Samsung Galaxy Note Pro 12.2 Motherboard Replacement
  1. Samsung Galaxy Note Pro 12.2 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Remove the back cover with the blue plastic opening tool.
  2. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: step 2, image 1 of 2 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: step 2, image 2 of 2
    • Disconnect the five base connectors from the motherboard by using the blue opening tool to carefully remove the connectors.
  3. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: step 3, image 1 of 2 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: step 3, image 2 of 2
    • Remove the yellow tape on the ribbon cables before attempting to disconnect them from the motherboard.
    • Using the blue opening tool, pry on the black tab at the base connector of ribbon cables until it is flipped up and moves with ease. Then, pull the ribbon cable from the base connectors of the motherboard.
  4. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: step 4, image 1 of 2 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Potential damage to the motherboard could occur without supporting the black motherboard connector as the white cable connector is being removed.
    • Remove the power cable from the motherboard by prying slightly on both sides of the clip using tweezers.
  5. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: step 5, image 1 of 3 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: step 5, image 2 of 3 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: step 5, image 3 of 3
    • Remove all three of the 3.0 mm screws using the Phillips #00 screwdriver.
    • It is easiest to pry on the points depicted in the pictures for the next step.
    • Use the blue plastic opening tool to pry the speakers up from the clips that hold them in place.
  6. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: step 6, image 1 of 1
    • Remove the motherboard using the blue opening tool while keeping any wires and connectors out of the way.
    • The motherboard should come out freely.
2 other people completed this guide.
La'Taja Long
346 Reputation
3 Guides authored
IUPUI, Team S1-G3, Henning Fall 2019 Member of IUPUI, Team S1-G3, Henning Fall 2019
IUPUI-HENNING-F19S1G3
3 Members
3 Guides authored
1 Guide Comment
Hi. Can i install sm-p905 motherboard into my sm-p900?
yem44 - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 2,669
