Up to 20% off select tools
Samsung Galaxy S10+ Screen Replacement
Views: 175K
View statistics:
Past 24 Hours:
16
Past 7 Days:
138
Past 30 Days:
657
All Time:
174,601
Comments: 16
9 comments on steps, 7 guide comments.
Go to guide comments
Completed: 36
36 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to remove and replace a broken screen for your Samsung Galaxy S10+. This involves removing the back cover in order to disconnect the screen from the motherboard.
This guide shows how to destructively remove the screen while retaining the original frame.
The procedure uses photos from the Galaxy S10, so there may be some minor visual differences. They should not affect the overall guide procedure.
Video Overview
    1. Samsung Galaxy S10+ Screen Replacement, Heat the back cover: step 1, image 1 of 3 Samsung Galaxy S10+ Screen Replacement, Heat the back cover: step 1, image 2 of 3 Samsung Galaxy S10+ Screen Replacement, Heat the back cover: step 1, image 3 of 3
      • Unplug and power off your phone before you begin.
      • Heat an iOpener and apply it to the back cover's right edge for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      • As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
      Ask FixBot
    2. Samsung Galaxy S10+ Screen Replacement, Create an opening gap: step 2, image 1 of 3 Samsung Galaxy S10+ Screen Replacement, Create an opening gap: step 2, image 2 of 3 Samsung Galaxy S10+ Screen Replacement, Create an opening gap: step 2, image 3 of 3
      • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
      • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
      • Insert the point of an opening pick into the gap.
      • Due to tight tolerances, this may take multiple attempts.
      • If you are having trouble creating a gap, your best bet is to apply more heat to the edge and try the previous step again.
      • You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
      • Do not apply excessive force with the pick, or you will risk cracking the back cover glass.
      Ask FixBot
    3. Samsung Galaxy S10+ Screen Replacement: step 3, image 1 of 3 Samsung Galaxy S10+ Screen Replacement: step 3, image 2 of 3 Samsung Galaxy S10+ Screen Replacement: step 3, image 3 of 3
      • Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
      • Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
      • Press the edge of an opening tool into the seam between the back cover and the frame.
      • Slide the opening tool back and forth along the seam a few times.
      Ask FixBot
    4. Samsung Galaxy S10+ Screen Replacement, Slice through the adhesive: step 4, image 1 of 3 Samsung Galaxy S10+ Screen Replacement, Slice through the adhesive: step 4, image 2 of 3 Samsung Galaxy S10+ Screen Replacement, Slice through the adhesive: step 4, image 3 of 3
      • Slide the opening pick along the edge of the phone, slicing through the adhesive.
      • Do not attempt to slice the adhesive holding the corners down before applying heat. If you do, you may crack the back cover.
      • Leave a pick in the seam to prevent the adhesive from re-sealing.
      Ask FixBot
    5. Samsung Galaxy S10+ Screen Replacement: step 5, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the phone for two minutes.
      Ask FixBot
    6. Samsung Galaxy S10+ Screen Replacement: step 6, image 1 of 2 Samsung Galaxy S10+ Screen Replacement: step 6, image 2 of 2
      • Insert an opening pick into the right edge near the bottom right corner.
      • Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
      • If the cutting feels difficult, re-apply heat to the edge before continuing.
      • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
      Ask FixBot
    7. Samsung Galaxy S10+ Screen Replacement: step 7, image 1 of 3 Samsung Galaxy S10+ Screen Replacement: step 7, image 2 of 3 Samsung Galaxy S10+ Screen Replacement: step 7, image 3 of 3
      • Continue heating and slicing around the remaining edges of the phone.
      • When cutting around corners, be sure that the corner is thoroughly heated.
      Ask FixBot
    8. Samsung Galaxy S10+ Screen Replacement: step 8, image 1 of 3 Samsung Galaxy S10+ Screen Replacement: step 8, image 2 of 3 Samsung Galaxy S10+ Screen Replacement: step 8, image 3 of 3
      • Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
      • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
      • Remove the back cover.
      • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
      • Follow this guide to reinstall the back cover, transfer and install the camera bezel, and replace the adhesive.
      Ask FixBot
    1. Samsung Galaxy S10+ Screen Replacement, Remove the midframe: step 9, image 1 of 1
      • Remove the nine 4 mm Phillips screws securing the top midframe to the phone.
      Ask FixBot
    2. Samsung Galaxy S10+ Screen Replacement: step 10, image 1 of 2 Samsung Galaxy S10+ Screen Replacement: step 10, image 2 of 2
      • The midframe is still held in place by a few plastic clips around the edge.
      • Insert the point of a spudger into the notch on the right edge of the midframe, near the Bixby button.
      • Pry up to loosen the midframe from the phone.
      Ask FixBot
    3. Samsung Galaxy S10+ Screen Replacement: step 11, image 1 of 2 Samsung Galaxy S10+ Screen Replacement: step 11, image 2 of 2
      • Insert the point of a spudger into the notch on the left edge of the phone, located near the power button.
      Ask FixBot
    4. Samsung Galaxy S10+ Screen Replacement: step 12, image 1 of 1
      Ask FixBot
    1. Samsung Galaxy S10+ Screen Replacement, Disconnect the battery: step 13, image 1 of 3 Samsung Galaxy S10+ Screen Replacement, Disconnect the battery: step 13, image 2 of 3 Samsung Galaxy S10+ Screen Replacement, Disconnect the battery: step 13, image 3 of 3
      • Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
      • Pry upwards to disconnect the connector from its socket.
      • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
      • Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
      Ask FixBot
    1. Samsung Galaxy S10+ Screen Replacement, Remove the loudspeaker: step 14, image 1 of 1
      • Remove the seven 4 mm Phillips screws securing the lower midframe to the phone.
      Ask FixBot
    2. Samsung Galaxy S10+ Screen Replacement: step 15, image 1 of 2 Samsung Galaxy S10+ Screen Replacement: step 15, image 2 of 2
      • Insert the point of a spudger in the notch near the bottom right corner of the lower midframe. It is marked by a small triangle.
      • Pry up to release the midframe from the phone.
      Ask FixBot
    3. Samsung Galaxy S10+ Screen Replacement: step 16, image 1 of 3 Samsung Galaxy S10+ Screen Replacement: step 16, image 2 of 3 Samsung Galaxy S10+ Screen Replacement: step 16, image 3 of 3
      • Grasp the loosened end of the midframe with your fingers and lift upwards slowly.
      • Wiggle the midframe slightly to help release the remaining edge clips.
      • Remove the lower midframe. The loudspeaker is built into the lower midframe.
      • To reinstall the lower midframe, align the midframe's bottom edge to to the phone edge, and press it into place.
      Ask FixBot
    1. Samsung Galaxy S10+ Screen Replacement, Disconnect the screen: step 17, image 1 of 2 Samsung Galaxy S10+ Screen Replacement, Disconnect the screen: step 17, image 2 of 2
      • Use the flat edge of a spudger to pry up and disconnect the display connector from its motherboard socket.
      Ask FixBot
    2. Samsung Galaxy S10+ Screen Replacement, Slice through the screen adhesive: step 18, image 1 of 1
      • Flip the phone over so that the display is facing up.
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the internal battery is susceptible to heat damage.
      Ask FixBot
    3. Samsung Galaxy S10+ Screen Replacement: step 19, image 1 of 3 Samsung Galaxy S10+ Screen Replacement: step 19, image 2 of 3 Samsung Galaxy S10+ Screen Replacement: step 19, image 3 of 3
      • Apply a suction cup to the heated edge of the display.
      • Pull up on the suction up with strong, steady force to create a gap.
      • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
      Ask FixBot
    4. Samsung Galaxy S10+ Screen Replacement: step 20, image 1 of 3 Samsung Galaxy S10+ Screen Replacement: step 20, image 2 of 3 Samsung Galaxy S10+ Screen Replacement: step 20, image 3 of 3
      • Slide the opening pick along the right edge to slice through the adhesive.
      • Leave the opening pick in the corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Samsung Galaxy S10+ Screen Replacement: step 21, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the display for one minute.
      Ask FixBot
    6. Samsung Galaxy S10+ Screen Replacement: step 22, image 1 of 2 Samsung Galaxy S10+ Screen Replacement: step 22, image 2 of 2
      • Slide an opening pick along the bottom edge to slice through the adhesive.
      Ask FixBot
    7. Samsung Galaxy S10+ Screen Replacement: step 23, image 1 of 3 Samsung Galaxy S10+ Screen Replacement: step 23, image 2 of 3 Samsung Galaxy S10+ Screen Replacement: step 23, image 3 of 3
      • Repeat the heating and slicing procedure for the remaining display sides.
      Ask FixBot
    8. Samsung Galaxy S10+ Screen Replacement: step 24, image 1 of 3 Samsung Galaxy S10+ Screen Replacement: step 24, image 2 of 3 Samsung Galaxy S10+ Screen Replacement: step 24, image 3 of 3
      • Use an opening pick to pry open and slice through any remaining adhesive.
      Ask FixBot
    9. Samsung Galaxy S10+ Screen Replacement, Remove the screen: step 25, image 1 of 2 Samsung Galaxy S10+ Screen Replacement, Remove the screen: step 25, image 2 of 2
      • Thread the display panel connector through the frame.
      • If you're having trouble, you can choose to cut the display panel cable in order to remove the display.
      Ask FixBot
    10. Samsung Galaxy S10+ Screen Replacement: step 26, image 1 of 2 Samsung Galaxy S10+ Screen Replacement: step 26, image 2 of 2
      • Remove the screen.
      • If you are using a custom-cut adhesive, follow this guide for instructions on how to remove the old adhesive and attach the replacement screen.
      • If you're using Tesa tape to reattach the screen, follow this guide.
      Ask FixBot
After you've completed the repair, follow this guide to test your repair.
36 other people completed this guide.
Author
with
Arthur Shi
354,419 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
7 Guide Comments
Couldn't get the screen off bc the adhesive was too strong and took it to a local repair shop to see if they could get it off for me. Apparently a typical screen replacement for this is to replace the whole frame alongside the screen and that typically by doing it this way would just straight up destroy the screen and is extremely difficult to do.
amooosed - Reply Share
Would the fingerprint comes with the new screen?
César Josué Espinosa - Reply Share
I can't touch the screen so how do I power off my phone?
Ayaan Jamil - Reply Share
keep holding the power button even after the menu pops up. you can also try a mouse through OTG
Steady Fredd - Reply Share
Where can i purchase just the replacement screen ? all i can find is screen and frame
Kenny Keefer - Reply Share
Past 24 Hours: 16
Past 7 Days: 138
Past 30 Days: 657
All Time: 174,601
