Up to 20% off select tools
Samsung Galaxy Note II USB Board Replacement
Views: 40K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
127
All Time:
39,951
Comments: 21
11 comments on steps, 10 guide comments.
Go to guide comments
Completed: 68
68 people have marked this guide "completed." Will you be next?
Favorites: 32
32 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the USB board in a Samsung Galaxy Note II.
    1. Samsung Galaxy Note II USB Board Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note II USB Board Replacement, Stylus: step 1, image 2 of 2
      • Grasp the end of the stylus and remove it from its slot in the midframe.
      Ask FixBot
    1. Samsung Galaxy Note II USB Board Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note II USB Board Replacement, Rear Case: step 2, image 2 of 2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
      Ask FixBot
    2. Samsung Galaxy Note II USB Board Replacement: step 3, image 1 of 3 Samsung Galaxy Note II USB Board Replacement: step 3, image 2 of 3 Samsung Galaxy Note II USB Board Replacement: step 3, image 3 of 3
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      Ask FixBot
    1. Samsung Galaxy Note II USB Board Replacement, MicroSD Card: step 4, image 1 of 3 Samsung Galaxy Note II USB Board Replacement, MicroSD Card: step 4, image 2 of 3 Samsung Galaxy Note II USB Board Replacement, MicroSD Card: step 4, image 3 of 3
      • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • Remove the microSD card.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      Ask FixBot
    1. Samsung Galaxy Note II USB Board Replacement, Battery: step 5, image 1 of 2 Samsung Galaxy Note II USB Board Replacement, Battery: step 5, image 2 of 2
      • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
      Ask FixBot
    2. Samsung Galaxy Note II USB Board Replacement: step 6, image 1 of 1
      • Remove the battery from the midframe.
      Ask FixBot
    1. Samsung Galaxy Note II USB Board Replacement, Midframe: step 7, image 1 of 1
      • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
      Ask FixBot
    2. Samsung Galaxy Note II USB Board Replacement: step 8, image 1 of 3 Samsung Galaxy Note II USB Board Replacement: step 8, image 2 of 3 Samsung Galaxy Note II USB Board Replacement: step 8, image 3 of 3
      • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
      • Slide the plastic opening tool down the seam.
      Ask FixBot
    3. Samsung Galaxy Note II USB Board Replacement: step 9, image 1 of 3 Samsung Galaxy Note II USB Board Replacement: step 9, image 2 of 3 Samsung Galaxy Note II USB Board Replacement: step 9, image 3 of 3
      • Continue to run the plastic opening tool down the seam.
      Ask FixBot
    4. Samsung Galaxy Note II USB Board Replacement: step 10, image 1 of 2 Samsung Galaxy Note II USB Board Replacement: step 10, image 2 of 2
      • Carefully pry around the corner with a plastic opening tool.
      Ask FixBot
    5. Samsung Galaxy Note II USB Board Replacement: step 11, image 1 of 2 Samsung Galaxy Note II USB Board Replacement: step 11, image 2 of 2
      • Pry along the top of the phone with a plastic opening tool.
      Ask FixBot
    6. Samsung Galaxy Note II USB Board Replacement: step 12, image 1 of 2 Samsung Galaxy Note II USB Board Replacement: step 12, image 2 of 2
      • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
      Ask FixBot
    7. Samsung Galaxy Note II USB Board Replacement: step 13, image 1 of 2 Samsung Galaxy Note II USB Board Replacement: step 13, image 2 of 2
      • Free the clips along the power button side of the phone.
      • Lastly, free the two clips along the top and bottom edge of battery compartment.
      Ask FixBot
    8. Samsung Galaxy Note II USB Board Replacement: step 14, image 1 of 2 Samsung Galaxy Note II USB Board Replacement: step 14, image 2 of 2
      • Lift the display assembly out of the midframe.
      Ask FixBot
    1. Samsung Galaxy Note II USB Board Replacement, Speaker Enclosure: step 15, image 1 of 1
      • Remove the 3 mm Phillips #00 screw from the speaker enclosure.
      Ask FixBot
    2. Samsung Galaxy Note II USB Board Replacement: step 16, image 1 of 1
      • Remove the speaker enclosure.
      Ask FixBot
    1. Samsung Galaxy Note II USB Board Replacement, USB Board: step 17, image 1 of 2 Samsung Galaxy Note II USB Board Replacement, USB Board: step 17, image 2 of 2
      • Using the flat end of a spudger, disconnect the USB board cable connector.
      • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
      Ask FixBot
    2. Samsung Galaxy Note II USB Board Replacement: step 18, image 1 of 2 Samsung Galaxy Note II USB Board Replacement: step 18, image 2 of 2
      • Push the flat end of a spudger under the USB board to separate it from the display assembly.
      • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
      Ask FixBot
    3. Samsung Galaxy Note II USB Board Replacement: step 19, image 1 of 1
      • Remove the USB board from the display assembly.
      Ask FixBot
68 other people completed this guide.
Author
with
Sam Goldheart
478,979 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
10 Guide Comments
Super easy thank you
jalamson - Reply Share
класс, только добавьте пожалуйста русский язык
abdul8477 - Reply Share
Very good tutorial of the process needed to do this repair. Sadly the one that I was trying to repair had been dropped and the circuit board right where the charge pcb attaches was physically cracked. Did not find that problem until actually removing the original part and throughly inspecting the connect area. Thank You again for an excellent tutorial and dialogue.
stubbie45 - Reply Share
Excellent tutorial regarding the disassembly of the Note II and replacement if the charge circuit board. Sadly the device i have had been dropped and the main circuit board where the charge PCB plugs into it was fractured. After removal of the original charge board through inspection noted the original problem was the cracked main PCB. :( Now I have a Note II with a good case and display but damaged main circuit board.
I replaced my USB board and success. However my speakers are not working now. Someone please guide me .
Elijah Williamson - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 127
All Time: 39,951
