxy S20 Ultra Screen Replacement: step 29, image 1 of 2 Samsung Galaxy S20 Ultra Screen Replacement: step 29, image 2 of 2
      • Slide the center pick further into the device's top edge to slice the adhesive surrounding the earpiece and front-facing camera.
      • If the adhesive becomes difficult to separate, apply more heat and try again.
      • Don't insert the pick too far or you may lose the pick under the screen assembly.
      • Remove the center pick.
      Ask FixBot
    8. Samsung Galaxy S20 Ultra Screen Replacement: step 30, image 1 of 1
      • Apply a heated iOpener to the right edge of the display for two minutes.
      Ask FixBot
    9. Samsung Galaxy S20 Ultra Screen Replacement: step 31, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement: step 31, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement: step 31, image 3 of 3
      • Insert an opening pick into the gap at the top right corner of the display.
      • Slide the pick down to the bottom right corner to slice the adhesive.
      • Insert a pick underneath the center of the screen's right edge to prevent the adhesive from resealing.
      Ask FixBot
    10. Samsung Galaxy S20 Ultra Screen Replacement: step 32, image 1 of 1
      • When you slice the adhesive around the perimeter of the device, watch out for the sensitive areas of the screen near the USB-C port.
      • There's no thick adhesive in this area, so insert your pick no more than 5 mm into the gap.
      Ask FixBot
    11. Samsung Galaxy S20 Ultra Screen Replacement: step 33, image 1 of 1
      • Apply a heated iOpener to the left edge of the display for two minutes.
      Ask FixBot
    12. Samsung Galaxy S20 Ultra Screen Replacement: step 34, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement: step 34, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement: step 34, image 3 of 3
      • Insert a pick into the gap at the top left corner of the display.
      • Slide the pick down to the bottom left corner to slice the adhesive.
      • Insert a pick underneath the center of the screen's left edge to prevent the adhesive from resealing.
      Ask FixBot
    13. Samsung Galaxy S20 Ultra Screen Replacement, Separate the interior adhesive: step 35, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Separate the interior adhesive: step 35, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Separate the interior adhesive: step 35, image 3 of 3
      • In this step, you will apply isopropyl alcohol behind the screen to release the clear adhesive towards the bottom center of the device.
      • Apply high concentration (over 90%) isopropyl alcohol behind the display as close to the clear adhesive (marked red) as possible.
      • Tilt the device as you apply the alcohol to help it penetrate the adhesive underneath the lower portion of the display.
      • After you apply the alcohol, continue tilting the bottom of the phone down for two to three minutes to help the alcohol penetrate further.
      Ask FixBot
    14. Samsung Galaxy S20 Ultra Screen Replacement: step 36, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement: step 36, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement: step 36, image 3 of 3
      • Slowly insert a spudger under the top edge of the screen to separate the clear adhesive.
      • Insert the spudger until the clear adhesive is completely separated.
      Ask FixBot
    15. Samsung Galaxy S20 Ultra Screen Replacement, Remove the screen: step 37, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Remove the screen: step 37, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Remove the screen: step 37, image 3 of 3
      • Remove the display from the frame.
      • There still may be a small strip of adhesive at the bottom edge of the phone, but it should release easily.
      • Take care to thread the display cable through the frame.
      • During reassembly, you will need to insert the display cable through the frame cutout before pressing the display into place. Do not insert the display cable before the new screen adhesive is applied.
      Ask FixBot
    16. Samsung Galaxy S20 Ultra Screen Replacement, Remove the old adhesive: step 38, image 1 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Remove the old adhesive: step 38, image 2 of 3 Samsung Galaxy S20 Ultra Screen Replacement, Remove the old adhesive: step 38, image 3 of 3
      Buy
      • Use tweezers to remove any remaining adhesive from the frame.
      • Use isopropyl alcohol and a lint-free cloth to thoroughly clean the frame's surface and prepare it for new adhesive. Wipe in one direction to avoid smearing.
      • During reassembly, follow this guide to install custom-cut adhesives for your device.
      Ask FixBot
After you've completed the repair, follow this guide to test your repair.
18 other people completed this guide.
Carsten Frauenheim
171,572 Reputation
441 Guides authored
3 Guide Comments
"Hinweis: Einige Ersatzdisplays sind schon in einem neuen Rahmen vorinstalliert. Du musst deshalb alle inneren Bauteile des Smartphones übertragen und einen neue Akku einsetzen." - genau das ist ja das Problem auf dem aktuellen Display-Markt (ebay usw.) - Welche Anleitung benötige ich also zum Übertragen der inneren Bauteile? (Habe ein gebrauchtes Display mit Glasbruch im Rahmen erstanden und denke nicht dass es sinnvoll ist, dieses herauszulösen, es könnte endgültig kaputt gehen)
Dirk O. - Reply Share
Svp je veux écran de Samsung Galaxy s 20 ultra écran
Gadoski Bilante - Reply Share
Is this dynamic AMOLED 2x?
Vincent Justin Pajara - Reply Share
Past 24 Hours: 22
Past 7 Days: 152
Past 30 Days: 600
All Time: 75,070
