Samsung Galaxy S20 Plus Battery Replacement
    1. Samsung Galaxy S20 Plus Battery Replacement, Heat the bottom edge: step 1, image 1 of 1
      • Unplug and power off your phone before you begin.
      • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Battery Replacement, Separate the bottom edge adhesive: step 2, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Separate the bottom edge adhesive: step 2, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Separate the bottom edge adhesive: step 2, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken glass.
      • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
      • Insert the point of an opening pick into the gap.
      • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
      • If you are having trouble creating a gap, apply more heat to the edge and try again.
      • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Battery Replacement: step 3, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement: step 3, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement: step 3, image 3 of 3
      • Slide the pick back and forth along the bottom edge to slice through the adhesive.
      • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
      • Leave your opening pick in the seam to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S20 Plus Battery Replacement, Heat the left edge: step 4, image 1 of 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Ask FixBot
    5. Samsung Galaxy S20 Plus Battery Replacement, Separate the left edge adhesive: step 5, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Separate the left edge adhesive: step 5, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Separate the left edge adhesive: step 5, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
      • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
      • Due to tight tolerances, this may take multiple attempts.
      • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
      Ask FixBot
    6. Samsung Galaxy S20 Plus Battery Replacement: step 6, image 1 of 2 Samsung Galaxy S20 Plus Battery Replacement: step 6, image 2 of 2
      • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
      Ask FixBot
    7. Samsung Galaxy S20 Plus Battery Replacement: step 7, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement: step 7, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement: step 7, image 3 of 3
      • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
      • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
      • Leave your pick under the left edge of the glass to prevent the adhesive from resealing.
      Ask FixBot
    8. Samsung Galaxy S20 Plus Battery Replacement, Heat the right edge: step 8, image 1 of 1
      • Apply a heated iOpener to the right edge of the back cover for two minutes.
      Ask FixBot
    9. Samsung Galaxy S20 Plus Battery Replacement, Separate the right edge adhesive: step 9, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Separate the right edge adhesive: step 9, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Separate the right edge adhesive: step 9, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
      • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
      Ask FixBot
    10. Samsung Galaxy S20 Plus Battery Replacement: step 10, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement: step 10, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement: step 10, image 3 of 3
      • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
      • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
      • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
      Ask FixBot
    11. Samsung Galaxy S20 Plus Battery Replacement, Heat the top edge: step 11, image 1 of 1
      • Apply a heated iOpener to the top edge of the back cover for two minutes.
      Ask FixBot
    12. Samsung Galaxy S20 Plus Battery Replacement, Separate the top edge adhesive: step 12, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Separate the top edge adhesive: step 12, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Separate the top edge adhesive: step 12, image 3 of 3
      • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
      • Gradually slide the pick from the right edge of the device around the top right corner.
      • Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
      • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
      Ask FixBot
    13. Samsung Galaxy S20 Plus Battery Replacement, Remove the back cover: step 13, image 1 of 2 Samsung Galaxy S20 Plus Battery Replacement, Remove the back cover: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
      • Remove the back cover.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Battery Replacement, Unfasten the motherboard bracket: step 14, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips #00 screwdriver to remove the six 4 mm-long screws securing the motherboard bracket.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Battery Replacement, Unclip the motherboard bracket: step 15, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Unclip the motherboard bracket: step 15, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Unclip the motherboard bracket: step 15, image 3 of 3
      Buy
      • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
      • Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Battery Replacement: step 16, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement: step 16, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement: step 16, image 3 of 3
      • Gently tilt up the motherboard bracket so the orange battery connector is accessible.
      Ask FixBot
    4. Samsung Galaxy S20 Plus Battery Replacement, Disconnect the battery: step 17, image 1 of 2 Samsung Galaxy S20 Plus Battery Replacement, Disconnect the battery: step 17, image 2 of 2
      • Use a spudger to pry up and disconnect the battery connector.
      • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Battery Replacement, Disconnect the wireless charging coil: step 18, image 1 of 2 Samsung Galaxy S20 Plus Battery Replacement, Disconnect the wireless charging coil: step 18, image 2 of 2
      • Use a spudger to pry up and disconnect the wireless charging coil connector.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Battery Replacement, Remove the wireless charging coil: step 19, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Remove the wireless charging coil: step 19, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Remove the wireless charging coil: step 19, image 3 of 3
      Buy
      • Use a pair of tweezers to gently peel the wireless charging coil away from the device.
      • Remove the wireless charging coil.
