Up to 20% off select tools
Samsung Galaxy Note Antenna Replacement
Views: 5K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
33
All Time:
5,040
Comments: 0
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
Before replacing the antenna, make sure your current antenna is the reason for you phone's problems. Check out the device's troubleshooting page to make sure your antenna is faulty. You may want to replace the antenna if your phone can't make calls or does not receive reception.
    1. Samsung Galaxy Note Antenna Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Note Antenna Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Note Antenna Replacement, Battery: step 1, image 3 of 3
      • Make sure the screen is face-down and the camera is opposite you.
      • Insert the flat end of a spudger into the phone's top right rectangular slot.
      • Use the spudger as a lever to pry open the back of the phone.
      Ask FixBot
    2. Samsung Galaxy Note Antenna Replacement: step 2, image 1 of 1
      • With the spudger still inserted, carefully slide the spudger down the side of the phone.
      • Gently peel off the back cover with your hand.
      Ask FixBot
    3. Samsung Galaxy Note Antenna Replacement: step 3, image 1 of 1
      • Place the spudger in the battery's bottom right slot.
      • Gently pry to remove the battery.
      Ask FixBot
    1. Samsung Galaxy Note Antenna Replacement, Midframe: step 4, image 1 of 1
      • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Galaxy Note Antenna Replacement: step 5, image 1 of 1
      • Remove the stylus from the bottom of the phone.
      Ask FixBot
    3. Samsung Galaxy Note Antenna Replacement: step 6, image 1 of 3 Samsung Galaxy Note Antenna Replacement: step 6, image 2 of 3 Samsung Galaxy Note Antenna Replacement: step 6, image 3 of 3
      • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
      • If the cover does not come off easily, continue to pry along the phone's perimeter.
      • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
      • Separate the midframe from the phone. The midframe should now pull off easily.
      Ask FixBot
    1. Samsung Galaxy Note Antenna Replacement, Antenna: step 7, image 1 of 1
      • Remove the two 3mm screws surrounded by a gold border with a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Galaxy Note Antenna Replacement: step 8, image 1 of 2 Samsung Galaxy Note Antenna Replacement: step 8, image 2 of 2
      • Use the spudger to pry up all six flex ribbons that hold the motherboard in place. They should pop off easily.
      Ask FixBot
    3. Samsung Galaxy Note Antenna Replacement: step 9, image 1 of 1
      • Use the spudger to pull off the white wire with the gold connector.
      Ask FixBot
    4. Samsung Galaxy Note Antenna Replacement: step 10, image 1 of 1
      • Lift the motherboard (PCB) directly up with your hands.
      • If the screws are all removed, the motherboard should come off easily.
      Ask FixBot
    5. Samsung Galaxy Note Antenna Replacement: step 11, image 1 of 2 Samsung Galaxy Note Antenna Replacement: step 11, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the three 3mm screws on the black rectangular bracket located towards the bottom of the phone.
      Ask FixBot
    6. Samsung Galaxy Note Antenna Replacement: step 12, image 1 of 1
      • Use the spudger's flat end to disconnect the other end of the antenna.
      Ask FixBot
13 other people completed this guide.
Author
with
David Ritter
758 Reputation
6 Guides authored
Cal Poly, Team 3-45, Amido Spring 2013 Member of Cal Poly, Team 3-45, Amido Spring 2013
CPSU-AMIDO-S13S3G45
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 33
All Time: 5,040
