Samsung Galaxy R Front Facing Camera Replacement
    1. Samsung Galaxy R Front Facing Camera Replacement, Rear Case: step 1, image 1 of 3 Samsung Galaxy R Front Facing Camera Replacement, Rear Case: step 1, image 2 of 3 Samsung Galaxy R Front Facing Camera Replacement, Rear Case: step 1, image 3 of 3
      • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
      • Gently pry apart the rear case from the midframe and remove.
      Ask FixBot
    1. Samsung Galaxy R Front Facing Camera Replacement, Battery: step 2, image 1 of 3 Samsung Galaxy R Front Facing Camera Replacement, Battery: step 2, image 2 of 3 Samsung Galaxy R Front Facing Camera Replacement, Battery: step 2, image 3 of 3
      • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
      • Gently pry the battery from the back of the phone.
      Ask FixBot
    1. Samsung Galaxy R Front Facing Camera Replacement, Remove screws: step 3, image 1 of 2 Samsung Galaxy R Front Facing Camera Replacement, Remove screws: step 3, image 2 of 2
      • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
      • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
      Ask FixBot
    2. Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: step 4, image 1 of 3 Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: step 4, image 2 of 3 Samsung Galaxy R Front Facing Camera Replacement, Front Facing Camera: step 4, image 3 of 3
      • The front facing camera is located in the top right corner of the back of the phone.
      • To remove the camera, gently pull until it detaches from the motherboard.
      Ask FixBot
2 other people completed this guide.
Keon Horahan
874 Reputation
6 Guides authored
Clemson, Team 3-3, Benson Fall 2014 Member of Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 110
All Time: 890