      • During reassembly, first reconnect the charging coil and battery connectors and refasten the motherboard bracket screws to properly align everything into place, then firmly press the coil pad down to adhere it.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Battery Replacement, Unfasten the lower midframe: step 20, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Battery Replacement, Remove the loudspeaker: step 21, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Remove the loudspeaker: step 21, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Remove the loudspeaker: step 21, image 3 of 3
      Buy
      • Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
      • Remove the loudspeaker and lower midframe.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Battery Replacement, Disconnect the daughterboard: step 22, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Disconnect the daughterboard: step 22, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Disconnect the daughterboard: step 22, image 3 of 3
      • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Battery Replacement, Disconnect the main flex cables: step 23, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Disconnect the main flex cables: step 23, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Disconnect the main flex cables: step 23, image 3 of 3
      • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Battery Replacement, Remove the main flex cables: step 24, image 1 of 2 Samsung Galaxy S20 Plus Battery Replacement, Remove the main flex cables: step 24, image 2 of 2
      • Gently peel up and remove the main and auxiliary flex cables.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Battery Replacement, Disconnect the left 5G antenna: step 25, image 1 of 2 Samsung Galaxy S20 Plus Battery Replacement, Disconnect the left 5G antenna: step 25, image 2 of 2
      • Pry up and disconnect the left 5G antenna cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Battery Replacement, Disconnect the main display cable: step 26, image 1 of 2 Samsung Galaxy S20 Plus Battery Replacement, Disconnect the main display cable: step 26, image 2 of 2
      • Use a spudger to pry up and disconnect the main display flex cable from the motherboard.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Battery Replacement, Reposition the display and 5G cables: step 27, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Reposition the display and 5G cables: step 27, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Reposition the display and 5G cables: step 27, image 3 of 3
      • Gently peel up and bend the display and left 5G antenna flex cables out of the way of the motherboard and battery.
      Ask FixBot
    1. Samsung Galaxy S20 Plus Battery Replacement, Apply isopropyl alcohol: step 28, image 1 of 3 Samsung Galaxy S20 Plus Battery Replacement, Apply isopropyl alcohol: step 28, image 2 of 3 Samsung Galaxy S20 Plus Battery Replacement, Apply isopropyl alcohol: step 28, image 3 of 3
      • Apply 1-2 drops of high concentration (over 90%) isopropyl alcohol to the gaps in between the frame and the edges of the battery.
      • Using too much alcohol can damage the display.
      • Wait one minute to allow the isopropyl alcohol to soften the adhesive.
      Ask FixBot
    2. Samsung Galaxy S20 Plus Battery Replacement, Lift the battery from its adhesive: step 29, image 1 of 2 Samsung Galaxy S20 Plus Battery Replacement, Lift the battery from its adhesive: step 29, image 2 of 2
      • Apply a suction handle to the center of the battery.
      • Brace the top and bottom of the device against your work surface with one hand and firmly pull up on the suction handle with the other.
      • The adhesive takes time and repeated pulls rather than strong force to loosen. Pull on the suction cup with steady force for 15 seconds at a time.
      • If the battery doesn't loosen, apply 1-2 drops of isopropyl alcohol along the top, left, and right edges, wait a minute, and pull again.
      • When the battery begins to lift from the device, proceed to the next step.
      Ask FixBot
    3. Samsung Galaxy S20 Plus Battery Replacement, Pry up the battery: step 30, image 1 of 2 Samsung Galaxy S20 Plus Battery Replacement, Pry up the battery: step 30, image 2 of 2
      • Do not proceed with this step until the battery is lifted enough to easily insert an opening pick underneath the battery. If the battery is still firmly glued into place, you risk piercing the battery with your pick and causing a dangerous thermal event.
      • Once the battery lifts, don't apply isopropyl alcohol, or it may seep into the fingerprint sensor and damage your screen.
      • Insert an opening pick underneath the bottom edge of the battery and twist to loosen the battery adhesive.
      Ask FixBot
    4. Samsung Galaxy S20 Plus Battery Replacement, Remove the battery: step 31, image 1 of 1
      • Remove the battery.
      • Peel up and/or scrape away any remaining battery adhesive before cleaning the battery well surface with isopropyl alcohol and a lint free cloth.
      • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
      • During reassembly, if your new battery doesn't come with pre-applied adhesive, apply some to the well. Then, firmly press the new battery into place.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      Ask FixBot
Follow this guide to perform a battery cycle reset, and calibrate your newly-installed battery.
30 other people completed this guide.
Tarun Thiruma
40,755 Reputation
133 Guides authored
14 Guide Comments
Do you need new adhesive to glue the front and back of the phone itself back together after replacing the battery?
Jennifer Hart - Reply Share
That is insane !!! I am replacing my Note 4 with an S20+. With the Note 4, one just opens the back, lifts the battery out and clicks in the new one. 10 seconds or less. I will NOT be trying to perform this 31 step, 30-60 minute replacement if the battery on my S20 needs replacing. Cheaper to replace the %#*@ phone. WTF were Samsung thinking???
thesilverbear - Reply Share
I don't know if the overseas version is different from the Korean model I have (it's probably the same), but I've heard stories from repair shops that the liquid crystal died because they used alcohol to remove the battery. In fact, after the replacement, the liquid crystal was slowly dying and then completely dead the next day. The only thing they said to do to remove the battery was to apply a lot of heat. Other than that, the rest of the steps seem to be fine. I just changed my phone to an S21+ because the liquid crystal was expensive. I signed up to try this. I hope everyone else has no problems replacing it...(it's not hard, except for the back plate and battery removal, which is a pain).
changmin lee - Reply Share
This happened to me unfortunately
Jean m - Reply Share
Me parece todo muy claro y un excelente contenido, pero quisiera saber la temperatura a la cual debe estar para retirar la cubierta, por ejemplo si utilizo una pistola de calor cual debe ser la temperatura ideal para trabajar en desamblar el dispositivo. Muchas gracias.
Estalin - Reply Share
Past 24 Hours: 24
Past 7 Days: 158
Past 30 Days: 680
All Time: 78,166
