Samsung Galaxy Prevail 2 Battery Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
106
All Time:
2,588
Comments: 3
3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
You may need to replace your battery if your current battery is damaged, or is not attaining power from an outlet. No background information is required.
Tools
  • Spudger
    4.9
    1. Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: step 1, image 1 of 3 Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: step 1, image 2 of 3 Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: step 1, image 3 of 3
      • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
      Ask FixBot
    2. Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: step 2, image 1 of 3 Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: step 2, image 2 of 3 Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: step 2, image 3 of 3
      • Gently pull the battery out of the phone.
      Ask FixBot
4 other people completed this guide.
Alexandra Hernandez
744 Reputation
3 Guides authored
USF Tampa, Team 14-4, Leahy Fall 2014 Member of USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Members
60 Guides authored
3 Guide Comments
I just replaced the battery about a month ago after turning phone off and the turned back on it stuck on screen with samsung and the other lights stayed on
lindabuhl5729 - Reply Share
Mine doing the same
Chuck Slagel - Reply Share
"To reassemble your device, follow these instructions in reverse order" seriously?! I mean even an idiot should know that!
illy - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 106
All Time: 2,588
