Samsung Galaxy Note10 Motherboard Replacement
    1. Samsung Galaxy Note10 Motherboard Replacement, Heat the back panel: step 1, image 1 of 1
      • Completely power off your phone before you begin disassembly.
      • Prepare an iOpener and apply it to the left edge of the back panel for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy Note10 Motherboard Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
      • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
      • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      Ask FixBot
    3. Samsung Galaxy Note10 Motherboard Replacement, Begin to slice the adhesive: step 3, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement, Begin to slice the adhesive: step 3, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement, Begin to slice the adhesive: step 3, image 3 of 3
      • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
      • Do not insert the opening pick more than halfway into the phone or you risk damaging internal components.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Samsung Galaxy Note10 Motherboard Replacement, Slice the left side adhesive: step 4, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement, Slice the left side adhesive: step 4, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement, Slice the left side adhesive: step 4, image 3 of 3
      • Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive.
      • Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. Samsung Galaxy Note10 Motherboard Replacement, Slice the top side adhesive: step 5, image 1 of 1
      • Prepare an iOpener and apply it to the top edge of the phone for one minute.
      Ask FixBot
    6. Samsung Galaxy Note10 Motherboard Replacement: step 6, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement: step 6, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement: step 6, image 3 of 3
      • Insert a third opening pick into the gap on the top edge of the phone.
      • Slide the opening pick to the top right corner, slicing the adhesive.
      • Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    7. Samsung Galaxy Note10 Motherboard Replacement, Slice the right side adhesive: step 7, image 1 of 1
      • Prepare an iOpener and apply it to the right edge of the phone for one minute.
      Ask FixBot
    8. Samsung Galaxy Note10 Motherboard Replacement: step 8, image 1 of 2 Samsung Galaxy Note10 Motherboard Replacement: step 8, image 2 of 2
      • Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive.
      • The back panel will begin to separate from the phone as you get closer to the bottom edge.
      • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
      Ask FixBot
    9. Samsung Galaxy Note10 Motherboard Replacement, Lift off the back panel: step 9, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement, Lift off the back panel: step 9, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement, Lift off the back panel: step 9, image 3 of 3
      • Lift up and remove the back panel.
      Ask FixBot
    1. Samsung Galaxy Note10 Motherboard Replacement, Lift up the metal cover: step 10, image 1 of 1
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
      Ask FixBot
    2. Samsung Galaxy Note10 Motherboard Replacement: step 11, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement: step 11, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement: step 11, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
      Ask FixBot
    3. Samsung Galaxy Note10 Motherboard Replacement, Disconnect the battery: step 12, image 1 of 2 Samsung Galaxy Note10 Motherboard Replacement, Disconnect the battery: step 12, image 2 of 2
      • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
      Ask FixBot
    4. Samsung Galaxy Note10 Motherboard Replacement, Disconnect the wireless charging coil: step 13, image 1 of 2 Samsung Galaxy Note10 Motherboard Replacement, Disconnect the wireless charging coil: step 13, image 2 of 2
      • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
      Ask FixBot
    5. Samsung Galaxy Note10 Motherboard Replacement, Remove the wireless charging coil: step 14, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the wireless charging coil: step 14, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the wireless charging coil: step 14, image 3 of 3
      • Tilt the metal shielding up so you can grip it with your fingers.
      • Peel the wireless charging coil up and away from the device.
      • The wireless charging coil is secured to the phone with some light adhesive.
      • Remove the wireless charging coil.
      Ask FixBot
    1. Samsung Galaxy Note10 Motherboard Replacement, Front-Facing Camera: step 15, image 1 of 1
      • Use a Phillips screwdriver to remove the four 4 mm screws securing the top plastic cover.
      Ask FixBot
    2. Samsung Galaxy Note10 Motherboard Replacement: step 16, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement: step 16, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement: step 16, image 3 of 3
      Buy
      • Use a pair of tweezers to pivot the top plastic cover up and off of the phone.
      Ask FixBot
    3. Samsung Galaxy Note10 Motherboard Replacement: step 17, image 1 of 2 Samsung Galaxy Note10 Motherboard Replacement: step 17, image 2 of 2
      • Use the pointed end of a spudger to pry the front-facing camera connector straight up from the motherboard.
      Ask FixBot
    4. Samsung Galaxy Note10 Motherboard Replacement: step 18, image 1 of 2 Samsung Galaxy Note10 Motherboard Replacement: step 18, image 2 of 2
      • Remove the front-facing camera.
      Ask FixBot
    1. Samsung Galaxy Note10 Motherboard Replacement, Remove the loudspeaker screws: step 19, image 1 of 1
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
      Ask FixBot
    2. Samsung Galaxy Note10 Motherboard Replacement, Remove the loudspeaker: step 20, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the loudspeaker: step 20, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the loudspeaker: step 20, image 3 of 3
      Buy
      • Use a pair of tweezers to remove the loudspeaker.
      Ask FixBot
    1. Samsung Galaxy Note10 Motherboard Replacement, Remove the interconnect cables: step 21, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the interconnect cables: step 21, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the interconnect cables: step 21, image 3 of 3
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
      • Disconnect the secondary interconnect cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy Note10 Motherboard Replacement: step 22, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement: step 22, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement: step 22, image 3 of 3
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
      • Disconnect the secondary interconnect cable from the daughterboard.
      Ask FixBot
    3. Samsung Galaxy Note10 Motherboard Replacement: step 23, image 1 of 2 Samsung Galaxy Note10 Motherboard Replacement: step 23, image 2 of 2
      • Remove both interconnect cables.
      Ask FixBot
    1. Samsung Galaxy Note10 Motherboard Replacement, Remove the SIM card tray: step 24, image 1 of 2 Samsung Galaxy Note10 Motherboard Replacement, Remove the SIM card tray: step 24, image 2 of 2
      • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the top edge of the phone.
      • Press firmly to eject the tray.
      • Remove the SIM card tray.
      Ask FixBot
    1. Samsung Galaxy Note10 Motherboard Replacement, Disconnect motherboard connectors: step 25, image 1 of 2 Samsung Galaxy Note10 Motherboard Replacement, Disconnect motherboard connectors: step 25, image 2 of 2
      • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy Note10 Motherboard Replacement: step 26, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement: step 26, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement: step 26, image 3 of 3
      • Use the pointed end of a spudger to disconnect the side button connector from the motherboard.
      • Disconnect the touch layer connector from the motherboard.
      Ask FixBot
    3. Samsung Galaxy Note10 Motherboard Replacement: step 27, image 1 of 2 Samsung Galaxy Note10 Motherboard Replacement: step 27, image 2 of 2
      • Use the pointed end of a spudger to disconnect the S-Pen charging coil connector from the motherboard.
      Ask FixBot
    4. Samsung Galaxy Note10 Motherboard Replacement, Remove the motherboard: step 28, image 1 of 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the motherboard: step 28, image 2 of 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the motherboard: step 28, image 3 of 3
      • Use the pointed end of a spudger to pry up the motherboard enough to grip it with your fingers.
      • Remove the motherboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 other people completed this guide.
Carsten Frauenheim
171,545 Reputation
441 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
1 Guide Comment
missing steps to remove piece above the wireless coil. You guys went from wireless coil to the bottom of the phone to remove the daughter board and skipped entirely how to remove the top piece above the coil.
Jose - Reply Share
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 127
All Time: 8,027
