Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement
    1. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement, Back Cover: step 1, image 1 of 1
      • Remove the Samsung S-Pen stylus.
      • Remove the micro SD storage card.
      Ask FixBot
    2. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 2, image 1 of 1
      • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
      Ask FixBot
    3. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 3, image 1 of 1
      • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
      • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
      Ask FixBot
    1. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement, Battery: step 4, image 1 of 2 Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement, Battery: step 4, image 2 of 2
      • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
      Ask FixBot
    2. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 5, image 1 of 1
      • Lift the top left corner of the battery up by the black tab.
      Ask FixBot
    3. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 6, image 1 of 1
      • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
      • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
      Ask FixBot
    1. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement, Power/Volume Buttons: step 7, image 1 of 1
      • The volume and power buttons are joined together on a common strip, so you are replacing both simultaneously.
      Ask FixBot
    2. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 8, image 1 of 1
      • Disconnect the black connector by pulling up using a plastic opening tool underneath the edge. This connection attaches the power/volume cable to the mother board.
      Ask FixBot
    3. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 9, image 1 of 1
      • Remove the 3-mm screw holding the upper left corner of the main board using a Phillips#00 screwdriver.
      Ask FixBot
    4. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 10, image 1 of 2 Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 10, image 2 of 2
      • Gently pry the lower edge of the cable off the plastic stud just above the stylus opening.
      Ask FixBot
    5. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 11, image 1 of 1
      • Gently pry the middle of the cable up and off of the two plastic studs.
      • Gently pry the part of the cable adjacent to the power button up and off the two plastics studs.
      • Gently pry the upper part of the cable up and off the two plastic studs.
      Ask FixBot
    6. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, pull the part of the cable that is located behind the volume buttons out of the slot.
      Ask FixBot
    7. Samsung Galaxy Note 8.0 Power/Volume Buttons Replacement: step 13, image 1 of 1
      • Hold the corner of the motherboard up and carefully slide the cable out.
      Ask FixBot
25 other people completed this guide.
Joel
1,878 Reputation
6 Guides authored
USF Tampa, Team 12-2, Blackwell Fall 2014 Member of USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 Members
83 Guides authored
8 Guide Comments
My wife's Samsung galaxy note 8 would not turn on. She has had it for three years and we thought it should be scrapped. I searched for this problem on line and found this site. Ordered new on off kit on e-bay. Followed these instructions. Very straight forward. Took less than 30 minutes. Reassembled and returned tablet to wife, who is very happy. Hoping for a good meal tonight! Thanks very much Joel. Martin
Martin Lonsdale - Reply Share
what is the part number or kit number of the on/off kit, how to order. please help.
Cesar Manila - Reply Share
My Samsung Galaxy Note 8.0 (wifi only) will not switch on or respond in any way to a known-good charger being plugged into it. It hasn't had much use since new, so I don't believe it's a worn out battery or switch, but I tested those anyway. It will not reset, or hard-reset, and I have removed and tested the function of the power tact-switch, that that works fine. The battery reads 4.2V. I fear that I've bricked it. Nothing I do gives any response. Is there anything else I can try?
craig9 - Reply Share
Worked last night, was charged, checked charger(good), replaced charge port, replaced power/volume button, replaced battery. Not a peep out of the tablet. No battery image on screen. Tried hard reset etc. Nada. What now, trash can??? Can't see spending another 45 to 50 $$$ for mother board. Can any body prove Samsung built deliberate ob's into the tablet. Like read the software code.
louiseno36 - Reply Share
This is not a note 8 though
discoditto - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 147
All Time: 24,844
