Samsung Galaxy Note Pro 12.2 SD Port Replacement
  1. Samsung Galaxy Note Pro 12.2 SD Port Replacement, SD Port: step 1, image 1 of 1
    • Turn off your device before starting your repair.
    • Carefully remove the back cover with the plastic opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 SD Port Replacement: step 2, image 1 of 2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: step 2, image 2 of 2
    • Pop up the orange tab connected to the SD port with the plastic opening tool.
  3. Samsung Galaxy Note Pro 12.2 SD Port Replacement: step 3, image 1 of 2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: step 3, image 2 of 2
    • Remove the one 3mm Phillips #00 screw connected to the SD port.
  4. Samsung Galaxy Note Pro 12.2 SD Port Replacement: step 4, image 1 of 2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Pop open the orange wire tab connected to the SD port with the plastic opening tool.
    • If there is tape covering your tab, remove it with the tweezers before you pop open the tab.
  5. Samsung Galaxy Note Pro 12.2 SD Port Replacement: step 5, image 1 of 2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: step 5, image 2 of 2
    • Using the orange tab, pull the SD port up and away from the device.
  6. Samsung Galaxy Note Pro 12.2 SD Port Replacement: step 6, image 1 of 1
    • Using the plastic end of the tweezers pop up the orange tab connecting the SD port to the device.
    • There is a little indent below the orange tab to help get under this piece. It may be difficult to remove, push up hard.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 677
