Samsung Galaxy Prevail Touch Screen Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
100
All Time:
1,261
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
By following this guide you should be able to fix issues with an unresponsive or cracked screen.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Samsung Galaxy Prevail Touch Screen Replacement, Touch Screen: step 1, image 1 of 1
      • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
      Ask FixBot
    2. Samsung Galaxy Prevail Touch Screen Replacement: step 2, image 1 of 1
      • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
      Ask FixBot
    3. Samsung Galaxy Prevail Touch Screen Replacement: step 3, image 1 of 1
      • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    4. Samsung Galaxy Prevail Touch Screen Replacement: step 4, image 1 of 1
      • Using the black spudger, carefully unhinge and pry the secondary rear panel , which houses the camera lens and speaker.
      • The metal trim of the headphone jack may come loose during this process.
      Ask FixBot
    5. Samsung Galaxy Prevail Touch Screen Replacement: step 5, image 1 of 1
      • Using the spudger, gently pry upward on the motherboard by the right side.
      • Motherboard is connected to shield plate with ribbon cable.
      Ask FixBot
    6. Samsung Galaxy Prevail Touch Screen Replacement: step 6, image 1 of 1
      • Using a spudger, carefully unhinge the gray shield plate by lifting upwards on the right side.
      • The shield plate will not be fully removed, it is attached to the front panel with a ribbon cable.
      Ask FixBot
    7. Samsung Galaxy Prevail Touch Screen Replacement: step 7, image 1 of 1
      • Using the spudger lift up the LCD screen and replace with the new screen.
      Ask FixBot
Ricardo Zuloaga
537 Reputation
5 Guides authored
USF Tampa, Team 17-6, Blackwell Fall 2016 Member of USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 100
All Time: 1,261
