Samsung Galaxy Note 8.0 Battery Replacement
    1. Samsung Galaxy Note 8.0 Battery Replacement, Back Cover: step 1, image 1 of 1
      • Remove the Samsung S-Pen stylus.
      • Remove the micro SD storage card.
      Ask FixBot
    2. Samsung Galaxy Note 8.0 Battery Replacement: step 2, image 1 of 1
      • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
      Ask FixBot
    3. Samsung Galaxy Note 8.0 Battery Replacement: step 3, image 1 of 1
      • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
      • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
      Ask FixBot
    1. Samsung Galaxy Note 8.0 Battery Replacement, Battery: step 4, image 1 of 2 Samsung Galaxy Note 8.0 Battery Replacement, Battery: step 4, image 2 of 2
      • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
      Ask FixBot
    2. Samsung Galaxy Note 8.0 Battery Replacement: step 5, image 1 of 1
      • Lift the top left corner of the battery up by the black tab.
      Ask FixBot
    3. Samsung Galaxy Note 8.0 Battery Replacement: step 6, image 1 of 1
      • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
      • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
      Ask FixBot
86 other people completed this guide.
Joel
1,878 Reputation
6 Guides authored
USF Tampa, Team 12-2, Blackwell Fall 2014 Member of USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 Members
83 Guides authored
14 Guide Comments
Please help on the connector wire connections coz mine snapped and i dont know which which is supposed to be in place.. Will be waiting.. Thanks..
Narz Ferrariz - Reply Share
Even me, 65 blond, woman made it thanks to your good guide. Thank you!!
elisabethbengzon - Reply Share
This was a great help! I was able to replace my son's battery in 10 mins. I purchased the battery from eBay for only $8. Saved me a lot of money.
orchidsinjune0511 - Reply Share
My Note would not turn on at all even though it was fully charged. Did not think it was on/off button so I followed the instructions for the Bios (reboot). Thought about it and had a program that was being fussy about turning off maybe causing an overload. These are very easy instructions to follow and better yet, it worked! My Note turned on and all is good with my world again. Learned that I really need to back up everything I have on my note. I reviewed all the instructions for the replacing of various parts and have to say the parts prices are more than reasonable. Thank you very much for having these instructions available to us novices.
Marcia Strickland - Reply Share
I just wanna say thanks, the instructions were easy to follow. I'm left-handed so I had to turn my tablet in opposite directions to get the job done. I was very nervous messing with computer parts. Thanks again.
patricia Gibson - Reply Share
Past 24 Hours: 4
Past 7 Days: 34
Past 30 Days: 124
All Time: 101,467
