Up to 20% off select tools
Samsung Galaxy Note7 Screen Assembly Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
103
All Time:
603
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 8 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
The Samsung Galaxy Note 7 is a rather dangerous phone, but even if it's rare and borderline unusable, it still needs proper documentation and maintenance.
NOTE: This guide assumes that you have a replacement screen + midframe with the other non-motherboard parts (speakers, S-pen compartment, etc).
    1. Samsung Galaxy Note7 Screen Assembly Replacement, Screen Assembly: step 1, image 1 of 1
      • Apply heat to the back panel, use a guitar pick and suction cup to carefully remove the adhesive and remove the back panel.
      Ask FixBot
    2. Samsung Galaxy Note7 Screen Assembly Replacement: step 2, image 1 of 1
      • Remove the screws holding the wireless charging and NFC cover in place using a 00 screwdriver, then lift it off.
      Ask FixBot
    3. Samsung Galaxy Note7 Screen Assembly Replacement: step 3, image 1 of 1
      • Carefully disconnect and remove the battery by lifting up the connector with either your fingernail or the flat end of a plastic spudger.
      Ask FixBot
    4. Samsung Galaxy Note7 Screen Assembly Replacement: step 4, image 1 of 1
      • Remove the five screws holding the speaker pass-through and lift it off.
      Ask FixBot
    5. Samsung Galaxy Note7 Screen Assembly Replacement: step 5, image 1 of 2 Samsung Galaxy Note7 Screen Assembly Replacement: step 5, image 2 of 2
      • Using the flat end of a plastic spudger, carefully remove and lift up every connector on the board.
      • Make sure to press them a little further upward using the spudger, or else they might end up blocking the motherboard from being lifted up, and can also get stuck underneath it during the reassembly process.
      Ask FixBot
    6. Samsung Galaxy Note7 Screen Assembly Replacement: step 6, image 1 of 2 Samsung Galaxy Note7 Screen Assembly Replacement: step 6, image 2 of 2
      • Remove the two screws holding the motherboard to the frame.
      Ask FixBot
    7. Samsung Galaxy Note7 Screen Assembly Replacement: step 7, image 1 of 1
      • Using a plastic spudger, lift up the bottom part of the motherboard, then lift it up and out of the frame.
      Ask FixBot
      • To reassemble the phone with the new screen + midframe, follow these steps in reverse order.
      Ask FixBot
2 other people completed this guide.
Author
with
Kugel Fisch
187 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 103
All Time: 603
