Samsung Galaxy Note20 Daughterboard Replacement
    1. Samsung Galaxy Note20 Daughterboard Replacement, Heat the rear cover: step 1, image 1 of 1
      • Completely power off your phone before you begin disassembly.
      • Heat an iOpener and apply it to the left side of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen, internal battery, and the plastic rear cover are susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy Note20 Daughterboard Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy Note20 Daughterboard Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy Note20 Daughterboard Replacement, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
      Ask FixBot
    3. Samsung Galaxy Note20 Daughterboard Replacement, Begin to cut the adhesive: step 3, image 1 of 3 Samsung Galaxy Note20 Daughterboard Replacement, Begin to cut the adhesive: step 3, image 2 of 3 Samsung Galaxy Note20 Daughterboard Replacement, Begin to cut the adhesive: step 3, image 3 of 3
      • As you cut through the adhesive around the perimeter of the phone, don't insert the pick more than 5 mm to avoid damaging internal components.
      • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Samsung Galaxy Note20 Daughterboard Replacement, Cut along the perimeter of the rear cover: step 4, image 1 of 3 Samsung Galaxy Note20 Daughterboard Replacement, Cut along the perimeter of the rear cover: step 4, image 2 of 3 Samsung Galaxy Note20 Daughterboard Replacement, Cut along the perimeter of the rear cover: step 4, image 3 of 3
      • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
      • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
      • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
      • If the rear cover is still attached to the frame after cutting through all four sides, try slicing through the adhesive again with an opening pick.
      Ask FixBot
    5. Samsung Galaxy Note20 Daughterboard Replacement, Remove the rear cover: step 5, image 1 of 2 Samsung Galaxy Note20 Daughterboard Replacement, Remove the rear cover: step 5, image 2 of 2
      • Lift the rear cover straight up to remove it.
      Ask FixBot
    1. Samsung Galaxy Note20 Daughterboard Replacement, Remove the motherboard shield: step 6, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
      • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
      Ask FixBot
    2. Samsung Galaxy Note20 Daughterboard Replacement: step 7, image 1 of 3 Samsung Galaxy Note20 Daughterboard Replacement: step 7, image 2 of 3 Samsung Galaxy Note20 Daughterboard Replacement: step 7, image 3 of 3
      Buy
      • Use a pair of tweezers to lift up and flip back the motherboard shield.
      • Be careful when handling the motherboard shield because its edges are thin and sharp.
      Ask FixBot
    3. Samsung Galaxy Note20 Daughterboard Replacement, Disconnect the battery: step 8, image 1 of 2 Samsung Galaxy Note20 Daughterboard Replacement, Disconnect the battery: step 8, image 2 of 2
      • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
      • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    4. Samsung Galaxy Note20 Daughterboard Replacement, Disconnect the wireless charging coil: step 9, image 1 of 2 Samsung Galaxy Note20 Daughterboard Replacement, Disconnect the wireless charging coil: step 9, image 2 of 2
      • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
      Ask FixBot
    5. Samsung Galaxy Note20 Daughterboard Replacement, Remove the wireless charging coil: step 10, image 1 of 3 Samsung Galaxy Note20 Daughterboard Replacement, Remove the wireless charging coil: step 10, image 2 of 3 Samsung Galaxy Note20 Daughterboard Replacement, Remove the wireless charging coil: step 10, image 3 of 3
      • Grip the motherboard shield with your fingers.
      • Peel the wireless charging coil up and away from the device.
      • The wireless charging coil is secured to the device with light adhesive.
      • Remove the wireless charging coil.
      Ask FixBot
    1. Samsung Galaxy Note20 Daughterboard Replacement, Unscrew the loudspeaker: step 11, image 1 of 1
      • Use a Phillips screwdriver to unscrew the five 4.0 mm screws securing the loudspeaker to the frame.
      Ask FixBot
    2. Samsung Galaxy Note20 Daughterboard Replacement, Remove the loudspeaker: step 12, image 1 of 3 Samsung Galaxy Note20 Daughterboard Replacement, Remove the loudspeaker: step 12, image 2 of 3 Samsung Galaxy Note20 Daughterboard Replacement, Remove the loudspeaker: step 12, image 3 of 3
      Buy
      • Insert the pointed end of a spudger underneath the loudspeaker near its top left screw hole.
      • Use the spudger to pry up and detach the loudspeaker from the frame.
      • Use a pair of tweezers to lift and remove the loudspeaker.
      • Take care not to puncture or bend the battery with your tweezers—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
      Ask FixBot
    1. Samsung Galaxy Note20 Daughterboard Replacement, Disconnect the interconnect cables: step 13, image 1 of 2 Samsung Galaxy Note20 Daughterboard Replacement, Disconnect the interconnect cables: step 13, image 2 of 2
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
      Ask FixBot
    2. Samsung Galaxy Note20 Daughterboard Replacement: step 14, image 1 of 2 Samsung Galaxy Note20 Daughterboard Replacement: step 14, image 2 of 2
      • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
      Ask FixBot
    3. Samsung Galaxy Note20 Daughterboard Replacement: step 15, image 1 of 2 Samsung Galaxy Note20 Daughterboard Replacement: step 15, image 2 of 2
      • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
      Ask FixBot
    4. Samsung Galaxy Note20 Daughterboard Replacement: step 16, image 1 of 2 Samsung Galaxy Note20 Daughterboard Replacement: step 16, image 2 of 2
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
      Ask FixBot
    1. Samsung Galaxy Note20 Daughterboard Replacement, Remove the daughterboard: step 17, image 1 of 1
      • Use a Phillips screwdriver to remove the 2.9 mm screw securing the daughterboard to the frame.
      Ask FixBot
    2. Samsung Galaxy Note20 Daughterboard Replacement: step 18, image 1 of 2 Samsung Galaxy Note20 Daughterboard Replacement: step 18, image 2 of 2
      • The daughterboard is fitted to the frame by three spring connectors along its bottom edge.
      • Insert the pointed end of a spudger under the right side of the daughterboard near the screw boss.
      • Use the spudger to pry up and detach the daughterboard from the frame.
      • There are small surface-mounted components underneath the daughterboard. Only insert the spudger as far as necessary to avoid damaging the components.
      Ask FixBot
    3. Samsung Galaxy Note20 Daughterboard Replacement: step 19, image 1 of 2 Samsung Galaxy Note20 Daughterboard Replacement: step 19, image 2 of 2
      Buy
      • Use a pair of tweezers to lift and remove the daughterboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
Kyle Smith
53,269 Reputation
124 Guides authored
1 Guide Comment
Thanks for these instructions. Though how do I remove the button shaped thing with "J50" on it?
Rebecca Gray - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 75
All Time: 2,083
