Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
64
All Time:
1,031
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
The Power Button and Ear Speaker of the phone are part of one component, and thus must be replaced together. The Power Button is responsible for turning the phone on/off, as well as resetting the phone. The speaker is responsible for sound during phone calls.
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
    1. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement, Battery: step 1, image 1 of 1
      • Power down your device and make sure that it is turned off.
      • Place the phone with the screen facing down on a clean flat surface.
      Ask FixBot
    2. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 2, image 1 of 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 2, image 2 of 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 2, image 3 of 3
      • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
      • Remove battery by using your Supdger on the notch located directly underneath battery location.
      • During the creation of this guide, we did not have access to a battery in our device.
      Ask FixBot
    1. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement, Motherboard: step 3, image 1 of 1
      • Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
      • Remove the stylus from the stylus holder.
      Ask FixBot
    2. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 4, image 1 of 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 4, image 2 of 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 4, image 3 of 3
      • Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
      • Insert your spudger into the stylus socket and pry the midframe from the phone.
      • Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
      Ask FixBot
    3. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 5, image 1 of 2 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 5, image 2 of 2
      • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
      • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
      Ask FixBot
    4. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 6, image 1 of 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 6, image 2 of 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 6, image 3 of 3
      • Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner:
      • Front Facing Camera
      • AMOLED Display Screen
      • AMOLED Capacitive Screen
      Ask FixBot
    5. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 7, image 1 of 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 7, image 2 of 3 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 7, image 3 of 3
      • At the top end, gently insert pointed end of spudger underneath the motherboard.
      • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
      • Remove the motherboard from the device.
      Ask FixBot
    1. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement, Ear Speaker and Power Button: step 8, image 1 of 1
      • Gently insert the pointed end of your spudger under the gold ribbon connecting the speaker and power button.
      • Lift the ribbon to disconnect it from the frame.
      Ask FixBot
    2. Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 9, image 1 of 2 Samsung Galaxy Note Edge Ear Speaker/Power Button Replacement: step 9, image 2 of 2
      • Insert the pointed end of spudger under an edge on the left side of the phones speaker.
      • Gently pry the speaker and power button from its home.
      • Carefully remove the power button from the device.
      • To reassemble, the Power Button must be inserted back in first.
      Ask FixBot
Duc Huynh
283 Reputation
2 Guides authored
Cal Poly, Team S22-G6, Maness Spring 2018 Member of Cal Poly, Team S22-G6, Maness Spring 2018
CPSU-MANESS-S18S22G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 64
All Time: 1,031
