Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement
    1. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Eject the SIM tray: step 1, image 1 of 2 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Eject the SIM tray: step 1, image 2 of 2
      • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
      • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
      • Press in firmly to eject the tray.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the SIM tray: step 2, image 1 of 2 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the SIM tray: step 2, image 2 of 2
      • Remove the SIM card tray.
      • The SIM card will fall out of the tray easily.
      • When you reinsert the SIM card, ensure that it is in the proper orientation relative to the tray.
      • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Heat the bottom edge: step 3, image 1 of 1
      • Unplug and power off your phone before you begin.
      • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the bottom edge adhesive: step 4, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the bottom edge adhesive: step 4, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the bottom edge adhesive: step 4, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken glass.
      • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
      • Insert the point of an opening pick into the gap.
      • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
      • If you are having trouble creating a gap, apply more heat to the edge and try again.
      • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 5, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 5, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 5, image 3 of 3
      • Slide the pick back and forth along the bottom edge to slice through the adhesive.
      • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
      • Leave your opening pick in the seam to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Heat the left edge: step 6, image 1 of 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Ask FixBot
    5. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the left edge adhesive: step 7, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the left edge adhesive: step 7, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the left edge adhesive: step 7, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
      • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
      • Due to tight tolerances, this may take multiple attempts.
      • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
      Ask FixBot
    6. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 8, image 1 of 2 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 8, image 2 of 2
      • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
      Ask FixBot
    7. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 9, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 9, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 9, image 3 of 3
      • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
      • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
      • Leave your pick under the left edge of the glass to prevent the adhesive from resealing.
      Ask FixBot
    8. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Heat the right edge: step 10, image 1 of 1
      • Apply a heated iOpener to the right edge of the back cover for two minutes.
      Ask FixBot
    9. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the right edge adhesive: step 11, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the right edge adhesive: step 11, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the right edge adhesive: step 11, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
      • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
      Ask FixBot
    10. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 12, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 12, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 12, image 3 of 3
      • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
      • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
      • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
      Ask FixBot
    11. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Heat the top edge: step 13, image 1 of 1
      • Apply a heated iOpener to the top edge of the back cover for two minutes.
      Ask FixBot
    12. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the top edge adhesive: step 14, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the top edge adhesive: step 14, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Separate the top edge adhesive: step 14, image 3 of 3
      • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
      • Gradually slide the pick from the right edge of the device around the top right corner.
      • Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
      • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
      Ask FixBot
    13. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the back cover: step 15, image 1 of 2 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the back cover: step 15, image 2 of 2
      Tool used on this step:
      Buy
      • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
      • Remove the back cover.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unfasten the motherboard bracket: step 16, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips #00 screwdriver to remove the six 4 mm-long screws securing the motherboard bracket.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unclip the motherboard bracket: step 17, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unclip the motherboard bracket: step 17, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unclip the motherboard bracket: step 17, image 3 of 3
      Buy
      • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
      • Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 18, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 18, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement: step 18, image 3 of 3
      • Gently tilt up the motherboard bracket so the orange battery connector is accessible.
      Ask FixBot
    4. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the battery: step 19, image 1 of 2 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the battery: step 19, image 2 of 2
      • Use a spudger to pry up and disconnect the battery connector.
      • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the wireless charging coil: step 20, image 1 of 2 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the wireless charging coil: step 20, image 2 of 2
      • Use a spudger to pry up and disconnect the wireless charging coil connector.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the wireless charging coil: step 21, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the wireless charging coil: step 21, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the wireless charging coil: step 21, image 3 of 3
      Buy
      • Use a pair of tweezers to gently peel the wireless charging coil away from the device.
      • Remove the wireless charging coil.
