Up to 20% off select tools
Samsung Galaxy Note20 Screen Replacement
Views: 25K
View statistics:
Past 24 Hours:
15
Past 7 Days:
63
Past 30 Days:
302
All Time:
25,198
Comments: 8
4 comments on steps, 4 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 4 hours
Difficulty: Difficult
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the screen on your Samsung Galaxy Note20.
The fingerprint sensor is embedded in this phone’s screen. If your fingerprint sensor isn’t working, you will likely need to replace the entire screen.
Some images may show the loudspeaker and earpiece speaker removed from the device. You don’t have to remove the speakers for this repair.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. If you’re trying to reuse the screen, be sure to apply plenty of heat and be extremely careful during the prying stage.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    1. Samsung Galaxy Note20 Screen Replacement, Heat the rear cover: step 1, image 1 of 1
      • Completely power off your phone before you begin disassembly.
      • Heat an iOpener and apply it to the left side of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen, internal battery, and the plastic rear cover are susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy Note20 Screen Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy Note20 Screen Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy Note20 Screen Replacement, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
      Ask FixBot
    3. Samsung Galaxy Note20 Screen Replacement, Begin to cut the adhesive: step 3, image 1 of 3 Samsung Galaxy Note20 Screen Replacement, Begin to cut the adhesive: step 3, image 2 of 3 Samsung Galaxy Note20 Screen Replacement, Begin to cut the adhesive: step 3, image 3 of 3
      • As you cut through the adhesive around the perimeter of the phone, don't insert the pick more than 5 mm to avoid damaging internal components.
      • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Samsung Galaxy Note20 Screen Replacement, Cut along the perimeter of the rear cover: step 4, image 1 of 3 Samsung Galaxy Note20 Screen Replacement, Cut along the perimeter of the rear cover: step 4, image 2 of 3 Samsung Galaxy Note20 Screen Replacement, Cut along the perimeter of the rear cover: step 4, image 3 of 3
      • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
      • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
      • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
      • If the rear cover is still attached to the frame after cutting through all four sides, try slicing through the adhesive again with an opening pick.
      Ask FixBot
    5. Samsung Galaxy Note20 Screen Replacement, Remove the rear cover: step 5, image 1 of 2 Samsung Galaxy Note20 Screen Replacement, Remove the rear cover: step 5, image 2 of 2
      • Lift the rear cover straight up to remove it.
      Ask FixBot
    1. Samsung Galaxy Note20 Screen Replacement, Remove the motherboard shield: step 6, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
      • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
      Ask FixBot
    2. Samsung Galaxy Note20 Screen Replacement: step 7, image 1 of 3 Samsung Galaxy Note20 Screen Replacement: step 7, image 2 of 3 Samsung Galaxy Note20 Screen Replacement: step 7, image 3 of 3
      Buy
      • Use a pair of tweezers to lift up and flip back the motherboard shield.
      • Be careful when handling the motherboard shield because its edges are thin and sharp.
      Ask FixBot
    3. Samsung Galaxy Note20 Screen Replacement, Disconnect the battery: step 8, image 1 of 2 Samsung Galaxy Note20 Screen Replacement, Disconnect the battery: step 8, image 2 of 2
      • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
      • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    4. Samsung Galaxy Note20 Screen Replacement, Disconnect the wireless charging coil: step 9, image 1 of 2 Samsung Galaxy Note20 Screen Replacement, Disconnect the wireless charging coil: step 9, image 2 of 2
      • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
      Ask FixBot
    5. Samsung Galaxy Note20 Screen Replacement, Remove the wireless charging coil: step 10, image 1 of 3 Samsung Galaxy Note20 Screen Replacement, Remove the wireless charging coil: step 10, image 2 of 3 Samsung Galaxy Note20 Screen Replacement, Remove the wireless charging coil: step 10, image 3 of 3
      • Grip the motherboard shield with your fingers.
      • Peel the wireless charging coil up and away from the device.
      • The wireless charging coil is secured to the device with light adhesive.
      • Remove the wireless charging coil.
