Up to 20% off select tools
Samsung Galaxy Note SD Card Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
19
All Time:
1,321
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Easy
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The SD card holds your phone's external memory. Replace or remove the SD card if you want to change how your phone deals with memory storage. Check the device's troubleshooting page if you think your SD card is malfunctioning.
    1. Samsung Galaxy Note SD Card Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Note SD Card Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Note SD Card Replacement, Battery: step 1, image 3 of 3
      • Make sure the screen is face-down and the camera is opposite you.
      • Insert the flat end of a spudger into the phone's top right rectangular slot.
      • Use the spudger as a lever to pry open the back of the phone.
      Ask FixBot
    2. Samsung Galaxy Note SD Card Replacement: step 2, image 1 of 1
      • With the spudger still inserted, carefully slide the spudger down the side of the phone.
      • Gently peel off the back cover with your hand.
      Ask FixBot
    3. Samsung Galaxy Note SD Card Replacement: step 3, image 1 of 1
      • Place the spudger in the battery's bottom right slot.
      • Gently pry to remove the battery.
      Ask FixBot
    1. Samsung Galaxy Note SD Card Replacement, SD Card: step 4, image 1 of 1
      • Pull out the micro SD card located in the upper right slot (above the battery).
      Ask FixBot
3 other people completed this guide.
Author
with
David Ritter
758 Reputation
6 Guides authored
Cal Poly, Team 3-45, Amido Spring 2013 Member of Cal Poly, Team 3-45, Amido Spring 2013
CPSU-AMIDO-S13S3G45
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 1,321