      • During reassembly, first reconnect the charging coil and battery connectors and refasten the motherboard bracket screws to properly align everything into place, then firmly press the coil pad down to adhere it.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unfasten the lower midframe: step 22, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the loudspeaker: step 23, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the loudspeaker: step 23, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the loudspeaker: step 23, image 3 of 3
      Buy
      • Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
      • Remove the loudspeaker and lower midframe.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the daughterboard: step 24, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the daughterboard: step 24, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the daughterboard: step 24, image 3 of 3
      • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the main flex cables: step 25, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the main flex cables: step 25, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the main flex cables: step 25, image 3 of 3
      • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the main flex cables: step 26, image 1 of 2 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the main flex cables: step 26, image 2 of 2
      • Gently peel up and remove the main and auxiliary flex cables.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the left 5G antenna: step 27, image 1 of 2 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the left 5G antenna: step 27, image 2 of 2
      • Pry up and disconnect the left 5G antenna cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the main display cable: step 28, image 1 of 2 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the main display cable: step 28, image 2 of 2
      • Use a spudger to pry up and disconnect the main display flex cable from the motherboard.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Reposition the display and 5G cables: step 29, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Reposition the display and 5G cables: step 29, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Reposition the display and 5G cables: step 29, image 3 of 3
      • Gently peel up and bend the display and left 5G antenna flex cables out of the way of the motherboard and battery.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unfasten the upper midframe: step 30, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the three 4 mm-long screws securing the upper midframe.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper midframe: step 31, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper midframe: step 31, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper midframe: step 31, image 3 of 3
      • Insert the point of a spudger into the notch on the right side of the upper midframe and pry up to release the clips holding it into place.
      • Remove the upper midframe.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the right 5G antenna: step 32, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the right 5G antenna: step 32, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the right 5G antenna: step 32, image 3 of 3
      Buy
      • Use a spudger to pry up and disconnect the right 5G antenna flex cable from the motherboard.
      • Use a pair of tweezers to bend the cable out of the way of the motherboard.
      Ask FixBot
    4. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the side button cable: step 33, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the side button cable: step 33, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the side button cable: step 33, image 3 of 3
      • Pry up and disconnect the side button flex cable from the motherboard.
      • Bend the cable out of the way of the motherboard.
      Ask FixBot
    5. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the front facing camera: step 34, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the front facing camera: step 34, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the front facing camera: step 34, image 3 of 3
      • Pry up and disconnect the front facing camera flex cable from the motherboard.
      Ask FixBot
    6. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the upper 5G antenna: step 35, image 1 of 2 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the upper 5G antenna: step 35, image 2 of 2
      • Pry up and disconnect the upper 5G antenna cable from the motherboard.
      Ask FixBot
    7. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper 5G antenna: step 36, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper 5G antenna: step 36, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the upper 5G antenna: step 36, image 3 of 3
      • Use the flat end of a spudger to pry up the corner of the 5G millimeter wave antenna module.
      • The module is secured with a bit of adhesive, but should release easily.
      • Remove the 5G antenna module.
      • During reassembly, reconnect the 5G antenna connector first to properly align it into place, then firmly press the rest of the antenna module down to adhere it.
      Ask FixBot
    8. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Unfasten the motherboard assembly: step 37, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two screws securing the motherboard and camera assembly.
      • One 4 mm-long screw
      • One 3.4 mm-long screw
      Ask FixBot
    9. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the motherboard assembly: step 38, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the motherboard assembly: step 38, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the motherboard assembly: step 38, image 3 of 3
      • Insert the flat end of a spudger into the bottom left corner of the motherboard assembly and pry up to release it from the phone body.
      • Remove the motherboard assembly.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the ultra wide camera module: step 39, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the ultra wide camera module: step 39, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the ultra wide camera module: step 39, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the ultrawide camera connector from the motherboard.
      • Remove the ultrawide camera module.
      • The module is lightly secured to the other cameras' frame via a small post, but you should be able to wiggle it free easily.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the remaining cameras: step 40, image 1 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the remaining cameras: step 40, image 2 of 3 Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Disconnect the remaining cameras: step 40, image 3 of 3
      • Use a spudger to pry up and disconnect the telephoto and wide-angle camera connector from the motherboard.
      • Pry up and disconnect the depth sensor.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Rear-Facing Camera Module Replacement, Remove the rear facing camera module: step 41, image 1 of 1
      • Remove the remaining rear facing camera module.
      Ask FixBot
After you've completed the repair, follow this guide to test your repair.
8 other people completed this guide.
Tarun Thiruma
40,755 Reputation
133 Guides authored
1 Guide Comment
It is more complicated than I expected. Dang it Samsung. Thanks for making and sharing the guide! The tip about not pressing on the center of the press connectors/Lego connectors is important sounding!
I feel that removing the speaker module and disconnecting the ribbon cables from that bottom module may be unnecessary. Is that true?
In my mind it is only necessary to disconnect the ribbon cables from the motherboard to free the motherboard.
A X - Reply Share
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 90
All Time: 8,201
