Up to 20% off select tools
Samsung Galaxy Note Edge Volume Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
60
All Time:
927
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you are unable to adjust the volume on your device, the volume switch may be faulty. Use this guide to replace the volume button in your device.
    1. Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: step 1, image 1 of 2 Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: step 1, image 2 of 2
      • Place your device flat down on a clean surface.
      • Use a Spudger to remove the back cover using the notch at the top left.
      Ask FixBot
    2. Samsung Galaxy Note Edge Volume Button Replacement: step 2, image 1 of 1
      • Use a Spudger to remove the battery using the notch located underneath the battery.
      • Note: During the creation of this guide, we did not have access to a battery.
      Ask FixBot
    3. Samsung Galaxy Note Edge Volume Button Replacement: step 3, image 1 of 1
      • Remove the stylus from its sheathe.
      Ask FixBot
    4. Samsung Galaxy Note Edge Volume Button Replacement: step 4, image 1 of 1
      • Use a Philips #000 Screwdriver to remove the fifteen 4mm screws.
      Ask FixBot
    5. Samsung Galaxy Note Edge Volume Button Replacement: step 5, image 1 of 1
      • Use a Spudger to remove the black chassis and expose the motherboard.
      Ask FixBot
    6. Samsung Galaxy Note Edge Volume Button Replacement: step 6, image 1 of 3 Samsung Galaxy Note Edge Volume Button Replacement: step 6, image 2 of 3 Samsung Galaxy Note Edge Volume Button Replacement: step 6, image 3 of 3
      • Use a Spudger to disconnect the following connections:
      • Connection 1
      • Connection 2
      • Connection 3
      Ask FixBot
    7. Samsung Galaxy Note Edge Volume Button Replacement: step 7, image 1 of 1
      • Remove the connection for the front camera.
      Ask FixBot
    8. Samsung Galaxy Note Edge Volume Button Replacement: step 8, image 1 of 3 Samsung Galaxy Note Edge Volume Button Replacement: step 8, image 2 of 3 Samsung Galaxy Note Edge Volume Button Replacement: step 8, image 3 of 3
      • Do not try to completely remove the motherboard until the final step.
      • Use a Spudger to gently lift the motherboard.
      • Remove the connection of the motherboard and the daughter board.
      • Remove the motherboard.
      Ask FixBot
    9. Samsung Galaxy Note Edge Volume Button Replacement: step 9, image 1 of 3 Samsung Galaxy Note Edge Volume Button Replacement: step 9, image 2 of 3 Samsung Galaxy Note Edge Volume Button Replacement: step 9, image 3 of 3
      • Remove the volume button panel.
      • Remove the volume button connection.
      • Remove the volume button entirely.
      Ask FixBot
Author
with
Lizzie Todd
301 Reputation
2 Guides authored
IUPUI, Team S1-G1, Harley Spring 2019 Member of IUPUI, Team S1-G1, Harley Spring 2019
IUPUI-HARLEY-S19S1G1
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 60
All Time: 927
