Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement
    1. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the SIM card tray: step 1, image 1 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the SIM card tray: step 1, image 2 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the SIM card tray: step 1, image 3 of 3
      • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the top edge of the phone.
      • Press firmly to eject the tray.
      • Remove the SIM card tray.
      • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Heat the rear cover: step 2, image 1 of 1
      • Completely power off your phone before you begin disassembly.
      • Heat an iOpener and apply it to the left side of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Insert an opening pick: step 3, image 3 of 3
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
      Ask FixBot
    3. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Begin to cut the adhesive: step 4, image 1 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Begin to cut the adhesive: step 4, image 2 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Begin to cut the adhesive: step 4, image 3 of 3
      • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Cut along the perimeter of the rear cover: step 5, image 1 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Cut along the perimeter of the rear cover: step 5, image 2 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Cut along the perimeter of the rear cover: step 5, image 3 of 3
      • While cutting through the adhesive, don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
      • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
      • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
      • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
      • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
      Ask FixBot
    5. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the rear cover: step 6, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the rear cover: step 6, image 2 of 2
      • Lift the rear cover straight up to remove it.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the wireless charging coil: step 7, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the wireless charging coil: step 7, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
      • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    2. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the white press connector: step 8, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the white press connector: step 8, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
      Ask FixBot
    3. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the motherboard shield screws: step 9, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
      • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
      Ask FixBot
    4. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the wireless charging coil: step 10, image 1 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the wireless charging coil: step 10, image 2 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the wireless charging coil: step 10, image 3 of 3
      Buy
      • Use a pair of tweezers to lift up the motherboard shield.
      • Be careful when handling the motherboard shield because its edges are thin and sharp.
      • Use your fingers to grip the motherboard shield.
      Ask FixBot
    5. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 11, image 1 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 11, image 2 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 11, image 3 of 3
      • Peel the wireless charging coil up and away from the device to remove it.
      • The wireless charging coil is secured to the device with light adhesive.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the battery: step 12, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the battery: step 12, image 2 of 2
      • Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the laser AF sensor: step 13, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the laser AF sensor: step 13, image 2 of 2
      • Use the pointed end of a spudger to pry up the laser AF sensor press connector.
      Ask FixBot
    2. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the earpiece speaker screws: step 14, image 1 of 1
      • Use a Phillips screwdriver to remove the four 4.0 mm screws securing the earpiece speaker.
      Ask FixBot
    3. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the earpiece speaker: step 15, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the earpiece speaker: step 15, image 2 of 2
      • Insert the pointed end of a spudger into the hole marked by a small triangle on the right side of the earpiece speaker.
      • Use the spudger to pry up and loosen the earpiece speaker from the frame.
      • The earpiece speaker clips to the frame along the top edge.
      Ask FixBot
    4. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 16, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 16, image 2 of 2
      • Lift and remove the earpiece speaker.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Front-Facing Camera Cable Disconnection: step 17, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Front-Facing Camera Cable Disconnection: step 17, image 2 of 2
      • Use the pointed end of a spudger to disconnect the front-facing camera cable from the motherboard.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the display cable: step 18, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the display cable: step 18, image 2 of 2
      • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the interconnect cables: step 19, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the interconnect cables: step 19, image 2 of 2
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 20, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 20, image 2 of 2
      • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
      Ask FixBot
    3. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the remaining cables: step 21, image 1 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the remaining cables: step 21, image 2 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the remaining cables: step 21, image 3 of 3
      • Use the pointed end of a spudger to disconnect the touch layer cable from the motherboard.
      • Use the pointed end of a spudger to disconnect the green press connector from the motherboard.
      Ask FixBot
    4. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 22, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 22, image 2 of 2
      • Use the pointed end of a spudger to disconnect the S-Pen press connector from the motherboard.
      Ask FixBot
    5. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the motherboard screws: step 23, image 1 of 1
      • Use a Phillips screwdriver to remove the two 4.0 mm screws securing the motherboard to the frame.
      Ask FixBot
    6. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Loosen the motherboard: step 24, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Loosen the motherboard: step 24, image 2 of 2
      • Insert the flat end of a spudger under the bottom edge of the motherboard.
      • Pry up to loosen the motherboard from the frame.
      Ask FixBot
    7. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the motherboard: step 25, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the motherboard: step 25, image 2 of 2
      • Lift the motherboard out of the phone.
      • Be careful not to damage the disconnected press connectors and their cables while removing the motherboard.
      Ask FixBot
    8. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Check cables during reassembly: step 26, image 1 of 1
      • When you reinstall the motherboard, make sure that no cables get trapped under the board as you lower it into place. Check these seven locations carefully:
      • Secondary interconnect cable
      • Battery cable
      • Main interconnect cable
      • Display cable
      • S-Pen cable
      • Touch layer cable and green press connector
      • Front-facing camera cable
      Ask FixBot
    9. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the camera press connectors: step 27, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Disconnect the camera press connectors: step 27, image 2 of 2
      • Use the pointed end of a spudger to disconnect the ultra wide camera from the motherboard.
      Ask FixBot
    10. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 28, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 28, image 2 of 2
      • Use the pointed end of a spudger to disconnect the telephoto camera from the motherboard.
      Ask FixBot
    11. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 29, image 1 of 2 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement: step 29, image 2 of 2
      • Use the pointed end of a spudger to disconnect the wide-angle camera from the motherboard.
      Ask FixBot
    12. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Move the ribbon cable: step 30, image 1 of 1
      • Bend the ultra wide camera ribbon cable away from the motherboard so that the rear camera assembly can be removed.
      • Don't bend the ribbon cable more than 90 degrees to avoid damaging it.
      Ask FixBot
    13. Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the rear camera assembly: step 31, image 1 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the rear camera assembly: step 31, image 2 of 3 Samsung Galaxy Note20 Ultra Rear Camera Assembly Replacement, Remove the rear camera assembly: step 31, image 3 of 3
      • The rear camera assembly is secured to the motherboard with light adhesive to the right of the telephoto camera.
      • Remove the rear camera assembly from the motherboard.
      • During reassembly, follow this guide if you are using a pre-cut adhesive card to secure the new rear camera assembly to the motherboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
9 other people completed this guide.
Kyle Smith
53,299 Reputation
124 Guides authored
1 Guide Comment
Hallo KYLE,
EINE Frage:
Wenn ich nun die Rückkamera Einheit separiert habe, und ich möchte einen Fremdkörper in der Tele kamera entfernen, wie kann ich diese Telekamera öffnen, um den relativ großen Fremdkörper zu entfernen?
Es handelt sich tatsächlich um einen Glassplitter!
Dieser kommt nicht von der Telekamera und ich habe keine Ahnung wie dieser von außen da hinein gelangt ist.
Das erste rechteckige Glas der Kamera-Optik mit der optischen Vergütung, ist unversehrt!
Der Splitter befindet sich dahinter!
Wie komme ich da dran, um ihn zu entfernen?
Vielen Dank und viele Grüße,
Roland
Roland von Bremen - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 179
All Time: 17,917
