Samsung Galaxy S10+ SIM/MicroSD Card Replacement
    1. Samsung Galaxy S10+ SIM/MicroSD Card Replacement, SIM/MicroSD Card: step 1, image 1 of 3 Samsung Galaxy S10+ SIM/MicroSD Card Replacement, SIM/MicroSD Card: step 1, image 2 of 3 Samsung Galaxy S10+ SIM/MicroSD Card Replacement, SIM/MicroSD Card: step 1, image 3 of 3
      • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
      • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
      • Press firmly to eject the tray.
      • Remove the SIM card tray.
      • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
      Ask FixBot
After you've completed the repair, follow this guide to test your repair.
6 other people completed this guide.
Arthur Shi
351,101 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
6 Guide Comments
I have the same question. I'm sure you've taken enough of these apart for repair. (Galaxy s10's and pluses) Can you guys see what's at the end of the hole? Any research that I've found says that the hole is straight and comes to an end and the microphone is 90° to that, so it cannot be poked by the pin, is this true? (I hope it is, and to give us peace of mind!) I don't want to have to take apart my phone. I'm sure there are lots people out here that have poked this %#*@ hole and are freaking that we have wrecked a $1600.00 phone! And then, if you could kindly please then post an answer plainly in the instructions for the SIM installation somewhere in the body of this installation article. I have seen no definitive answer to this mistake in any other article that I've read. Ifixit is the premiere repair company for phones, this should be solved here. Thanks in advance I hope. I've used your services multiple times in the past for various breakages of our family phones in Chicago, you've always been great.
Lin Car - Reply Share
Hi Lin,
Please look for the answer in step 1’s comments.
Arthur Shi - Reply Share
I inserted the pin in the microphone hole first. Thank you for setting my mind at ease that I didn’t damage anything,
Craig Thielke - Reply Share
Where can you order a OEM SM-G975U Prism Blue sim card tray from? I want a genuine Samsung replacement.
MarkC 609 - Reply Share
well we have a dilemma here my s10+ ihas got a micro sim card stuck in the sd slot see if you can get it out by taking the phone apartand also ill need directions to you
Kevin Gaiser - Reply Share
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 143
All Time: 18,772
