Up to 20% off select tools
Samsung Galaxy Note 4 SIM Card Replacement
Views: 13K
View statistics:
Past 24 Hours:
5
Past 7 Days:
30
Past 30 Days:
129
All Time:
13,350
Comments: 6
3 comments on steps, 3 guide comments.
Go to guide comments
Completed: 31
31 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace your SIM card in your Samsung Galaxy Note 4. You may need this guide if your phone is having trouble connecting to the cellular network.
    1. Samsung Galaxy Note 4 SIM Card Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy Note 4 SIM Card Replacement, Rear Case: step 1, image 2 of 2
      • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
      • Gently pry and twist the flexible rear cover off the back of the phone.
      Ask FixBot
    1. Samsung Galaxy Note 4 SIM Card Replacement, Battery: step 2, image 1 of 1
      • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
      • Remove the battery.
      Ask FixBot
    1. Samsung Galaxy Note 4 SIM Card Replacement, SIM Card: step 3, image 1 of 2 Samsung Galaxy Note 4 SIM Card Replacement, SIM Card: step 3, image 2 of 2
      • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
      Ask FixBot
31 other people completed this guide.
Author
with
Derek Nola
2,295 Reputation
5 Guides authored
Cal Poly, Team 70-6, Forte Winter 2015 Member of Cal Poly, Team 70-6, Forte Winter 2015
CPSU-FORTE-W15S70G6
4 Members
72 Guides authored
3 Guide Comments
Thanks too much
goooooogle319 - Reply Share
Many thanks my bro
Theres 5 pins next to sim card port. Can i ask..what is the purpose of that pin?
Nirza Dhom - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 129
All Time: 13,350