      Ask FixBot
    1. Samsung Galaxy Note20 Screen Replacement, Disconnect the display cable: step 11, image 1 of 2 Samsung Galaxy Note20 Screen Replacement, Disconnect the display cable: step 11, image 2 of 2
      • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy Note20 Screen Replacement, Disconnect the touch layer cable: step 12, image 1 of 2 Samsung Galaxy Note20 Screen Replacement, Disconnect the touch layer cable: step 12, image 2 of 2
      • Use the pointed end of a spudger to disconnect the touch layer cable connector from the motherboard.
      Ask FixBot
    3. Samsung Galaxy Note20 Screen Replacement, Adhesive information: step 13, image 1 of 1
      • This image shows the phone with the screen removed.
      • To remove the screen, you will need to weaken and cut through the adhesive securing the screen's perimeter to the frame.
      • There is additional adhesive around the front-facing camera and the fingerprint sensor.
      • Inserting opening picks beyond the adhesive may damage internal components.
      Ask FixBot
    4. Samsung Galaxy Note20 Screen Replacement, Loosen the adhesive: step 14, image 1 of 1
      • Heat an iOpener and apply it to the top of the screen for two minutes.
      • A properly heated iOpener should stay warm for up to 10 minutes. Do not reheat the iOpener more than necessary.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen and internal battery are both susceptible to heat damage.
      Ask FixBot
    5. Samsung Galaxy Note20 Screen Replacement, Separate the perimeter adhesive: step 15, image 1 of 3 Samsung Galaxy Note20 Screen Replacement, Separate the perimeter adhesive: step 15, image 2 of 3 Samsung Galaxy Note20 Screen Replacement, Separate the perimeter adhesive: step 15, image 3 of 3
      • Apply a suction cup to the heated top edge of the screen, as close to the edge as possible.
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Pull up on the suction cup with a steady force to create a gap between the screen and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble creating a gap for the opening pick, apply more heat to the edge and try again. You may need to repeat this step multiple times.
      • Insert the tip of an opening pick into the gap at a steep angle. Push down the opening pick so that it is level with the screen.
      • Make sure the opening pick slides over the front-facing camera and is not pushing against it.
      • Leave the opening pick in the gap to prevent the adhesive from re-sealing.
      Ask FixBot
    6. Samsung Galaxy Note20 Screen Replacement: step 16, image 1 of 2 Samsung Galaxy Note20 Screen Replacement: step 16, image 2 of 2
      • Insert a second opening pick into the gap.
      • Slide it to the top left corner of the screen to cut the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    7. Samsung Galaxy Note20 Screen Replacement: step 17, image 1 of 2 Samsung Galaxy Note20 Screen Replacement: step 17, image 2 of 2
      • Insert a third opening pick into the initial gap.
      • Slide it to the top right corner to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    8. Samsung Galaxy Note20 Screen Replacement: step 18, image 1 of 2 Samsung Galaxy Note20 Screen Replacement: step 18, image 2 of 2
      • Push the center opening pick farther into the phone to cut through the adhesive surrounding the earpiece speaker and front-facing camera.
      • Don't insert the opening pick so far under the screen that you can't retrieve it.
      • Remove the center opening pick.
      Ask FixBot
    9. Samsung Galaxy Note20 Screen Replacement: step 19, image 1 of 1
      Ask FixBot
    10. Samsung Galaxy Note20 Screen Replacement: step 20, image 1 of 2 Samsung Galaxy Note20 Screen Replacement: step 20, image 2 of 2
      • Insert another opening pick into the gap in the top right corner of the screen.
      • Slide the opening pick down to the bottom right corner to cut through the adhesive.
      • Leave the opening pick in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    11. Samsung Galaxy Note20 Screen Replacement: step 21, image 1 of 2 Samsung Galaxy Note20 Screen Replacement: step 21, image 2 of 2
      • Insert the tip of an opening pick under the center of the right edge of the screen at a steep angle.
      • Push down the opening pick so that it is level with the screen.
      • Leave the opening pick in the center of the right edge of the screen to prevent the adhesive from re-sealing.
