Samsung Galaxy Prevail Rear Camera Lens Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
92
All Time:
736
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
Using this guide you will replace the camera lens fixing hardware related camera issues such as scratches or cracks.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Samsung Galaxy Prevail Rear Camera Lens Replacement, Rear Camera Lens: step 1, image 1 of 1
      • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
      Ask FixBot
    2. Samsung Galaxy Prevail Rear Camera Lens Replacement: step 2, image 1 of 1
      • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
      Ask FixBot
    3. Samsung Galaxy Prevail Rear Camera Lens Replacement: step 3, image 1 of 1
      • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    4. Samsung Galaxy Prevail Rear Camera Lens Replacement: step 4, image 1 of 1
      • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
      • The secondary rear panel houses the camera lens and speaker assembly,
      • The metal trim of the headphone jack may come loose during this process.
      Ask FixBot
    5. Samsung Galaxy Prevail Rear Camera Lens Replacement: step 5, image 1 of 1
      • Replace the secondary rear panel which has the camera lens attached.
      Ask FixBot
Ricardo Zuloaga
537 Reputation
5 Guides authored
USF Tampa, Team 17-6, Blackwell Fall 2016 Member of USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 92
All Time: 736
