Samsung Galaxy S Blaze Volume Rocker Replacement
    1. Samsung Galaxy S Blaze Volume Rocker  Replacement, Volume Rocker: step 1, image 1 of 1
      • Start by removing the back plate to expose the battery by pulling the back and front plates apart.
      Ask FixBot
    2. Samsung Galaxy S Blaze Volume Rocker  Replacement: step 2, image 1 of 1
      • Remove the battery from the device and set aside.
      Ask FixBot
    3. Samsung Galaxy S Blaze Volume Rocker  Replacement: step 3, image 1 of 2 Samsung Galaxy S Blaze Volume Rocker  Replacement: step 3, image 2 of 2
      • Using a Phillips Head Screwdriver size 00. Remove all eight 4mm screws from the frame.
      • The eight screws are all the same size.
      Ask FixBot
    4. Samsung Galaxy S Blaze Volume Rocker  Replacement: step 4, image 1 of 1
      • Remove the frame from the phone by prying it off with the iFixit blue plastic opening tool.
      • Work around the phone with the tool until the frame is off.
      • You may need to use a bit of force to pry off the frame.
      Ask FixBot
    5. Samsung Galaxy S Blaze Volume Rocker  Replacement: step 5, image 1 of 2 Samsung Galaxy S Blaze Volume Rocker  Replacement: step 5, image 2 of 2
      • The volume rocker is held into the frame by two small prongs.
      • Carefully unhook the prongs from the frame by pulling to the side and remove the volume rocker.
      • The prongs on the volume rocker look like this.
      Ask FixBot
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Jake Best
264 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 96
All Time: 873
