Up to 20% off select tools
Samsung Galaxy Note USB Board Replacement
Views: 26K
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
119
All Time:
25,505
Comments: 9
3 comments on steps, 6 guide comments.
Go to guide comments
Completed: 51
51 people have marked this guide "completed." Will you be next?
Favorites: 24
24 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove or replace the Note's USB board/daughterboard
    1. Samsung Galaxy Note USB Board Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note USB Board Replacement, Stylus: step 1, image 2 of 2
      • Grasp the cap of the stylus and remove it from its slot in the midframe.
      Ask FixBot
    1. Samsung Galaxy Note USB Board Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note USB Board Replacement, Rear Case: step 2, image 2 of 2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
      Ask FixBot
    2. Samsung Galaxy Note USB Board Replacement: step 3, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 3, image 2 of 2
      • Lift and remove the rear case from the phone.
      Ask FixBot
    1. Samsung Galaxy Note USB Board Replacement, Battery: step 4, image 1 of 2 Samsung Galaxy Note USB Board Replacement, Battery: step 4, image 2 of 2
      • Insert your finger in the notch of the battery compartment.
      • Press the battery toward the rear facing camera while pulling outward.
      Ask FixBot
    1. Samsung Galaxy Note USB Board Replacement, MicroSD Card: step 5, image 1 of 3 Samsung Galaxy Note USB Board Replacement, MicroSD Card: step 5, image 2 of 3 Samsung Galaxy Note USB Board Replacement, MicroSD Card: step 5, image 3 of 3
      • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      Ask FixBot
    2. Samsung Galaxy Note USB Board Replacement: step 6, image 1 of 1
      • Remove the microSD card from its slot in the midframe.
      Ask FixBot
    1. Samsung Galaxy Note USB Board Replacement, SIM Card: step 7, image 1 of 2 Samsung Galaxy Note USB Board Replacement, SIM Card: step 7, image 2 of 2
      • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
      Ask FixBot
    2. Samsung Galaxy Note USB Board Replacement: step 8, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 8, image 2 of 2
      • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
      Ask FixBot
    1. Samsung Galaxy Note USB Board Replacement, Midframe: step 9, image 1 of 1
      • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
      Ask FixBot
    2. Samsung Galaxy Note USB Board Replacement: step 10, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 10, image 2 of 2
      • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
      Ask FixBot
    3. Samsung Galaxy Note USB Board Replacement: step 11, image 1 of 3 Samsung Galaxy Note USB Board Replacement: step 11, image 2 of 3 Samsung Galaxy Note USB Board Replacement: step 11, image 3 of 3
      • Slide the plastic opening tool down the seam.
      Ask FixBot
    4. Samsung Galaxy Note USB Board Replacement: step 12, image 1 of 3 Samsung Galaxy Note USB Board Replacement: step 12, image 2 of 3 Samsung Galaxy Note USB Board Replacement: step 12, image 3 of 3
      • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
      • Slide the opening tool along the top edge of the phone.
      • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
      Ask FixBot
    5. Samsung Galaxy Note USB Board Replacement: step 13, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 13, image 2 of 2
      • Remove the midframe from the display assembly.
      Ask FixBot
    1. Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: step 14, image 1 of 2 Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: step 14, image 2 of 2
      • Use the flat end of a spudger to carefully disconnect the display cable connector.
      Ask FixBot
    2. Samsung Galaxy Note USB Board Replacement: step 15, image 1 of 3 Samsung Galaxy Note USB Board Replacement: step 15, image 2 of 3 Samsung Galaxy Note USB Board Replacement: step 15, image 3 of 3
      • Use a spudger to disconnect the front-facing camera assembly cable connector.
      • Disconnect the headphone jack/earpiece speaker assembly cable connector.
      • Disconnect the digitizer cable connector.
      Ask FixBot
    3. Samsung Galaxy Note USB Board Replacement: step 16, image 1 of 3 Samsung Galaxy Note USB Board Replacement: step 16, image 2 of 3 Samsung Galaxy Note USB Board Replacement: step 16, image 3 of 3
      • Disconnect the soft button cable connector with the flat end of a spudger.
      • Use a spudger to disconnect the USB board cable connector.
      • Disconnect the antenna cable connector.
      Ask FixBot
    4. Samsung Galaxy Note USB Board Replacement: step 17, image 1 of 1
      • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
      Ask FixBot
    5. Samsung Galaxy Note USB Board Replacement: step 18, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 18, image 2 of 2
      • Remove the motherboard assembly from the display assembly.
      Ask FixBot
    1. Samsung Galaxy Note USB Board Replacement, USB Board: step 19, image 1 of 1
      • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
      Ask FixBot
    2. Samsung Galaxy Note USB Board Replacement: step 20, image 1 of 1
      • Lift the speaker enclosure from the display assembly.
      Ask FixBot
    3. Samsung Galaxy Note USB Board Replacement: step 21, image 1 of 2 Samsung Galaxy Note USB Board Replacement: step 21, image 2 of 2
      • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
      • Remove the antenna cable.
      Ask FixBot
    4. Samsung Galaxy Note USB Board Replacement: step 22, image 1 of 3 Samsung Galaxy Note USB Board Replacement: step 22, image 2 of 3 Samsung Galaxy Note USB Board Replacement: step 22, image 3 of 3
      • Push the flat end of a spudger under the USB board to separate it from the display assembly.
      • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
      Ask FixBot
    5. Samsung Galaxy Note USB Board Replacement: step 23, image 1 of 1
      • Remove the USB board.
      Ask FixBot
51 other people completed this guide.
Author
with
Sam Goldheart
478,973 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
6 Guide Comments
Using the Guides on online and the PDF guides made this repair easy and quick!
Joe - Reply Share
It's not necessary to remove the motherboard (steps 17 and 18) to complete this repair. The flat flex running to the USB board can be easily slid out from under the motherboard with the motherboard still in position. Just omit steps 17 and 18 and the rest of the procedure works fine. I've done it twice.
Phil - Reply Share
Where in England could I buy the USB Board part?
Craig Pyle - Reply Share
USB board bought off ebay. Didnt need plastic opening tools, thumb nail worked easier than expected.
john dingley - Reply Share
It's not the Galaxy Note GT-N7000!
costantino - Reply Share
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 119
All Time: 25,505
