Samsung Galaxy Note II Front Facing Camera Assembly Replacement
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Stylus: step 1, image 2 of 2
      • Grasp the end of the stylus and remove it from its slot in the midframe.
      Ask FixBot
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Rear Case: step 2, image 2 of 2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
      Ask FixBot
    2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 3, image 1 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 3, image 2 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 3, image 3 of 3
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      Ask FixBot
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: step 4, image 1 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: step 4, image 2 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: step 4, image 3 of 3
      • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • Remove the microSD card.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      Ask FixBot
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Battery: step 5, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Battery: step 5, image 2 of 2
      • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
      Ask FixBot
    2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 6, image 1 of 1
      • Remove the battery from the midframe.
      Ask FixBot
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Midframe: step 7, image 1 of 1
      • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
      Ask FixBot
    2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 8, image 1 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 8, image 2 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 8, image 3 of 3
      • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
      • Slide the plastic opening tool down the seam.
      Ask FixBot
    3. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 9, image 1 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 9, image 2 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 9, image 3 of 3
      • Continue to run the plastic opening tool down the seam.
      Ask FixBot
    4. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 10, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 10, image 2 of 2
      • Carefully pry around the corner with a plastic opening tool.
      Ask FixBot
    5. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 11, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 11, image 2 of 2
      • Pry along the top of the phone with a plastic opening tool.
      Ask FixBot
    6. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 12, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 12, image 2 of 2
      • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
      Ask FixBot
    7. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 13, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 13, image 2 of 2
      • Free the clips along the power button side of the phone.
      • Lastly, free the two clips along the top and bottom edge of battery compartment.
      Ask FixBot
    8. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 14, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 14, image 2 of 2
      • Lift the display assembly out of the midframe.
      Ask FixBot
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Front Facing Camera Assembly: step 15, image 1 of 1
      • Remove the 3mm Phillips #00 screw from the front-facing camera bracket.
      Ask FixBot
    2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 16, image 1 of 1
      • Remove the front-facing camera bracket.
      Ask FixBot
    3. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 17, image 1 of 1
      • Use the flat end of a spudger to disconnect the front-facing camera connector.
      Ask FixBot
    4. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 18, image 1 of 1
      • Remove the front-facing camera.
      Ask FixBot
13 other people completed this guide.
Sam Goldheart
478,447 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 29
Past 30 Days: 113
All Time: 12,549
