Samsung Galaxy Note5 Motherboard Replacement
    1. Samsung Galaxy Note5 Motherboard Replacement, SIM Card Tray: step 1, image 1 of 3 Samsung Galaxy Note5 Motherboard Replacement, SIM Card Tray: step 1, image 2 of 3 Samsung Galaxy Note5 Motherboard Replacement, SIM Card Tray: step 1, image 3 of 3
      • Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray at the top of the phone.
      • Press to eject the tray. This may require some force.
      • Remove the SIM card tray.
      Ask FixBot
    1. Samsung Galaxy Note5 Motherboard Replacement, S-Pen: step 2, image 1 of 3 Samsung Galaxy Note5 Motherboard Replacement, S-Pen: step 2, image 2 of 3 Samsung Galaxy Note5 Motherboard Replacement, S-Pen: step 2, image 3 of 3
      • Using your fingernail, push the S-Pen button until it clicks and pops out of the phone.
      • Remove the S-Pen.
      Ask FixBot
    1. Samsung Galaxy Note5 Motherboard Replacement, Rear Glass: step 3, image 1 of 1
      • If the glass back is cracked, carefully tape over the entire surface with packing tape.
      • Apply a heated iOpener to the bottom of the phone for about two minutes.
      • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy Note5 Motherboard Replacement: step 4, image 1 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 4, image 2 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 4, image 3 of 3
      • Apply a suction cup as close as possible to the bottom edge of the phone.
      • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
      • Lift on the suction cup and insert an opening pick under the rear glass.
      • The rear glass very fragile and can break if you use too much force or attempt to pry with metal tools.
      Ask FixBot
    3. Samsung Galaxy Note5 Motherboard Replacement: step 5, image 1 of 1
      • Once the pick is in place, reheat the edge with an iOpener for another minute.
      Ask FixBot
    4. Samsung Galaxy Note5 Motherboard Replacement: step 6, image 1 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 6, image 2 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 6, image 3 of 3
      • Slide the pick down the bottom edge of the phone.
      • Go slowly so that the tip doesn't slip out of the seam. If sliding becomes difficult, reheat and reapply the iOpener.
      • Leave the pick in place to prevent the adhesive from resealing, and grab another pick as you proceed to the next step.
      Ask FixBot
    5. Samsung Galaxy Note5 Motherboard Replacement: step 7, image 1 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 7, image 2 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 7, image 3 of 3
      • Insert another pick and slowly cut around the corner of the phone.
      • Due to the curved shape of the back, the glass is extremely fragile and prone to cracking in the corners. Be patient and reapply an iOpener if the corner feels hard to slice through.
      Ask FixBot
    6. Samsung Galaxy Note5 Motherboard Replacement: step 8, image 1 of 1
      • Before cutting further, apply a heated iOpener to the long edge.
      Ask FixBot
    7. Samsung Galaxy Note5 Motherboard Replacement: step 9, image 1 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 9, image 2 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 9, image 3 of 3
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave an opening pick in each edge of the phone as you continue to the next to prevent the adhesive from resealing.
      Ask FixBot
    8. Samsung Galaxy Note5 Motherboard Replacement: step 10, image 1 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 10, image 2 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 10, image 3 of 3
      • Use an opening pick to cut any remaining adhesive around the edges of the glass.
      • Lift the glass and remove it from the phone.
      Ask FixBot
    9. Samsung Galaxy Note5 Motherboard Replacement: step 11, image 1 of 1
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • To reinstall the back cover:
      • Use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
      • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
      • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
      • Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. Be aware that this leaves gaps that are vulnerable to liquid intrusion.
      • After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
      • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
      Ask FixBot
    1. Samsung Galaxy Note5 Motherboard Replacement, Midframe: step 12, image 1 of 1
      • Remove the twenty 3.3 mm Phillips screws.
      Ask FixBot
    2. Samsung Galaxy Note5 Motherboard Replacement: step 13, image 1 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 13, image 2 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 13, image 3 of 3
      • Make sure you've ejected the SIM tray before performing this step.
      • Hold the midframe by the edges and lift it upwards while pushing down against the battery with one finger.
      • There is a small amount of adhesive in each corner holding the midframe to the display assembly. Apply constant force until the midframe separates.
      • Remove the midframe.
      Ask FixBot
    1. Samsung Galaxy Note5 Motherboard Replacement, Samsung Galaxy Note5 Battery Disconnect: step 14, image 1 of 2 Samsung Galaxy Note5 Motherboard Replacement, Samsung Galaxy Note5 Battery Disconnect: step 14, image 2 of 2
      • Using the flat end of a spudger, lift the battery connector straight up from its socket on the motherboard.
      Ask FixBot
    1. Samsung Galaxy Note5 Motherboard Replacement, Motherboard: step 15, image 1 of 2 Samsung Galaxy Note5 Motherboard Replacement, Motherboard: step 15, image 2 of 2
      • Using the flat end of a spudger, disconnect the earpiece connector.
      Ask FixBot
    2. Samsung Galaxy Note5 Motherboard Replacement: step 16, image 1 of 2 Samsung Galaxy Note5 Motherboard Replacement: step 16, image 2 of 2
      • Using the flat end of a spudger, disconnect the touchscreen connector.
      Ask FixBot
    3. Samsung Galaxy Note5 Motherboard Replacement: step 17, image 1 of 2 Samsung Galaxy Note5 Motherboard Replacement: step 17, image 2 of 2
      • Using the flat end of a spudger, disconnect the display connector.
      Ask FixBot
    4. Samsung Galaxy Note5 Motherboard Replacement: step 18, image 1 of 2 Samsung Galaxy Note5 Motherboard Replacement: step 18, image 2 of 2
      • Using the flat end of a spudger, disconnect the navigation buttons connector.
      Ask FixBot
    5. Samsung Galaxy Note5 Motherboard Replacement: step 19, image 1 of 2 Samsung Galaxy Note5 Motherboard Replacement: step 19, image 2 of 2
      • Using the pointed end of a spudger, disconnect the antenna cable.
      Ask FixBot
    6. Samsung Galaxy Note5 Motherboard Replacement: step 20, image 1 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 20, image 2 of 3 Samsung Galaxy Note5 Motherboard Replacement: step 20, image 3 of 3
      • Holding the motherboard by the top corners, hinge it upwards while clearing flex cables out of its path.
      • Do not remove the motherboard. It is still attached to the daughterboard.
      Ask FixBot
    7. Samsung Galaxy Note5 Motherboard Replacement: step 21, image 1 of 2 Samsung Galaxy Note5 Motherboard Replacement: step 21, image 2 of 2
      • Using the flat end of a spudger, disconnect the daughterboard connector from the motherboard.
      • Remove the motherboard.
      Ask FixBot
7 other people completed this guide.
Arthur Shi
350,942 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
1 Guide Comment
thx buddy for help
kararcoco - Reply Share
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 81
All Time: 9,949
