Up to 20% off select tools
Samsung Galaxy Note5 Volume Button Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
6
Past 7 Days:
18
Past 30 Days:
93
All Time:
1,934
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Broken volume button? Use this guide to remove the volume button on your Galaxy Note 5. The guide will take you through the steps of removing the back glass, separating the middle housing and removing the necessary parts to remove the volume button.
    1. Samsung Galaxy Note5 Volume Button Replacement, SIM Card Tray: step 1, image 1 of 1
      • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
      • Press down until the SIM Card Tray begins to protrude out of the device.
      Ask FixBot
    2. Samsung Galaxy Note5 Volume Button Replacement: step 2, image 1 of 1
      • Remove the SIM Card Tray from the slot.
      Ask FixBot
    1. Samsung Galaxy Note5 Volume Button Replacement, Power Button: step 3, image 1 of 1
      • Heat the back of the device with a heat gun for 2 minutes
      Ask FixBot
    2. Samsung Galaxy Note5 Volume Button Replacement: step 4, image 1 of 1
      • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
      • Be careful holding the device after heating the back, it may burn!
      • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
      • While pulling upwards, insert a pick under the rear glass
      Ask FixBot
    3. Samsung Galaxy Note5 Volume Button Replacement: step 5, image 1 of 1
      • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
      Ask FixBot
    4. Samsung Galaxy Note5 Volume Button Replacement: step 6, image 1 of 1
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
      Ask FixBot
    5. Samsung Galaxy Note5 Volume Button Replacement: step 7, image 1 of 1
      • Once all adhesive has been cut, gently lift up the rear glass to remove it.
      Ask FixBot
    6. Samsung Galaxy Note5 Volume Button Replacement: step 8, image 1 of 1
      • Remove the S-Pen from the bottom of the device
      Ask FixBot
    7. Samsung Galaxy Note5 Volume Button Replacement: step 9, image 1 of 2 Samsung Galaxy Note5 Volume Button Replacement: step 9, image 2 of 2
      • Remove 20 5mm screws with a Phillips #1 Screwdriver.
      Ask FixBot
    8. Samsung Galaxy Note5 Volume Button Replacement: step 10, image 1 of 2 Samsung Galaxy Note5 Volume Button Replacement: step 10, image 2 of 2
      • Grip the back of the device and press down on the white square to remove the middle housing.
      Ask FixBot
    9. Samsung Galaxy Note5 Volume Button Replacement: step 11, image 1 of 2 Samsung Galaxy Note5 Volume Button Replacement: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • Loosen the power button flex adhesive by holding it with the tweezers.
      • With the tweezers, pry up and remove the power button flex
      Ask FixBot
    10. Samsung Galaxy Note5 Volume Button Replacement: step 12, image 1 of 1
      • Push out the power button with the tip of the tweezers.
      Ask FixBot
    1. Samsung Galaxy Note5 Volume Button Replacement, Volume Button: step 13, image 1 of 2 Samsung Galaxy Note5 Volume Button Replacement, Volume Button: step 13, image 2 of 2
      • Loosen the volume flex adhesive.
      • Pry up and remove the volume button flex.
      Ask FixBot
    2. Samsung Galaxy Note5 Volume Button Replacement: step 14, image 1 of 1
      • Push out the volume button and remove it from the device.
      Ask FixBot
3 other people completed this guide.
Author
with
Bernice Nunez
388 Reputation
2 Guides authored
Cal Poly, Team S25-G17, Maness Spring 2018 Member of Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 93
All Time: 1,934
