Up to 20% off select tools
Samsung Galaxy Note Micro USB Port Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
38
All Time:
7,160
Comments: 0
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 50
50 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Tools
Introduction
Go to step 1 ↓
Refer to the device's troubleshooting page before replacing the micro USB port. If your Micro USB connection is not working properly, check the cord before replacing the port. Other reason's to replace the Micro USB include phone does not charge with a new charger or the Micro USB port malfunctions.
    1. Samsung Galaxy Note Micro USB Port Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Note Micro USB Port Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Note Micro USB Port Replacement, Battery: step 1, image 3 of 3
      • Make sure the screen is face-down and the camera is opposite you.
      • Insert the flat end of a spudger into the phone's top right rectangular slot.
      • Use the spudger as a lever to pry open the back of the phone.
      Ask FixBot
    2. Samsung Galaxy Note Micro USB Port Replacement: step 2, image 1 of 1
      • With the spudger still inserted, carefully slide the spudger down the side of the phone.
      • Gently peel off the back cover with your hand.
      Ask FixBot
    3. Samsung Galaxy Note Micro USB Port Replacement: step 3, image 1 of 1
      • Place the spudger in the battery's bottom right slot.
      • Gently pry to remove the battery.
      Ask FixBot
    1. Samsung Galaxy Note Micro USB Port Replacement, Midframe: step 4, image 1 of 1
      • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Galaxy Note Micro USB Port Replacement: step 5, image 1 of 1
      • Remove the stylus from the bottom of the phone.
      Ask FixBot
    3. Samsung Galaxy Note Micro USB Port Replacement: step 6, image 1 of 3 Samsung Galaxy Note Micro USB Port Replacement: step 6, image 2 of 3 Samsung Galaxy Note Micro USB Port Replacement: step 6, image 3 of 3
      • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
      • If the cover does not come off easily, continue to pry along the phone's perimeter.
      • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
      • Separate the midframe from the phone. The midframe should now pull off easily.
      Ask FixBot
    1. Samsung Galaxy Note Micro USB Port Replacement, Micro USB Port: step 7, image 1 of 1
      • Turn the phone so the screen is on the table and the USB port is facing you.
      • Disconnect the orange ribbon near the bottom of the device using a spudger.
      Ask FixBot
    2. Samsung Galaxy Note Micro USB Port Replacement: step 8, image 1 of 1
      • Remove the three 3mm screws on the bottom of the device with a Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung Galaxy Note Micro USB Port Replacement: step 9, image 1 of 1
      • Remove the black rectangular bracket imprinted with a "7" where you just removed the screws. The piece should pop off easily.
      • Disconnect the antenna (white wire) with a spudger by prying the metal part gently off.
      Ask FixBot
    4. Samsung Galaxy Note Micro USB Port Replacement: step 10, image 1 of 2 Samsung Galaxy Note Micro USB Port Replacement: step 10, image 2 of 2
      • Slide spudger under the USB port and gently drag it left and right to remove the port from the phone.
      • Adhesive keeps the USB port from moving, so it might not pull up right away.
      Ask FixBot
20 other people completed this guide.
Author
with
David Ritter
758 Reputation
6 Guides authored
Cal Poly, Team 3-45, Amido Spring 2013 Member of Cal Poly, Team 3-45, Amido Spring 2013
CPSU-AMIDO-S13S3G45
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 38
All Time: 7,160
