Up to 20% off select tools
Samsung Galaxy Note9 Display Assembly Replacement
Views: 65K
View statistics:
Past 24 Hours:
11
Past 7 Days:
88
Past 30 Days:
470
All Time:
65,144
Comments: 57
36 comments on steps, 21 guide comments.
Go to guide comments
Completed: 55
55 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 3 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the display assembly on your Samsung Galaxy Note9.
    1. Samsung Galaxy Note9 Display Assembly Replacement, Remove the S-Pen: step 1, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Remove the S-Pen: step 1, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Remove the S-Pen: step 1, image 3 of 3
      • Press in the bottom of the S-Pen until it clicks.
      • Release the S-Pen and it will self-eject.
      • Remove the S-Pen.
      Ask FixBot
    1. Samsung Galaxy Note9 Display Assembly Replacement, Eject the SIM card tray: step 2, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Eject the SIM card tray: step 2, image 2 of 2
      • Insert a SIM card eject tool straight into the hole in the SIM card tray.
      • Press to eject the SIM card tray.
      Ask FixBot
    2. Samsung Galaxy Note9 Display Assembly Replacement, Remove the SIM card tray: step 3, image 1 of 1
      • Remove the SIM card tray.
      • The SIM card will fall out of the tray easily.
      Ask FixBot
    1. Samsung Galaxy Note9 Display Assembly Replacement, Apply a heated iOpener: step 4, image 1 of 1
      • Power off your phone before beginning disassembly.
      • Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
      Ask FixBot
    2. Samsung Galaxy Note9 Display Assembly Replacement, Insert an opening pick: step 5, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Insert an opening pick: step 5, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Insert an opening pick: step 5, image 3 of 3
      • Apply a suction handle to the back cover.
      • Lift with a suction handle to create a gap between the back cover and the frame of the phone.
      • Insert an opening pick into the gap.
      • If the glass is badly cracked, cover it in packing tape to create a surface for the suction cup to adhere to.
      • If the adhesive won't budge, apply more heat, not excessive force. Too much force could break the glass.
      Ask FixBot
    3. Samsung Galaxy Note9 Display Assembly Replacement, Cut through the adhesive: step 6, image 1 of 1
      • Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
      • Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
      • If, at any point, the adhesive feels stubborn, apply more heat—not more force.
      Ask FixBot
    4. Samsung Galaxy Note9 Display Assembly Replacement, Slide the opening pick: step 7, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Slide the opening pick: step 7, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Slide the opening pick: step 7, image 3 of 3
      • Starting from the center, cut the adhesive up and down the right side with an opening pick.
      • Do not insert the pick more than halfway into the phone when cutting near the fingerprint sensor or cameras, or you risk damaging internal components.
      Ask FixBot
    5. Samsung Galaxy Note9 Display Assembly Replacement: step 8, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 8, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 8, image 3 of 3
      • Be careful near the corner, as the glass is very weak. Apply more heat at any time if the adhesive becomes stuck.
      • Leave an opening pick in the upper-right corner.
      • Use another opening pick to cut the adhesive around the bottom-right corner.
      • Leave that opening pick in the phone.
      Ask FixBot
    6. Samsung Galaxy Note9 Display Assembly Replacement: step 9, image 1 of 1
      • Use a heat gun or hair dryer or apply a heated iOpener to the left side of the rear panel for at three minutes to soften the adhesive underneath.
      Ask FixBot
    7. Samsung Galaxy Note9 Display Assembly Replacement: step 10, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 10, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 10, image 3 of 3
      • Be careful near the corners, as the glass is weakest there.
      • Insert an opening pick into the lower-left corner of the rear panel.
      • Using another opening pick, cut the adhesive along the left edge of the rear panel.
      • Don't insert an opening pick in more than halfway on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
      • It is fine if opening picks fall out as the back cover becomes separated.
      Ask FixBot
    8. Samsung Galaxy Note9 Display Assembly Replacement: step 11, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 11, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 11, image 3 of 3
      • Using the inserted opening pick, carefully cut the adhesive around the upper-left corner of the rear panel.
      • Finally, cut the last of the adhesive along the top of the phone.
      • Use an iOpener, hair dryer, or heat gun to apply more heat as needed where you are cutting the adhesive.
      Ask FixBot
    9. Samsung Galaxy Note9 Display Assembly Replacement: step 12, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement: step 12, image 2 of 2
      • Separate the right side of the rear cover first.
      • Tilt the cover up along the left edge to expose the fingerprint sensor ribbon cable.
      • Do not pull out the fingerprint sensor ribbon cable yet.
      • The fingerprint sensor cover might stay attached to the midframe.
      Ask FixBot
    10. Samsung Galaxy Note9 Display Assembly Replacement, Disconnect the fingerprint sensor: step 13, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Disconnect the fingerprint sensor: step 13, image 2 of 2
      • Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
      Ask FixBot
    11. Samsung Galaxy Note9 Display Assembly Replacement: step 14, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the back cover.
