Samsung Galaxy S III Battery Replacement
    1. Samsung Galaxy S III Battery Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy S III Battery Replacement, Rear Case: step 1, image 2 of 2
      • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
      • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
      • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
      Ask FixBot
    2. Samsung Galaxy S III Battery Replacement: step 2, image 1 of 2 Samsung Galaxy S III Battery Replacement: step 2, image 2 of 2
      • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
      Ask FixBot
    3. Samsung Galaxy S III Battery Replacement: step 3, image 1 of 2 Samsung Galaxy S III Battery Replacement: step 3, image 2 of 2
      • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
      Ask FixBot
    4. Samsung Galaxy S III Battery Replacement: step 4, image 1 of 2 Samsung Galaxy S III Battery Replacement: step 4, image 2 of 2
      • Pry along the top right side, and continue prying down the right side of the rear case.
      Ask FixBot
    5. Samsung Galaxy S III Battery Replacement: step 5, image 1 of 2 Samsung Galaxy S III Battery Replacement: step 5, image 2 of 2
      • Lift up and remove the rear case from the phone.
      • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
      Ask FixBot
    1. Samsung Galaxy S III Battery Replacement, Battery: step 6, image 1 of 2 Samsung Galaxy S III Battery Replacement, Battery: step 6, image 2 of 2
      • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
      • Wedge a plastic opening tool into the small notch above the battery.
      • Pry the battery up out of its recess.
      Ask FixBot
    2. Samsung Galaxy S III Battery Replacement: step 7, image 1 of 2 Samsung Galaxy S III Battery Replacement: step 7, image 2 of 2
      • Remove the battery.
      Ask FixBot
92 other people completed this guide.
3 Guide Comments
Do I have to wait after replacing it or can I use my phone right away? If so how long
ivon200021 - Reply Share
Super simple. Thanks!
bmwherry - Reply Share
I don't get it why you insist it takes at least 2 minutes. I've done it in 5 seconds multiple times using fingers and no tabs have ever broken off. It literally takes 5-10 seconds, you just pull it off.
Krzeszny - Reply Share
Past 24 Hours: 15
Past 7 Days: 41
Past 30 Days: 157
All Time: 67,219
