Samsung Galaxy S II Screen Replacement
    1. Samsung Galaxy S II Screen Replacement, Remove back cover: step 1, image 1 of 1
      • Gently remove the back cover starting from the slot given on the right side.
      Ask FixBot
    2. Samsung Galaxy S II Screen Replacement, Remove battery: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the battery from the slot.
      • Carefully place the battery away from some hot object or fire.
      Ask FixBot
    3. Samsung Galaxy S II Screen Replacement, Remove back case screws: step 3, image 1 of 1
      • Use a magnetic philips #0 head screw driver to open the 7 x 1/16 in (1.6 mm) philips head screws shown in the image.
      • Place the screws carefully in a box.
      Ask FixBot
    4. Samsung Galaxy S II Screen Replacement: step 4, image 1 of 3 Samsung Galaxy S II Screen Replacement: step 4, image 2 of 3 Samsung Galaxy S II Screen Replacement: step 4, image 3 of 3
      • Gently unlock the snap locks starting from the top left corner and progressing along the perimeter to remove the back case.
      • To unlock the snaps, apply force close to the snap in order to avoid cracking of the plastic cover.
      • Remove the plastic cover carefully and place on the white paper.
      Ask FixBot
    5. Samsung Galaxy S II Screen Replacement: step 5, image 1 of 2 Samsung Galaxy S II Screen Replacement: step 5, image 2 of 2
      • Use a screwdriver or another pointed tool to disconnect the screen connector.
      • Lift the cable out of the slot.
      • Gently handle the cable to avoid damage to the cable or the connector.
      Ask FixBot
    6. Samsung Galaxy S II Screen Replacement: step 6, image 1 of 2 Samsung Galaxy S II Screen Replacement: step 6, image 2 of 2
      • Remove the connector for the speaker and audio jack carefully.
      • Gently lift the cable to avoid damage to the cable or the connector.
      Ask FixBot
    7. Samsung Galaxy S II Screen Replacement: step 7, image 1 of 3 Samsung Galaxy S II Screen Replacement: step 7, image 2 of 3 Samsung Galaxy S II Screen Replacement: step 7, image 3 of 3
      • Use a screwdriver to gently lift the speaker which is fixed to the base with double side tape.
      • Gently lift the earpiece using a flat screwdriver.
      Ask FixBot
    8. Samsung Galaxy S II Screen Replacement: step 8, image 1 of 3 Samsung Galaxy S II Screen Replacement: step 8, image 2 of 3 Samsung Galaxy S II Screen Replacement: step 8, image 3 of 3
      • Unplug the secondary camera connector carefully and lift the cable.
      • Then unplug the connector that receives the input from the screen.
      • Remove the connection for the charging port using a screw driver.
      • Handle carefully to avoid tearing off the cable.
      Ask FixBot
    9. Samsung Galaxy S II Screen Replacement: step 9, image 1 of 2 Samsung Galaxy S II Screen Replacement: step 9, image 2 of 2
      • Remove the two 1.6 mm black head screws using the Phillips #00 screwdriver.
      Ask FixBot
    10. Samsung Galaxy S II Screen Replacement: step 10, image 1 of 2 Samsung Galaxy S II Screen Replacement: step 10, image 2 of 2
      • Disconnect the antennae from both the ends by removing the connections using flat screwdriver.
      • Carefully pull out the antennae cable from the slot.
      Ask FixBot
    11. Samsung Galaxy S II Screen Replacement: step 11, image 1 of 2 Samsung Galaxy S II Screen Replacement: step 11, image 2 of 2
      • Gently peel off the power button fixed with double adhesive tape.
      • Carefully lift the button out of the slot.
      • Try to keep the double side tape on the button and handle the cable carefully to avoid tearing the ribbon.
      Ask FixBot
    12. Samsung Galaxy S II Screen Replacement, Disassemble volume up/down button: step 12, image 1 of 2 Samsung Galaxy S II Screen Replacement, Disassemble volume up/down button: step 12, image 2 of 2
      • Repeat the same procedure from step 15 to remove the volume up down button.
      Ask FixBot
    13. Samsung Galaxy S II Screen Replacement, Remove main board: step 13, image 1 of 2 Samsung Galaxy S II Screen Replacement, Remove main board: step 13, image 2 of 2
      • Now the main board is free. Carefully lift it up and place on the workbench gently.
      Ask FixBot
    14. Samsung Galaxy S II Screen Replacement, Lift charging port connecting cable: step 14, image 1 of 2 Samsung Galaxy S II Screen Replacement, Lift charging port connecting cable: step 14, image 2 of 2
      • Peel off the ribbon cable connecting the charging port and microphone by hand.
      Ask FixBot
    15. Samsung Galaxy S II Screen Replacement, Unscrew charging module: step 15, image 1 of 1
      • Remove the two 2.0 mm screws using the Phillips #0 screwdriver.
      Ask FixBot
    16. Samsung Galaxy S II Screen Replacement, Disassemble charging port module: step 16, image 1 of 3 Samsung Galaxy S II Screen Replacement, Disassemble charging port module: step 16, image 2 of 3 Samsung Galaxy S II Screen Replacement, Disassemble charging port module: step 16, image 3 of 3
      • Lift the microphone gently.
      • Lift the board out from the metal casing and place on the workbench.
      Ask FixBot
    17. Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: step 17, image 1 of 3 Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: step 17, image 2 of 3 Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: step 17, image 3 of 3
      • Finally push the screen out applying force through the screwdriver at the highlighted locations.
      • Take out the screen, clean the remaining double side tape and adhesive.
      • Install the new screen and follow the same steps in reverse order to re assemble the phone.
      Ask FixBot
3 other people completed this guide.
Bader
337 Reputation
1 Guide authored
1 Guide Comment
My Samsung Galaxy s2 is an AT&T phone
Anthony Godoy - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 112
All Time: 3,535