      • To re-install the back cover:
      • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
      • Turn on your phone and test your repair before installing new adhesive and resealing the phone.
      • Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
      Ask FixBot
    1. Careful: steps 15-18 are sourced from a guide that's marked as in-progress.
      Samsung Galaxy Note9 Display Assembly Replacement, Remove the upper midframe: step 15, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Remove the upper midframe: step 15, image 2 of 2
      • Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
      Ask FixBot
    2. Samsung Galaxy Note9 Display Assembly Replacement: step 16, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement: step 16, image 2 of 2
      • Insert the tip of a spudger into the upper-left corner of the upper midframe.
      • Pry the upper midframe out of the phone.
      • The upper midframe snaps into and out of place.
      Ask FixBot
    3. Samsung Galaxy Note9 Display Assembly Replacement: step 17, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 17, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 17, image 3 of 3
      • Peel the wireless charging coil off the battery starting with the left side.
      • The adhesive is weak but you can use an opening pick to cut it if necessary.
      • During reassembly start by snapping the midframe into place first before adhering the wireless charging coil.
      Ask FixBot
    4. Samsung Galaxy Note9 Display Assembly Replacement, Disconnect the battery: step 18, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Disconnect the battery: step 18, image 2 of 2
      • Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
      Ask FixBot
    1. Samsung Galaxy Note9 Display Assembly Replacement, Remove the midframe: step 19, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Remove the midframe: step 19, image 2 of 2
      • Remove the nine 4 mm Phillips screws from the plastic cover next to the battery.
      Ask FixBot
    2. Samsung Galaxy Note9 Display Assembly Replacement: step 20, image 1 of 1
      • Remove the plastic cover next to the battery.
      Ask FixBot
    3. Samsung Galaxy Note9 Display Assembly Replacement: step 21, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 21, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 21, image 3 of 3
      • Insert the tip of a spudger into the top of the lower midframe.
      • Pry the lower midframe out from the phone.
      • The lower midframe snaps into and out of place.
      • Remove the lower midframe.
      Ask FixBot
    4. Samsung Galaxy Note9 Display Assembly Replacement, Remove the front camera: step 22, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Remove the front camera: step 22, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Remove the front camera: step 22, image 3 of 3
      Buy
      • Use the tip of a spudger to pry the front camera connector straight up and out of its socket.
      • Use tweezers to remove the front camera.
      Ask FixBot
    5. Samsung Galaxy Note9 Display Assembly Replacement, Remove the iris scanner: step 23, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Remove the iris scanner: step 23, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Remove the iris scanner: step 23, image 3 of 3
      • Use the tip of a spudger to disconnect the iris scanner from the motherboard.
      • Use tweezers to remove the iris scanner.
      Ask FixBot
    6. Samsung Galaxy Note9 Display Assembly Replacement, Disconnect the front sensor array: step 24, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Disconnect the front sensor array: step 24, image 2 of 2
      • Use the flat end of a spudger to pry the front sensor connector out of its socket.
      Ask FixBot
    7. Samsung Galaxy Note9 Display Assembly Replacement, Disconnect the display assembly: step 25, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Disconnect the display assembly: step 25, image 2 of 2
      • Use the flat end of a spudger to disconnect the display cable from the motherboard.
      Ask FixBot
    8. Samsung Galaxy Note9 Display Assembly Replacement: step 26, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement: step 26, image 2 of 2
      • Use the flat end of a spudger to disconnect the touchscreen cable from the motherboard.
      Ask FixBot
    9. Samsung Galaxy Note9 Display Assembly Replacement, Disconnect the charging assembly: step 27, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Disconnect the charging assembly: step 27, image 2 of 2
      • Use the flat end of a spudger to disconnect the charging assembly from the motherboard.
      Ask FixBot
    10. Samsung Galaxy Note9 Display Assembly Replacement: step 28, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement: step 28, image 2 of 2
      • Remove the three 4 mm Phillips screws securing the motherboard.
      • There are triangles next to the holes indicating the motherboard screw locations.
      Ask FixBot
    11. Samsung Galaxy Note9 Display Assembly Replacement: step 29, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 29, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 29, image 3 of 3
      • Use a spudger to gently lift the motherbord from the upper-left corner.
      • Carefully remove the motherboard.
      • Move the ribbon cables out of the way as necessary. Do not pull the motherboard out if it becomes snagged on any cables.
      Ask FixBot
    1. Samsung Galaxy Note9 Display Assembly Replacement, Remove the headphone jack assembly: step 30, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Remove the headphone jack assembly: step 30, image 2 of 2
      • Remove the 3.2 mm Phillips screw from the headphone jack.
      Ask FixBot
    2. Samsung Galaxy Note9 Display Assembly Replacement: step 31, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement: step 31, image 2 of 2
      • Insert the tip of a spudger into the notch next to the headphone jack contact points.
