Samsung Galaxy Player 5.0 Battery Replacement
  1. Samsung Galaxy Player 5.0 Battery Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Player 5.0 Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the SD Memory Card before taking the device apart. Using the screwdriver, remove the 10mm Phillips screw that is near the SD Memory Card port.
  2. Samsung Galaxy Player 5.0 Battery Replacement: step 2, image 1 of 1
    • Remove the white caps, which are covering the screws that are located on either side of the charging port.
    • You may have to use a low heat blow dryer for 5 to 10 seconds, or other equivalent heat source to loosen the adhesive.
  3. Samsung Galaxy Player 5.0 Battery Replacement: step 3, image 1 of 2 Samsung Galaxy Player 5.0 Battery Replacement: step 3, image 2 of 2
    • Continue to unscrew the two 10mm Phillips Screws from the bottom of the device.
  4. Samsung Galaxy Player 5.0 Battery Replacement: step 4, image 1 of 1
    • Starting from the bottom and working around, use the prying tool to separate the front cover housing from the back cover housing.
    • You will hear a popping sound, indicating the separation.
  5. Samsung Galaxy Player 5.0 Battery Replacement: step 5, image 1 of 2 Samsung Galaxy Player 5.0 Battery Replacement: step 5, image 2 of 2
    • Take the back housing cover off of the device.
  6. Samsung Galaxy Player 5.0 Battery Replacement: step 6, image 1 of 1
    • Using the prying tool, remove the tab that attaches the battery to the motherboard.
  7. Samsung Galaxy Player 5.0 Battery Replacement: step 7, image 1 of 3 Samsung Galaxy Player 5.0 Battery Replacement: step 7, image 2 of 3 Samsung Galaxy Player 5.0 Battery Replacement: step 7, image 3 of 3
    • Then remove the battery, using the prying tool in an upward motion.
    • There is an adhesive behind the battery but it is not strong.
  8. Samsung Galaxy Player 5.0 Battery Replacement: step 8, image 1 of 3 Samsung Galaxy Player 5.0 Battery Replacement: step 8, image 2 of 3 Samsung Galaxy Player 5.0 Battery Replacement: step 8, image 3 of 3
    • Insert the new battery into its position, and reconnect its tab onto the motherboard.
  9. Samsung Galaxy Player 5.0 Battery Replacement: step 9, image 1 of 1
    • Now put the rear housing cover on the device, starting from its bottom side, and snap the edges all the way around to close the device.
  10. Samsung Galaxy Player 5.0 Battery Replacement: step 10, image 1 of 3 Samsung Galaxy Player 5.0 Battery Replacement: step 10, image 2 of 3 Samsung Galaxy Player 5.0 Battery Replacement: step 10, image 3 of 3
    • Lastly, reinsert the screws at the bottom of the device, as well as the screw beside the SD Memory Card port.
Finish Line
2 other people completed this guide.
China Ayala
596 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 34
All Time: 3,915
