Samsung Galaxy Note 3 Motherboard Replacement
    1. Samsung Galaxy Note 3 Motherboard Replacement, Remove the rear case: step 1, image 1 of 1
      • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
      Ask FixBot
    2. Samsung Galaxy Note 3 Motherboard Replacement, Remove Case from the Base: step 2, image 1 of 2 Samsung Galaxy Note 3 Motherboard Replacement, Remove Case from the Base: step 2, image 2 of 2
      • Slide your fingernail or plastic opening tool along the edge of the rear case.
      • Lift the case gently from the base.
      Ask FixBot
    1. Samsung Galaxy Note 3 Motherboard Replacement, Battery: step 3, image 1 of 2 Samsung Galaxy Note 3 Motherboard Replacement, Battery: step 3, image 2 of 2
      • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
      • Lift the battery out of its recess.
      Ask FixBot
    1. Samsung Galaxy Note 3 Motherboard Replacement, S Pen: step 4, image 1 of 1
      • Place your fingernail in the groove of the stylus pen.
      • Pull the stylus pen away from the phone.
      Ask FixBot
    1. Samsung Galaxy Note 3 Motherboard Replacement, Unscrew Back Chassis: step 5, image 1 of 1
      • Remove the twelve 4mm Phillips #00 screws from the back chassis.
      Ask FixBot
    2. Samsung Galaxy Note 3 Motherboard Replacement, Remove Back Chassis: step 6, image 1 of 1
      • Insert the plastic opening tool into the Stylus Pen placement holder.
      • Lift the plastic opening tool so that the midframe separates from the base.
      Ask FixBot
    1. Samsung Galaxy Note 3 Motherboard Replacement, Screw Removal: step 7, image 1 of 2 Samsung Galaxy Note 3 Motherboard Replacement, Screw Removal: step 7, image 2 of 2
      • Remove the single screw beside headphone jack.
      Ask FixBot
    2. Samsung Galaxy Note 3 Motherboard Replacement, Unfasten Clips and Cable Connectors: step 8, image 1 of 2 Samsung Galaxy Note 3 Motherboard Replacement, Unfasten Clips and Cable Connectors: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove both antenna clips.
      • Use a spudger to disconnect six cable connectors.
      Ask FixBot
    3. Samsung Galaxy Note 3 Motherboard Replacement, Motherboard Removal: step 9, image 1 of 1
      • Pull up on the motherboard with tweezers.
      Ask FixBot
75 other people completed this guide.
Brittany Gail
8,581 Reputation
7 Guides authored
USF Tampa, Team 2-2, Blackwell Fall 2014 Member of USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Members
84 Guides authored
4 Guide Comments
I'm looking for the screws for this phone, but all the search hits I've come across are for the screwdriver. Any leads on where I can find the screws?
Jared Lunt - Reply Share
I can replace motherboard sm-n9005 with motherboard sm-n900
yacine - Reply Share
I want to replace motherboard of galaxy note 3 SM-N900 with SM-N9005. Is it possible and can it convert 3g to 4G. Because my phone doesn't support 4G .it is 3g and I want to make it 4G .what should I do help me
Nippy Preet - Reply Share
I am also looking for the same question
Jalil Ahmad - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 132
All Time: 52,462