      • Pry the contact board straight up to free it from the adhesive underneath.
      • If the contact board is difficult to separate, apply a drop of 90% isopropyl alcohol into the notch and allow it to soften the adhesive. Then, try again.
      Ask FixBot
    3. Samsung Galaxy Note9 Display Assembly Replacement: step 32, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement: step 32, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the headphone jack assembly.
      Ask FixBot
    1. Samsung Galaxy Note9 Display Assembly Replacement, Remove the Charging Assembly: step 33, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Remove the Charging Assembly: step 33, image 2 of 2
      • Remove the two 3.2 mm Phillips screws from the charging assembly.
      Ask FixBot
    2. Samsung Galaxy Note9 Display Assembly Replacement: step 34, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 34, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 34, image 3 of 3
      • Use a spudger to lift the microphone out from its housing.
      Ask FixBot
    3. Samsung Galaxy Note9 Display Assembly Replacement: step 35, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 35, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 35, image 3 of 3
      • Use an opening pick to separate the charging assembly from the phone.
      Ask FixBot
    4. Samsung Galaxy Note9 Display Assembly Replacement: step 36, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement: step 36, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the charging assembly.
      Ask FixBot
    5. Samsung Galaxy Note9 Display Assembly Replacement, Remove the battery: step 37, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Remove the battery: step 37, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement, Remove the battery: step 37, image 3 of 3
      • Apply a few drops of 90% isopropyl alcohol into the battery well along the bottom and upper-left corner of the battery.
      • Wait a couple of minutes for the alcohol to soften the adhesive under the battery.
      • Hold the phone at various angles to help the alcohol flow under the battery.
      Ask FixBot
    6. Samsung Galaxy Note9 Display Assembly Replacement: step 38, image 1 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 38, image 2 of 3 Samsung Galaxy Note9 Display Assembly Replacement: step 38, image 3 of 3
      • Apply a suction cup to the battery.
      • Lift the battery straight up until there is a gap large enough to insert the opening pick.
      • Insert an opening pick underneath the bottom edge of the battery and twist to loosen the battery adhesive.
      • Remove the battery.
      • It may take multiple attempts to get the suction cup to adhere. Apply is as close to the center of the battery as possible and avoid the white sticker at the bottom of the battery.
      • Do not bend the battery.
      Ask FixBot
    7. Samsung Galaxy Note9 Display Assembly Replacement, Remove the front sensor array: step 39, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement, Remove the front sensor array: step 39, image 2 of 2
      • Use a pair of tweezers to peel back the adhesive-backed copper foil.
      • Stop peeling once you reach the sensor array.
      • Be careful not to tear the foil.
      Ask FixBot
    8. Samsung Galaxy Note9 Display Assembly Replacement: step 40, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement: step 40, image 2 of 2
      • Use a spudger to lift the left side of the front sensor array and separate the adhesive the rest of the way.
      • The front sensor array is still connected to a ribbon cable that is adhered to the phone. Do not try to remove the front sensor array yet or you will damage it.
      Ask FixBot
    9. Samsung Galaxy Note9 Display Assembly Replacement: step 41, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement: step 41, image 2 of 2
      • Carefully slide an opening pick under the front sensor array ribbon cable to cut the adhesive underneath.
      Ask FixBot
    10. Samsung Galaxy Note9 Display Assembly Replacement: step 42, image 1 of 2 Samsung Galaxy Note9 Display Assembly Replacement: step 42, image 2 of 2
      • Use a pair of tweezers to remove the front sensor array.
      • Only the display assembly remains.
      • Before you begin reassembly, compare the new display assembly with the original and transfer any remaining components if necessary.
      Ask FixBot
55 other people completed this guide.
Author
with
Sam Omiotek
101,895 Reputation
289 Guides authored
21 Guide Comments
Make sure you transfer over the vibration motor if the new frame does not have it… didn’t realize my replacement didn’t have it until I put the glass back on :/
Oakman978 - Reply Share
Thank you for pointing this out! I almost missed it! I wish this guide showed how to put it back together instead of just saying “okay now do it again but backwards.” Anyway, I appreciate this comment right here haha.
Jeremiah Furlow - Reply Share
Is it just me or is this guide not complete?
ben allen - Reply Share
The guide assumes that you have a new display unit containing all the parts that are left after the last step (display, front glass, screen, cooling system, vibration motor and so on.)
Nils Hennings - Reply Share
Since replacement parts vary from seller to seller, you’ll have to compare yours to the original and transfer any remaining components. This guide was written for the display assembly that we were selling at the time.
When transferring other components such as the vibration motor just be sure to use the same methods as with similar components. Work slowly, always use heat or ≥90% isopropyl alcohol to soften adhesives, and search the internet for more information as necessary.
Sam Omiotek - Reply Share
Past 24 Hours: 11
Past 7 Days: 88
Past 30 Days: 470
All Time: 65,144
