Samsung Galaxy S II Front Glass/Digitizer Replacement
Video Overview
    1. Samsung Galaxy S II Front Glass/Digitizer Replacement, Front Glass and Digitizer: step 1, image 1 of 2 Samsung Galaxy S II Front Glass/Digitizer Replacement, Front Glass and Digitizer: step 1, image 2 of 2
      • We have a Samsung Galaxy S II with broken screen.
      Ask FixBot
    2. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 2, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 2, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 2, image 3 of 3
      • Remove your battery, the SIM card and the SD card.
      • Remove the 7 screws highlighted in red.
      Ask FixBot
    3. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 3, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 3, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 3, image 3 of 3
      • Use a plastic tool to remove the rear housing.
      Ask FixBot
    4. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 4, image 1 of 2 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 4, image 2 of 2
      • The mother board is held by 2x screws. Remove them.
      Ask FixBot
    5. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 5, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 5, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 5, image 3 of 3
      • Remove the cables that are highlighted in red, before continuing to the screen.
      Ask FixBot
    6. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 6, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 6, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 6, image 3 of 3
      • Release the side buttons. The arrow will point you to where they are.
      Ask FixBot
    7. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 7, image 1 of 2 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 7, image 2 of 2
      • Careful release the motherboard from it's housing.
      Ask FixBot
    8. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 8, image 1 of 2 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 8, image 2 of 2
      • At this moment if you have touch screen with LCD and frame like spare part you are ready for replacing.
      • We will continue with disassembling LCD and Touch from the frame. Now preheat it before removing!
      • Use a hot air to soften the adhesive enough to remove the glass.
      Ask FixBot
    9. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 9, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 9, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 9, image 3 of 3
      • With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame.
      Ask FixBot
    10. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 10, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 10, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 10, image 3 of 3
      • Be careful with the menu buttons flex cable in the bottom side of the touchscreen. You must release it before separating the digitizer from the frame.
      Ask FixBot
    11. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 11, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 11, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 11, image 3 of 3
      • Now, use a suction tool to remove the screen from it's housing. Be careful when doing this, to prevent possible injury.
      Ask FixBot
    12. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 12, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 12, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 12, image 3 of 3
      • Clean the frame from the remains of tape.
      Ask FixBot
    13. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 13, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 13, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 13, image 3 of 3
      • Test the new spare part before reassembling.
      Ask FixBot
    14. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 14, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 14, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 14, image 3 of 3
      • Install the LCD&Digitiser on it's housing.
      • Many times the spare parts come without adhesive tape. In this situation you'll need to install double sided adhesive tape yourself. Also you can easy find adhesive sticker exactly for the model.
      Ask FixBot
    15. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 15, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 15, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 15, image 3 of 3
      • To reassemble your device, follow these instructions in reverse order.
      Ask FixBot
32 other people completed this guide.
ZFix
197,534 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
334 Members
7,859 Guides authored
9 Guide Comments
I attempted to replace the display glass alone on a Virgin Mobile Galaxy SII, and was unsuccessful. Removing the Glass from the Digitizer proved to be extremely difficult. It seems as if the Virgin Mobile version of the SII is not meant for repair, so easily.
Edward Weissbard - Reply Share
Yes, removing the glass is very difficult and you must have some experience from before.
ZFix - Reply Share
To moderators: please un-archive this guide: there's no replacement or "updated version of the guide" among the current guides.
yurkennis - Reply Share
To moderators :
please there is a photo of a babe in the video tutorial and in the photo tutorial, not for children.
Frederic Morelli - Reply Share
how much the cost in replacement display with fame.....samsung galaxy s2
Bhola Shrestha - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 68
All Time: 100,071
