Parts
Introduction
Go to step 1 ↓Follow the steps in order to replace your battery.
If your battery is swollen, take appropriate precautions.
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its recess.
48 other people completed this guide.
4 Guide Comments
Mon telephone ne garde pas la charge plus d'une heure même si j'ai changé la batterie mais reste le même problème
