Samsung Galaxy Note Speaker Enclosure Replacement
    1. Samsung Galaxy Note Speaker Enclosure Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement, Stylus: step 1, image 2 of 2
      • Grasp the cap of the stylus and remove it from its slot in the midframe.
      Ask FixBot
    1. Samsung Galaxy Note Speaker Enclosure Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement, Rear Case: step 2, image 2 of 2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
      Ask FixBot
    2. Samsung Galaxy Note Speaker Enclosure Replacement: step 3, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement: step 3, image 2 of 2
      • Lift and remove the rear case from the phone.
      Ask FixBot
    1. Samsung Galaxy Note Speaker Enclosure Replacement, Battery: step 4, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement, Battery: step 4, image 2 of 2
      • Insert your finger in the notch of the battery compartment.
      • Press the battery toward the rear facing camera while pulling outward.
      Ask FixBot
    1. Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: step 5, image 1 of 3 Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: step 5, image 2 of 3 Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: step 5, image 3 of 3
      • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      Ask FixBot
    2. Samsung Galaxy Note Speaker Enclosure Replacement: step 6, image 1 of 1
      • Remove the microSD card from its slot in the midframe.
      Ask FixBot
    1. Samsung Galaxy Note Speaker Enclosure Replacement, SIM Card: step 7, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement, SIM Card: step 7, image 2 of 2
      • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
      Ask FixBot
    2. Samsung Galaxy Note Speaker Enclosure Replacement: step 8, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement: step 8, image 2 of 2
      • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
      Ask FixBot
    1. Samsung Galaxy Note Speaker Enclosure Replacement, Midframe: step 9, image 1 of 1
      • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
      Ask FixBot
    2. Samsung Galaxy Note Speaker Enclosure Replacement: step 10, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement: step 10, image 2 of 2
      • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
      Ask FixBot
    3. Samsung Galaxy Note Speaker Enclosure Replacement: step 11, image 1 of 3 Samsung Galaxy Note Speaker Enclosure Replacement: step 11, image 2 of 3 Samsung Galaxy Note Speaker Enclosure Replacement: step 11, image 3 of 3
      • Slide the plastic opening tool down the seam.
      Ask FixBot
    4. Samsung Galaxy Note Speaker Enclosure Replacement: step 12, image 1 of 3 Samsung Galaxy Note Speaker Enclosure Replacement: step 12, image 2 of 3 Samsung Galaxy Note Speaker Enclosure Replacement: step 12, image 3 of 3
      • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
      • Slide the opening tool along the top edge of the phone.
      • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
      Ask FixBot
    5. Samsung Galaxy Note Speaker Enclosure Replacement: step 13, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement: step 13, image 2 of 2
      • Remove the midframe from the display assembly.
      Ask FixBot
    1. Samsung Galaxy Note Speaker Enclosure Replacement, Speaker Enclosure: step 14, image 1 of 1
      • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
      Ask FixBot
    2. Samsung Galaxy Note Speaker Enclosure Replacement: step 15, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement: step 15, image 2 of 2
      • Remove the speaker enclosure from the display assembly.
      Ask FixBot
6 other people completed this guide.
Sam Goldheart
478,447 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 110
All Time: 7,855
