Samsung Galaxy Note20 Ultra Battery Replacement
    1. Samsung Galaxy Note20 Ultra Battery Replacement, Heat the rear cover: step 1, image 1 of 1
      • Completely power off your phone before you begin disassembly.
      • Heat an iOpener and apply it to the left side of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy Note20 Ultra Battery Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy Note20 Ultra Battery Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy Note20 Ultra Battery Replacement, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
      Ask FixBot
    3. Samsung Galaxy Note20 Ultra Battery Replacement, Begin to cut the adhesive: step 3, image 1 of 3 Samsung Galaxy Note20 Ultra Battery Replacement, Begin to cut the adhesive: step 3, image 2 of 3 Samsung Galaxy Note20 Ultra Battery Replacement, Begin to cut the adhesive: step 3, image 3 of 3
      • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Samsung Galaxy Note20 Ultra Battery Replacement, Cut along the perimeter of the rear cover: step 4, image 1 of 3 Samsung Galaxy Note20 Ultra Battery Replacement, Cut along the perimeter of the rear cover: step 4, image 2 of 3 Samsung Galaxy Note20 Ultra Battery Replacement, Cut along the perimeter of the rear cover: step 4, image 3 of 3
      • While cutting through the adhesive, don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
      • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
      • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
      • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
      • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
      Ask FixBot
    5. Samsung Galaxy Note20 Ultra Battery Replacement, Remove the rear cover: step 5, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement, Remove the rear cover: step 5, image 2 of 2
      • Lift the rear cover straight up to remove it.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the wireless charging coil: step 6, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the wireless charging coil: step 6, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
      • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    2. Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the white press connector: step 7, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the white press connector: step 7, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
      Ask FixBot
    3. Samsung Galaxy Note20 Ultra Battery Replacement, Remove the motherboard shield screws: step 8, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
      • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
      Ask FixBot
    4. Samsung Galaxy Note20 Ultra Battery Replacement, Remove the wireless charging coil: step 9, image 1 of 3 Samsung Galaxy Note20 Ultra Battery Replacement, Remove the wireless charging coil: step 9, image 2 of 3 Samsung Galaxy Note20 Ultra Battery Replacement, Remove the wireless charging coil: step 9, image 3 of 3
      Buy
      • Use a pair of tweezers to lift up the motherboard shield.
      • Be careful when handling the motherboard shield because its edges are thin and sharp.
      • Use your fingers to grip the motherboard shield.
      Ask FixBot
    5. Samsung Galaxy Note20 Ultra Battery Replacement: step 10, image 1 of 3 Samsung Galaxy Note20 Ultra Battery Replacement: step 10, image 2 of 3 Samsung Galaxy Note20 Ultra Battery Replacement: step 10, image 3 of 3
      • Peel the wireless charging coil up and away from the device to remove it.
      • The wireless charging coil is secured to the device with light adhesive.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the battery: step 11, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the battery: step 11, image 2 of 2
      • Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Battery Replacement, Remove the loudspeaker screws: step 12, image 1 of 1
      • Use a Phillips screwdriver to remove the five 4.0 mm screws securing the loudspeaker to the frame.
      Ask FixBot
    2. Samsung Galaxy Note20 Ultra Battery Replacement, Loosen the loudspeaker: step 13, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement, Loosen the loudspeaker: step 13, image 2 of 2
      • Insert the pointed end of a spudger into the hole marked by a triangle on the left side of the loudspeaker.
      • Use the spudger to pry up and loosen the left side of the loudspeaker.
      Ask FixBot
    3. Samsung Galaxy Note20 Ultra Battery Replacement: step 14, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement: step 14, image 2 of 2
      • Insert the pointed end of a spudger into the hole marked by a triangle on the right side of the loudspeaker.
      • Use the spudger to pry up and detach the loudspeaker from the frame.
      • The loudspeaker is secured to the frame by clips along its bottom edge.
      Ask FixBot
    4. Samsung Galaxy Note20 Ultra Battery Replacement, Remove the loudspeaker: step 15, image 1 of 1
      Buy
      • Use a pair of tweezers to lift and remove the loudspeaker.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the interconnect cables from the daughterboard: step 16, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the interconnect cables from the daughterboard: step 16, image 2 of 2
      • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
      Ask FixBot
    2. Samsung Galaxy Note20 Ultra Battery Replacement: step 17, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement: step 17, image 2 of 2
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the display cable: step 18, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the display cable: step 18, image 2 of 2
      • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
      Ask FixBot
    1. Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the interconnect cables from the motherboard: step 19, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement, Disconnect the interconnect cables from the motherboard: step 19, image 2 of 2
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy Note20 Ultra Battery Replacement: step 20, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement: step 20, image 2 of 2
      • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
      Ask FixBot
    3. Samsung Galaxy Note20 Ultra Battery Replacement, Move the cables: step 21, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement, Move the cables: step 21, image 2 of 2
      • Flip the secondary interconnect cable away from the battery.
