Samsung Galaxy Note II Rear Facing Camera Assembly Replacement
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Stylus: step 1, image 2 of 2
      • Grasp the end of the stylus and remove it from its slot in the midframe.
      Ask FixBot
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Case: step 2, image 2 of 2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
      Ask FixBot
    2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 3, image 1 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 3, image 2 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 3, image 3 of 3
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      Ask FixBot
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: step 4, image 1 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: step 4, image 2 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: step 4, image 3 of 3
      • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • Remove the microSD card.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      Ask FixBot
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Battery: step 5, image 1 of 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Battery: step 5, image 2 of 2
      • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
      Ask FixBot
    2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 6, image 1 of 1
      • Remove the battery from the midframe.
      Ask FixBot
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Midframe: step 7, image 1 of 1
      • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
      Ask FixBot
    2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 8, image 1 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 8, image 2 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 8, image 3 of 3
      • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
      • Slide the plastic opening tool down the seam.
      Ask FixBot
    3. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 9, image 1 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 9, image 2 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 9, image 3 of 3
      • Continue to run the plastic opening tool down the seam.
      Ask FixBot
    4. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 10, image 1 of 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 10, image 2 of 2
      • Carefully pry around the corner with a plastic opening tool.
      Ask FixBot
    5. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 11, image 1 of 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 11, image 2 of 2
      • Pry along the top of the phone with a plastic opening tool.
      Ask FixBot
    6. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 12, image 1 of 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 12, image 2 of 2
      • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
      Ask FixBot
    7. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 13, image 1 of 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 13, image 2 of 2
      • Free the clips along the power button side of the phone.
      • Lastly, free the two clips along the top and bottom edge of battery compartment.
      Ask FixBot
    8. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 14, image 1 of 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 14, image 2 of 2
      • Lift the display assembly out of the midframe.
      Ask FixBot
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: step 15, image 1 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: step 15, image 2 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: step 15, image 3 of 3
      • Use a spudger to disconnect the vibrator/power button assembly cable connector.
      • Disconnect the antenna cable connector.
      • Disconnect the display cable connector.
      Ask FixBot
    2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 16, image 1 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 16, image 2 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 16, image 3 of 3
      • Disconnect the front-facing camera cable connector.
      • Disconnect the headphone jack cable connector.
      • Disconnect the digitizer cable connector.
      Ask FixBot
    3. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 17, image 1 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 17, image 2 of 3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 17, image 3 of 3
      • Use the spudger to disconnect the antenna cable connector from the motherboard.
      • Disconnect the soft button cable connector.
      • Disconnect the USB board cable connector.
      Ask FixBot
    4. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 18, image 1 of 1
      • Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
      Ask FixBot
    5. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 19, image 1 of 2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 19, image 2 of 2
      • Gently remove the motherboard.
      • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
      Ask FixBot
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Facing Camera Assembly: step 20, image 1 of 1
      • Use a spudger to disconnect the rear-facing camera assembly cable connector.
      Ask FixBot
    2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: step 21, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers, or your fingers, to remove the rear-facing camera assembly.
      Ask FixBot
13 other people completed this guide.
Sam Goldheart
478,447 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 111
All Time: 12,877
