Up to 20% off select tools
Samsung Galaxy Note10+ 5G Battery Replacement
Views: 10K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
200
All Time:
10,456
Comments: 8
7 comments on steps, 1 guide comment.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove or replace the battery on your Samsung Galaxy Note10+ 5G.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
This guide uses steps written for the non-5G Note10+. Some images in this guide may show minor discontinuities. They shouldn’t affect the overall guide procedure.
    1. Samsung Galaxy Note10+ 5G Battery Replacement, Heat the rear cover: step 1, image 1 of 1
      • Completely power off your phone before you begin disassembly.
      • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy Note10+ 5G Battery Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      Ask FixBot
    3. Samsung Galaxy Note10+ 5G Battery Replacement, Begin to slice the adhesive: step 3, image 1 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Begin to slice the adhesive: step 3, image 2 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Begin to slice the adhesive: step 3, image 3 of 3
      • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
      • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Samsung Galaxy Note10+ 5G Battery Replacement, Slice around the perimeter of the phone: step 4, image 1 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Slice around the perimeter of the phone: step 4, image 2 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Slice around the perimeter of the phone: step 4, image 3 of 3
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
      • The rear cover will begin to separate from the phone as you finish all sides of the phone.
      Ask FixBot
    5. Samsung Galaxy Note10+ 5G Battery Replacement, Lift off the rear cover: step 5, image 1 of 2 Samsung Galaxy Note10+ 5G Battery Replacement, Lift off the rear cover: step 5, image 2 of 2
      • Lift the rear cover straight up to remove it.
      • Follow this guide to reinstall the rear cover and replace the adhesive.
      • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
      • If you're using Tesa tape to reattach components, follow this guide.
      Ask FixBot
    1. Samsung Galaxy Note10+ 5G Battery Replacement, Lift up the metal cover: step 6, image 1 of 1
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
      Ask FixBot
    2. Samsung Galaxy Note10+ 5G Battery Replacement: step 7, image 1 of 3 Samsung Galaxy Note10+ 5G Battery Replacement: step 7, image 2 of 3 Samsung Galaxy Note10+ 5G Battery Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
      Ask FixBot
    3. Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the battery: step 8, image 1 of 2 Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the battery: step 8, image 2 of 2
      • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
      Ask FixBot
    4. Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the wireless charging coil: step 9, image 1 of 2 Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the wireless charging coil: step 9, image 2 of 2
      • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
      Ask FixBot
    5. Samsung Galaxy Note10+ 5G Battery Replacement, Remove the wireless charging coil: step 10, image 1 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the wireless charging coil: step 10, image 2 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the wireless charging coil: step 10, image 3 of 3
      • Tilt the metal shielding up so you can grip it with your fingers.
      • Peel the wireless charging coil up and away from the device.
      • The wireless charging coil is secured to the phone with some light adhesive.
      • Remove the wireless charging coil.
      Ask FixBot
    1. Samsung Galaxy Note10+ 5G Battery Replacement, Remove the loudspeaker screws: step 11, image 1 of 1
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
      Ask FixBot
    2. Samsung Galaxy Note10+ 5G Battery Replacement, Remove the loudspeaker: step 12, image 1 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the loudspeaker: step 12, image 2 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the loudspeaker: step 12, image 3 of 3
      Buy
      • Use a pair of tweezers to remove the loudspeaker.
      Ask FixBot
    1. Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the interconnect cables: step 13, image 1 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the interconnect cables: step 13, image 2 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the interconnect cables: step 13, image 3 of 3
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
      • Disconnect the secondary interconnect cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy Note10+ 5G Battery Replacement: step 14, image 1 of 3 Samsung Galaxy Note10+ 5G Battery Replacement: step 14, image 2 of 3 Samsung Galaxy Note10+ 5G Battery Replacement: step 14, image 3 of 3
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
      • Disconnect the secondary interconnect cable from the daughterboard.
      Ask FixBot
    3. Samsung Galaxy Note10+ 5G Battery Replacement: step 15, image 1 of 1
      • Remove the main interconnect cable.
      Ask FixBot
    4. Samsung Galaxy Note10+ 5G Battery Replacement: step 16, image 1 of 2 Samsung Galaxy Note10+ 5G Battery Replacement: step 16, image 2 of 2
      • Don't try to remove the secondary interconnect cable. The cable is connected to the side 5G mmWave antenna.
      • Use a spudger or your fingers to gently fold the secondary interconnect cable away from the battery.
      Ask FixBot
    1. Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the display cable: step 17, image 1 of 2 Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the display cable: step 17, image 2 of 2
      • Use the pointed end of a spudger to disconnect the display cable connector from the motherboard.
      Ask FixBot
    2. Samsung Galaxy Note10+ 5G Battery Replacement, Loosen the battery adhesive: step 18, image 1 of 2 Samsung Galaxy Note10+ 5G Battery Replacement, Loosen the battery adhesive: step 18, image 2 of 2
      • Apply 1-2 drops of high concentration (90% or greater) isopropyl alcohol underneath the battery at the tear-shaped indents near the corners of the battery well.
      • Using too much alcohol can damage the display.
      • Wait for a minute for the isopropyl alcohol to penetrate and weaken the battery adhesive before you proceed to the next step.
      Ask FixBot
    3. Samsung Galaxy Note10+ 5G Battery Replacement, Remove the battery: step 19, image 1 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the battery: step 19, image 2 of 3 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the battery: step 19, image 3 of 3
      • Apply a suction cup to the back of the battery.
      • Pull up on the suction cup with strong, steady force to begin to separate the battery from the frame.
      • If this is difficult, apply a few more drops of isopropyl alcohol underneath the battery, let it sit for two minutes, and try again.
      • Insert the point of an opening pick into the gap created between the battery and frame.
      • Don't insert the opening pick more than halfway or you risk damaging the fingerprint sensor underneath.
      • Pull up on the suction cup to remove the battery.
      • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
      • When you're reassembling your phone, remove the old adhesive and apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
8 other people completed this guide.
Author
with
Arthur Shi
354,431 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Guide Comment
Nice l solve my problem
Abdulsalam Murait - Reply Share
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 200
All Time: 10,456