      • The secondary interconnect cable is still attached to the phone by a ribbon cable. You only need to move the cable enough to access the battery.
      • Do not bend the ribbon cables more than necessary. Excessive bending may damage the cables.
      Ask FixBot
    4. Samsung Galaxy Note20 Ultra Battery Replacement: step 22, image 1 of 3 Samsung Galaxy Note20 Ultra Battery Replacement: step 22, image 2 of 3 Samsung Galaxy Note20 Ultra Battery Replacement: step 22, image 3 of 3
      • Bend the display cable back so you can access the battery.
      • Bend the main interconnect cable back.
      Ask FixBot
    5. Samsung Galaxy Note20 Ultra Battery Replacement, Apply isopropyl alcohol: step 23, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement, Apply isopropyl alcohol: step 23, image 2 of 2
      • Apply 1-2 drops of high-concentration (90% or higher) isopropyl alcohol to the open spaces in each corner of the battery.
      • Using too much alcohol can damage the display.
      • Wait two minutes for the isopropyl alcohol to weaken the adhesive underneath the battery.
      Ask FixBot
    6. Samsung Galaxy Note20 Ultra Battery Replacement, Remove the battery: step 24, image 1 of 1
      • Apply a suction cup to the center of the battery.
      Ask FixBot
    7. Samsung Galaxy Note20 Ultra Battery Replacement: step 25, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement: step 25, image 2 of 2
      • Pull up on the suction cup with a steady force to create a gap between the bottom edge of the battery and the frame.
      • Take care not to bend the battery—a bent battery may leak dangerous chemicals or cause a thermal event.
      • If the battery does not appear to be separating from the frame, apply a few more drops of isopropyl alcohol and wait two minutes before trying again.
      • The adhesive underneath the battery is strong. You might need to apply isopropyl alcohol and pull up on the suction cup multiple times to loosen the battery.
      Ask FixBot
    8. Samsung Galaxy Note20 Ultra Battery Replacement: step 26, image 1 of 2 Samsung Galaxy Note20 Ultra Battery Replacement: step 26, image 2 of 2
      • Insert the point of an opening pick into the gap created between the bottom edge of the battery and the frame.
      • Push the pick under the battery to cut through the adhesive and detach the battery from the frame.
      • Don't insert the opening pick more than halfway to avoid damaging the fingerprint sensor underneath the battery.
      • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
      Ask FixBot
    9. Samsung Galaxy Note20 Ultra Battery Replacement: step 27, image 1 of 1
      • Pull up on the suction cup to remove the battery.
      • The battery will come out without much force once the isopropyl alcohol has adequately penetrated the battery adhesive.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
      • During reassembly, remove the old adhesive and apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
39 other people completed this guide.
Kyle Smith
53,296 Reputation
124 Guides authored
11 Guide Comments
where did you buy the new battery from?
Cameron Rozek - Reply Share
What is the precut adhesive card used for?
Fabian Charlton - Reply Share
Thank you so much!!! My battery was starting to bulge badly. While the life was still satisfactory, the shape of my phone was beginning to become very distorted, the side buttons no longer worked properly in my DBrand case, and when I pressed my finger on the fingerprint sensor, my screen would depress and click. Not only did you offer the battery and tools needed, but a perfect guide to installing it. Simply amazing.
I just wish you would lose the ridiculous communist imagery on your branding. Repairing products is not communist, it just makes sense. Let's make right to repair an American virtue again, and not model the movement off some Maoist revolution.
Scott Aragon - Reply Share
Just want to note, I bought the precut adhesive, and battery adhesive from this guide, only to start looking around more and find that Ifixit also sells the note 20 ultra 5G precut adhesive so you don't need to deal with putting the precut adhesive strips around the edge.
Fun note, it also comes with the battery adhesive, so now I have an extra battery adhesive, as well as precut tape strips that I probably will never use, or if I do use, will probably never be able to find them... lol
Galaxy Note20 Ultra/20 Ultra 5G Rear Cover Adhesive
David Johnson - Reply Share
I made this same mistake of ordering an extra battery adhesive when I ordered last month. I guess I just read the title, as the description mentions the battery adhesive.
David M - Reply Share
Past 24 Hours: 49
Past 7 Days: 343
Past 30 Days: 1,583
All Time: 104,189