      Ask FixBot
    12. Samsung Galaxy Note20 Screen Replacement: step 22, image 1 of 1
      Ask FixBot
    13. Samsung Galaxy Note20 Screen Replacement: step 23, image 1 of 2 Samsung Galaxy Note20 Screen Replacement: step 23, image 2 of 2
      • Insert another opening pick into the gap in the top left corner of the screen.
      • Slide the opening pick down to the bottom left corner to cut through the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    14. Samsung Galaxy Note20 Screen Replacement: step 24, image 1 of 2 Samsung Galaxy Note20 Screen Replacement: step 24, image 2 of 2
      • Insert the tip of an opening pick under the center of the left edge of the screen at a steep angle.
      • Leave the opening pick in the center of the left edge of the screen to prevent the adhesive from re-sealing.
      • At this point, the perimeter of the screen should be separated from the frame. If there is still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
      Ask FixBot
    15. Samsung Galaxy Note20 Screen Replacement, Loosen the inner adhesive: step 25, image 1 of 2 Samsung Galaxy Note20 Screen Replacement, Loosen the inner adhesive: step 25, image 2 of 2
      • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the right edge of the screen to weaken the inner adhesive near the fingerprint sensor.
      • Insert the isopropyl alcohol applicator near the top of the inner adhesive area to avoid damaging the fingerprint sensor.
      • You may apply the isopropyl alcohol without inserting the applicator into the phone if needed.
      • Tilt the phone so that the isopropyl alcohol flows toward the inner adhesive.
      • Wait two minutes for the alcohol to weaken the adhesive.
      Ask FixBot
    16. Samsung Galaxy Note20 Screen Replacement, Remove the screen: step 26, image 1 of 2 Samsung Galaxy Note20 Screen Replacement, Remove the screen: step 26, image 2 of 2
      • Don't try to completely remove the screen yet. There are still two cables routed through the frame.
      • Hold the top half of the frame up so that the touch layer cable can be threaded through its cutout.
      • Lift the screen up from its top half while threading the touch layer cable through its cutout in the frame.
      • Don't lift the screen higher than a 15 degree angle above the frame to avoid damaging the device.
      • If the screen does not easily lift off the frame, you may need to cut through more of the perimeter adhesive or apply more isopropyl alcohol to the inner adhesive.
      Ask FixBot
    17. Samsung Galaxy Note20 Screen Replacement: step 27, image 1 of 3 Samsung Galaxy Note20 Screen Replacement: step 27, image 2 of 3 Samsung Galaxy Note20 Screen Replacement: step 27, image 3 of 3
      • Thread the display cable and touch layer cable through their cutouts in the frame as you remove the screen.
      • During reassembly, remember to thread the display cable and touch layer cable back through their cutouts in the frame.
      • The display cable has two clips near the screen that secure it to the metal bracket on the frame. When threading the display cable into its cutout, make sure to align the clips so they hang over the edge of the bracket.
      Ask FixBot
    18. Samsung Galaxy Note20 Screen Replacement: step 28, image 1 of 1
      • Remove the screen.
      • Remove any leftover adhesive before installing a new screen.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new screen.
      • Be sure to test your repairs before installing new adhesives.
      • If you are using a custom-cut adhesive, follow this guide for instructions on how to apply adhesive to the replacement screen.
      • If you are using a pre-cut adhesive card, follow this guide.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
15 other people completed this guide.
Author
with
Kyle Smith
53,826 Reputation
124 Guides authored
4 Guide Comments
Over priced for the digitizer, crappy to call people stupid
William Gundelach - Reply Share
I used this guide today for a screen replacement. This guide is a great way to keep track of screws.
Nicholas Jacob - Reply Share
i have one issue a customer brought their phone to my store the phone turns on but the screen shows nothing you feel the phone vibrating but displays nothing she claims its not broken or anything .. just hep me out here what do i do tried disconecting it and reconecting still no change how do i go about this then
Alvin Gerald - Reply Share
So 133 dollar screen for what I'm getting for 72 dollars what a rip off 🤣
Afam Tochukwu - Reply Share
Past 24 Hours: 15
Past 7 Days: 63
Past 30 Days: 302
All Time: 25,198
