Samsung Galaxy Note 3 Rear Facing Camera Replacement
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove the rear case: step 1, image 1 of 1
      • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
      Ask FixBot
    2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: step 2, image 1 of 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: step 2, image 2 of 2
      • Slide your fingernail or plastic opening tool along the edge of the rear case.
      • Lift the case gently from the base.
      Ask FixBot
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: step 3, image 1 of 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: step 3, image 2 of 2
      • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
      • Lift the battery out of its recess.
      Ask FixBot
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, S Pen: step 4, image 1 of 1
      • Place your fingernail in the groove of the stylus pen.
      • Pull the stylus pen away from the phone.
      Ask FixBot
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unscrew Back Chassis: step 5, image 1 of 1
      • Remove the twelve 4mm Phillips #00 screws from the back chassis.
      Ask FixBot
    2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Back Chassis: step 6, image 1 of 1
      • Insert the plastic opening tool into the Stylus Pen placement holder.
      • Lift the plastic opening tool so that the midframe separates from the base.
      Ask FixBot
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: step 7, image 1 of 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: step 7, image 2 of 2
      • Remove the single screw beside headphone jack.
      Ask FixBot
    2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: step 8, image 1 of 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove both antenna clips.
      • Use a spudger to disconnect six cable connectors.
      Ask FixBot
    3. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Motherboard Removal: step 9, image 1 of 1
      • Pull up on the motherboard with tweezers.
      Ask FixBot
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unclipping the Camera: step 10, image 1 of 1
      • Unclip the camera connecting cable using the plastic opening tool from the motherboard
      • Remove loose camera from base
      Ask FixBot
37 other people completed this guide.
Brittany Gail
8,581 Reputation
7 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2014 Member of USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Members
84 Guides authored
3 Guide Comments
Awesome, phone disassembly and fingernail painting at same time :) Thanks for your time to post this!
Chris G - Reply Share
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
hameidfehri - Reply Share
I shall be very thankfull for this act of kindness
Malik wajdan ali - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 102
All Time: 14,423
