Samsung Galaxy Note Edge Motherboard Replacement
    1. Samsung Galaxy Note Edge Motherboard Replacement, Battery: step 1, image 1 of 1
      • Power down your device and make sure that it is turned off.
      • Place the phone with the screen facing down on a clean flat surface.
      Ask FixBot
    2. Samsung Galaxy Note Edge Motherboard Replacement: step 2, image 1 of 3 Samsung Galaxy Note Edge Motherboard Replacement: step 2, image 2 of 3 Samsung Galaxy Note Edge Motherboard Replacement: step 2, image 3 of 3
      • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
      • Remove battery by using your Supdger on the notch located directly underneath battery location.
      • During the creation of this guide, we did not have access to a battery in our device.
      Ask FixBot
    1. Samsung Galaxy Note Edge Motherboard Replacement, Motherboard: step 3, image 1 of 1
      • Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
      • Remove the stylus from the stylus holder.
      Ask FixBot
    2. Samsung Galaxy Note Edge Motherboard Replacement: step 4, image 1 of 3 Samsung Galaxy Note Edge Motherboard Replacement: step 4, image 2 of 3 Samsung Galaxy Note Edge Motherboard Replacement: step 4, image 3 of 3
      • Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
      • Insert your spudger into the stylus socket and pry the midframe from the phone.
      • Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
      Ask FixBot
    3. Samsung Galaxy Note Edge Motherboard Replacement: step 5, image 1 of 2 Samsung Galaxy Note Edge Motherboard Replacement: step 5, image 2 of 2
      • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
      • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
      Ask FixBot
    4. Samsung Galaxy Note Edge Motherboard Replacement: step 6, image 1 of 3 Samsung Galaxy Note Edge Motherboard Replacement: step 6, image 2 of 3 Samsung Galaxy Note Edge Motherboard Replacement: step 6, image 3 of 3
      • Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner:
      • Front Facing Camera
      • AMOLED Display Screen
      • AMOLED Capacitive Screen
      Ask FixBot
    5. Samsung Galaxy Note Edge Motherboard Replacement: step 7, image 1 of 3 Samsung Galaxy Note Edge Motherboard Replacement: step 7, image 2 of 3 Samsung Galaxy Note Edge Motherboard Replacement: step 7, image 3 of 3
      • At the top end, gently insert pointed end of spudger underneath the motherboard.
      • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
      • Remove the motherboard from the device.
      Ask FixBot
4 other people completed this guide.
Matt Clark
160 Reputation
1 Guide authored
Cal Poly, Team S22-G6, Maness Spring 2018 Member of Cal Poly, Team S22-G6, Maness Spring 2018
CPSU-MANESS-S18S22G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 71
All Time: 4,293
