Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
101
All Time:
727
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
If the buttons are jammed, loose or damaged if can be frustrating trying to use the phone. This guide will show you how to replace any of the buttons in about 10-15 minutes.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement, Volume, Camera, & Power Buttons: step 1, image 1 of 1
      • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
      Ask FixBot
    2. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: step 2, image 1 of 1
      • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
      Ask FixBot
    3. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: step 3, image 1 of 1
      • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    4. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: step 4, image 1 of 1
      • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
      • The secondary rear panel houses the camera lens and speaker assembly,
      • The metal trim of the headphone jack may come loose during this process.
      Ask FixBot
    5. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: step 5, image 1 of 1
      • Using the spudger, gently pry upward on the motherboard by the right side.
      • Motherboard is connected to shield plate with ribbon cable.
      Ask FixBot
    6. Samsung Galaxy Prevail Volume, Camera, & Power Buttons Replacement: step 6, image 1 of 1
      • Remove the desired button by pushing inward with the spudger or disconnecting the rubber pin connections.
      Ask FixBot
Ricardo Zuloaga
537 Reputation
5 Guides authored
USF Tampa, Team 17-6, Blackwell Fall 2016 Member of USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 101
All Time: 727
