Samsung Galaxy Note 8.0 Screen Assembly Replacement
    1. Samsung Galaxy Note 8.0 Screen Assembly Replacement, Back Cover: step 1, image 1 of 1
      • Remove the Samsung S-Pen stylus.
      • Remove the micro SD storage card.
      Ask FixBot
    2. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 2, image 1 of 1
      • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
      Ask FixBot
    3. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 3, image 1 of 1
      • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
      • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
      Ask FixBot
    1. Samsung Galaxy Note 8.0 Screen Assembly Replacement, Battery: step 4, image 1 of 2 Samsung Galaxy Note 8.0 Screen Assembly Replacement, Battery: step 4, image 2 of 2
      • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
      Ask FixBot
    2. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 5, image 1 of 1
      • Lift the top left corner of the battery up by the black tab.
      Ask FixBot
    3. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 6, image 1 of 1
      • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
      • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
      Ask FixBot
    1. Samsung Galaxy Note 8.0 Screen Assembly Replacement, Screen Digitizer and LCD: step 7, image 1 of 2 Samsung Galaxy Note 8.0 Screen Assembly Replacement, Screen Digitizer and LCD: step 7, image 2 of 2
      • Gently pull the tan part of the digitizer connector up.
      • Carefully slide the orange ribbon out from connector.
      Ask FixBot
    2. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 8, image 1 of 2 Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 8, image 2 of 2
      • Gently pull up the black part of the LCD connector.
      • Carefully slide orange ribbon out from connector.
      Ask FixBot
    3. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 9, image 1 of 1
      • Turn the tablet over screen up. Set your heat gun or blow dryer to the medium heat setting.
      • Sweep the heat gun over the white edge of the tablet screen. Apply heat for 30 seconds on each side before moving to the next side.
      • You will repeat a circular pattern bottom, left, top and then right. Repeat this pattern 3 times spending 30 seconds on each side.
      • As an alternative to a heat gun, you can use an iOpener: iOpener Instructions
      Ask FixBot
    4. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 10, image 1 of 1
      • Insert your plastic opening tool between the silver surround and the screen, starting at the top of the tablet.
      Ask FixBot
    5. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 11, image 1 of 1
      • It is important that you separate the 3 edges only at this time. The side of the tablet opposite the power button has a connection that could be damaged if this side is separated.
      • Slide your opening tool down the side of the device with the volume and power buttons. Continue sliding down the side toward the home button until the glue is free on this side.
      Ask FixBot
    6. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 12, image 1 of 1
      • Slide your opening tool down the home button edge until the glue is free on this side.
      Ask FixBot
    7. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 13, image 1 of 3 Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 13, image 2 of 3 Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 13, image 3 of 3
      • Turn the tablet over and carefully press out the LCD panel from the back along the power button edge only. Push gently on the back of the LCD in the battery opening.
      • Disconnect ribbon that is connecting the screen assembly to the motherboard
      Ask FixBot
    8. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 14, image 1 of 1
      • When inserting your opening tool on the side opposite the power button, avoid the screen cable located 7 cm from the top of the device.
      • Turn the tablet over and completely remove the LCD and screen assembly from the tablet by sliding a plastic opening tool down the final edge until the adhesive is free.
      • If you are replacing the screen by itself, continue to the next step. If you are replacing the screen digitizer only, simply follow the procedures in reverse to complete the replacement.
      Ask FixBot
    9. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 15, image 1 of 1
      • To separate the screen from the LCD you will need to heat the adhesive holding the two together.
      • Holding the heat gun, set to medium, approximately 6 inches from the screen, sweep from left to right as you move the heat gun across the tablet from top to bottom.
      • Continue heating the screen from top to bottom as you sweep from left to right for 5 minutes.
      Ask FixBot
    10. Samsung Galaxy Note 8.0 Screen Assembly Replacement: step 16, image 1 of 1
      • Find a plastic card you no longer need.
      • It will be covered in adhesive when you're done.
      • Slide the card between the screen and digitizer working around the edges toward the center.
      Ask FixBot
48 other people completed this guide.
James Laubaugh
3,120 Reputation
1 Guide authored
USF Tampa, Team 12-2, Blackwell Fall 2014 Member of USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 Members
83 Guides authored
20 Guide Comments
For steps 15 and 16, removing just the glass digitizer from the lcd, does this step happen after you completely remove the lcd from the tablet? It is hard to tell because it looks like the silver from the tablet is present but it takes place in the instructions after the lcd should already be removed and no silver should be present. Any help on this would be appreciated. I have one where the digitizer screen is broken but the lcd has no damage at all.
Zachary Warner - Reply Share
No you dont need to remove the lcd you hav to unplug the toch connector n heat the glass like in the steps
sulaiman criss - Reply Share
For step 13, I ripped this motherboard connector trying to get the new lcd in. Anyone have any idea what I have actually damaged? And where I could find out how to fix it?
Henok Yared - Reply Share
yes replacements are on ebay
Pantalla Flex Cable LCD Conector Display Screen Ribbon Samsung Galaxy Note 8.0.
haydn.nelms - Reply Share
My Samsung note 8 model N5110 has a broken screen glass. It still work very good. Question ..must I changed the digitaliser and screen . Please advice.
thanks in advance
9y4ajc - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 98
All Time: 64,817
