Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement
    1. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Heat the rear cover: step 1, image 1 of 1
      • Completely power off your phone before you begin disassembly.
      • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      Ask FixBot
    3. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Begin to slice the adhesive: step 3, image 1 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Begin to slice the adhesive: step 3, image 2 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Begin to slice the adhesive: step 3, image 3 of 3
      • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
      • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Slice around the perimeter of the phone: step 4, image 1 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Slice around the perimeter of the phone: step 4, image 2 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Slice around the perimeter of the phone: step 4, image 3 of 3
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
      • The rear cover will begin to separate from the phone as you finish all sides of the phone.
      Ask FixBot
    5. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Lift off the rear cover: step 5, image 1 of 2 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Lift off the rear cover: step 5, image 2 of 2
      • Lift the rear cover straight up to remove it.
      • Follow this guide to reinstall the rear cover and replace the adhesive.
      • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
      • If you're using Tesa tape to reattach components, follow this guide.
      Ask FixBot
    1. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Lift up the metal cover: step 6, image 1 of 1
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
      Ask FixBot
    2. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 7, image 1 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 7, image 2 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
      Ask FixBot
    3. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Disconnect the battery: step 8, image 1 of 2 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Disconnect the battery: step 8, image 2 of 2
      • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
      Ask FixBot
    4. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Disconnect the wireless charging coil: step 9, image 1 of 2 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Disconnect the wireless charging coil: step 9, image 2 of 2
      • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
      Ask FixBot
    5. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the wireless charging coil: step 10, image 1 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the wireless charging coil: step 10, image 2 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the wireless charging coil: step 10, image 3 of 3
      • Tilt the metal shielding up so you can grip it with your fingers.
      • Peel the wireless charging coil up and away from the device.
      • The wireless charging coil is secured to the phone with some light adhesive.
      • Remove the wireless charging coil.
      Ask FixBot
    1. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the loudspeaker screws: step 11, image 1 of 1
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
      Ask FixBot
    2. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the loudspeaker: step 12, image 1 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the loudspeaker: step 12, image 2 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the loudspeaker: step 12, image 3 of 3
      Buy
      • Use a pair of tweezers to remove the loudspeaker.
      Ask FixBot
    1. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Disconnect the interconnect cables: step 13, image 1 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Disconnect the interconnect cables: step 13, image 2 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Disconnect the interconnect cables: step 13, image 3 of 3
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
      • Disconnect the secondary interconnect cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 14, image 1 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 14, image 2 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 14, image 3 of 3
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
      • Disconnect the secondary interconnect cable from the daughterboard.
      Ask FixBot
    3. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 15, image 1 of 1
      • Remove the main interconnect cable.
      Ask FixBot
    4. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 16, image 1 of 2 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 16, image 2 of 2
      • Don't try to remove the secondary interconnect cable. The cable is connected to the side 5G mmWave antenna.
      • Use a spudger or your fingers to gently fold the secondary interconnect cable away from the battery.
      Ask FixBot
    1. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the daughterboard: step 17, image 1 of 1
      • Use a Phillips screwdriver to remove the three 4 mm screws securing the charging assembly daughterboard.
      Ask FixBot
    2. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 18, image 1 of 2 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 18, image 2 of 2
      • Use the pointed end of a spudger to pivot the daughterboard out of its recess.
      Ask FixBot
    3. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 19, image 1 of 2 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement: step 19, image 2 of 2
      Buy
      • Use a pair of tweezers to lift up and remove the daughterboard.
      Ask FixBot
    1. Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the vibration motor: step 20, image 1 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the vibration motor: step 20, image 2 of 3 Samsung Galaxy Note10 Plus 5G Vibration Motor Replacement, Remove the vibration motor: step 20, image 3 of 3
      Buy
      • Use a pair of tweezers to pull the vibration motor out of its recess in the frame.
      • The vibration motor is secured with some light adhesive.
      • Whenever you use tweezers near the battery, be very careful not to puncture the battery.
      • Remove the vibration motor.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Arthur Shi
346,983 Reputation
923 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,581 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 35
All Time: 1,054
