Up to 20% off select tools
Samsung Galaxy Note Edge Display Assembly Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
81
All Time:
3,042
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
How to change the Samsung GalaxyNote Edge / N915 screen assembly
_______Video manual_______
Video Overview
    1. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: step 1, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: step 1, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: step 1, image 3 of 3
      • Switch off the device.
      • Remove the back cover and the battery.
      Ask FixBot
    2. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: step 2, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: step 2, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: step 2, image 3 of 3
      • Remove the Memory card, the SIM card and the S Pen.
      • Remove the screws by using Screwdriver Phillips #00
      • With a plastic opening tool emove the Back Frame.
      Ask FixBot
    3. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: step 3, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: step 3, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: step 3, image 3 of 3
      • Disconnect one by one:
      • Coaxial antenna cable (x2)
      • Home Button flex cable
      • Display Flex cable
      • Stylus Sensor flex cable
      • Front Camera flex cable
      Ask FixBot
    4. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: step 4, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: step 4, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: step 4, image 3 of 3
      • Pry up the connector on the back of the board to release the bottom part of motherboard.
      • Gently remove the logic board.
      Ask FixBot
    5. Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: step 5, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: step 5, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: step 5, image 3 of 3
      • I prefer to test the new spare part before install it.
      • Transfer the Power button / Loud speaker flex cable.
      • Install the mother board.
      • Test the display.
      • To prevent damage to the put back the back frame before the test.
      Ask FixBot
    6. Samsung Galaxy Note Edge Display Assembly Replacement, Check the Thermal Pads: step 6, image 1 of 1
      • Check the quality of the thermal pads (if the spare part is not original).
      • If its necessary use the thermal pads from the old assembly.
      Ask FixBot
    7. Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: step 7, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: step 7, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: step 7, image 3 of 3
      • Insert wisdom here.
      Ask FixBot
    8. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: step 8, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: step 8, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: step 8, image 3 of 3
      • Remove the black Phillips screw,
      • the the charging port plate,
      • disconnect the Home buttons flex cable
      • and the coaxial antenna cable (x2).
      • Use hot air and a plastic opening tool to remove the Charging Port flex assembly.
      Ask FixBot
    9. Samsung Galaxy Note Edge Display Assembly Replacement, Reassembling: step 9, image 1 of 1
      • To reassemble your device, follow these instructions in reverse order.
      Ask FixBot
3 other people completed this guide.
Author
with
ZFix
197,930 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 81
All Time: 3,042
